Sample Peripheral UART, can't compile on DK5340 with CDC configuration
I can compile the sample Peripheral UART on the DK5340 with VSC without any problem (standard prj.conf).
I'm trying to compile with the CDC configuration (prj_cdc.conf and DTC_OVERLAY_FILE = usb.overlay) but it fails.
I have no clue what's going wrong, Can you help me ?
Stéphane
Building peripheral_uart
west build --build-dir s:\AURORA\nRF\peripheral_uart\build_cdc s:\AURORA\nRF\peripheral_uart --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="s:/AURORA/nRF/peripheral_uart/prj_cdc.conf" -DBOARD_ROOT:STRING="s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart" -DBOARD_ROOT:STRING="s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart" -DDTC_OVERLAY_FILE:STRING="s:/AURORA/nRF/peripheral_uart/usb.overlay"
-- Application: S:/AURORA/nRF/peripheral_uart
-- Found Python3: C:/ncs/toolchains/v2.0.2/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.0.2/zephyr/.cache
-- Zephyr version: 3.0.99 (C:/ncs/v2.0.2/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.2/opt/zephyr-sdk)
-- Found dtc: C:/ncs/toolchains/v2.0.2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.2/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.0.2/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: usb.overlay
-- Generated zephyr.dts: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/dts.cmake
Parsing S:/AURORA/nRF/peripheral_uart/Kconfig
Loaded configuration 'C:/ncs/v2.0.2/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 's:/AURORA/nRF/peripheral_uart/prj_cdc.conf'
warning: BT_SMP (defined at C:\ncs\v2.0.2\zephyr\subsys\bluetooth\host\Kconfig:310, s:\AURORA\nRF\peripheral_uart\build_cdc\subsys\bluetooth\host\Kconfig:310) has direct dependencies (BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (BT_CONN && BT_HCI_HOST && BT_HCI && BT) with value n, but is currently being y-selected by the following symbols:
 - BT_NUS_SECURITY_ENABLED (defined at S:\AURORA\nRF\peripheral_uart\Kconfig:23), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at C:\ncs\v2.0.2\zephyr\cmake\modules\kconfig.cmake:290 (message):
  command failed with return code: 1
  C:\ncs\v2.0.2\zephyr\cmake\modules\zephyr_default.cmake:121 (include)
  C:\ncs\v2.0.2\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:51 (include)
  C:\ncs\v2.0.2\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:76 (include_boilerplate)
  s:\AURORA\nRF\peripheral_uart\build_cdc\CMakeLists.txt:14 (find_package)
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.0.2\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.0.2\opt\bin\python.exe' '-Bs:\AURORA\nRF\peripheral_uart\build_cdc' '-Ss:\AURORA\nRF\peripheral_uart' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=s:/AURORA/nRF/peripheral_uart/prj_cdc.conf '-DBOARD_ROOT:STRING=s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart' '-DBOARD_ROOT:STRING=s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart' -DDTC_OVERLAY_FILE:STRING=s:/AURORA/nRF/peripheral_uart/usb.overlay
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
    There is an explanation of how to provide the CMake options in the documentation under Important Build System Variables which is also mentioned in the 'Activating sample extensions' section, but I agree that this could be clearer.
    However, this is also explained in the VS Code extension. If you hover over the question mark next to 'Extra CMake arguments' you get an explanation of the format they should be provided as:
    Marte
  • Hi Marte,
    I'm not saying that the information isn't available somewhere, I just think that the documentation for an example should be more explicit.
    Every employee at nordic is familiar with cmake and the nordic way of doing things, and for these people (such as yourself) the documentation is sufficient, and perhaps even mind-numbingly clear. Personally, it took me a few hours to find this thread and figure it out, which felt like a long time for an example project.
    I don't think I have anything more to add that will change your mind. Thank you for sharing your side of things.
