MQTT Publish Payload Size Limitation in Serial LTE Modem App 2.0.0
Our tests and the MQTT publish documentation indicate a payload size limitation of 256 bytes for MQTT publish, which we see is set with an enum in slm_at_mqtt.c. Our understanding is that this limitation is  smaller than in previous versions of SLM, though documentation suggests the 9160 can support transmissions of up to 2kb.
Could you please provide clarity on the size limitation - why it was restricted and if there is a preferred method which supports the publishing of longer messages?
Thank you.
