Sample Peripheral UART, can't compile on DK5340 with CDC configuration
I can compile the sample Peripheral UART on the DK5340 with VSC without any problem (standard prj.conf).
I'm trying to compile with the CDC configuration (prj_cdc.conf and DTC_OVERLAY_FILE = usb.overlay) but it fails.
I have no clue what's going wrong, Can you help me ?
Stéphane
Building peripheral_uart
west build --build-dir s:\AURORA\nRF\peripheral_uart\build_cdc s:\AURORA\nRF\peripheral_uart --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="s:/AURORA/nRF/peripheral_uart/prj_cdc.conf" -DBOARD_ROOT:STRING="s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart" -DBOARD_ROOT:STRING="s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart" -DDTC_OVERLAY_FILE:STRING="s:/AURORA/nRF/peripheral_uart/usb.overlay"
-- Application: S:/AURORA/nRF/peripheral_uart
-- Found Python3: C:/ncs/toolchains/v2.0.2/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.0.2/zephyr/.cache
-- Zephyr version: 3.0.99 (C:/ncs/v2.0.2/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.2/opt/zephyr-sdk)
-- Found dtc: C:/ncs/toolchains/v2.0.2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.0.2/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.0.2/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: usb.overlay
-- Generated zephyr.dts: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: S:/AURORA/nRF/peripheral_uart/build_cdc/zephyr/dts.cmake
Parsing S:/AURORA/nRF/peripheral_uart/Kconfig
Loaded configuration 'C:/ncs/v2.0.2/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 's:/AURORA/nRF/peripheral_uart/prj_cdc.conf'
warning: BT_SMP (defined at C:\ncs\v2.0.2\zephyr\subsys\bluetooth\host\Kconfig:310, s:\AURORA\nRF\peripheral_uart\build_cdc\subsys\bluetooth\host\Kconfig:310) has direct dependencies (BT_CONN && BT_HCI_HOST && BT_RPC_STACK) || (BT_CONN && BT_HCI_HOST && BT_HCI && BT) with value n, but is currently being y-selected by the following symbols:
 - BT_NUS_SECURITY_ENABLED (defined at S:\AURORA\nRF\peripheral_uart\Kconfig:23), with value y, direct dependencies y (value: y)
error: Aborting due to Kconfig warnings
CMake Error at C:\ncs\v2.0.2\zephyr\cmake\modules\kconfig.cmake:290 (message):
  command failed with return code: 1
  C:\ncs\v2.0.2\zephyr\cmake\modules\zephyr_default.cmake:121 (include)
  C:\ncs\v2.0.2\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:51 (include)
  C:\ncs\v2.0.2\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:76 (include_boilerplate)
  s:\AURORA\nRF\peripheral_uart\build_cdc\CMakeLists.txt:14 (find_package)
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.0.2\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\ncs\toolchains\v2.0.2\opt\bin\python.exe' '-Bs:\AURORA\nRF\peripheral_uart\build_cdc' '-Ss:\AURORA\nRF\peripheral_uart' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=s:/AURORA/nRF/peripheral_uart/prj_cdc.conf '-DBOARD_ROOT:STRING=s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart' '-DBOARD_ROOT:STRING=s:/AURORA/nRF/fat_fs;s:/AURORA/nRF/fat_fs2;s:/AURORA/nRF/peripheral_uart' -DDTC_OVERLAY_FILE:STRING=s:/AURORA/nRF/peripheral_uart/usb.overlay
 *  The terminal process terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
