Scan a period if time then advertising a period of time
So I am working on ner52840 with nrf connect sdk, I need to scan a device which is broadcasting ble 5.0 extend advertising for a period of time(probably 2 second), then my device need to advertise for a period of time and do someother work. I tired to use the example periodic _sync, but I don't know how to stop the scanning process after scanning for two second.
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#include <bluetooth/bluetooth.h>
#define TIMEOUT_SYNC_CREATE K_SECONDS(10)
#define NAME_LEN            30
static bool         per_adv_found;
static bt_addr_le_t per_addr;
static uint8_t      per_sid;
static K_SEM_DEFINE(sem_per_adv, 0, 1);
static K_SEM_DEFINE(sem_per_sync, 0, 1);
static K_SEM_DEFINE(sem_per_sync_lost, 0, 1);
static bool data_cb(struct bt_data *data, void *user_data)
	char *name = user_data;
	uint8_t len;
	switch (data->type) {
	case BT_DATA_NAME_SHORTENED:
	case BT_DATA_NAME_COMPLETE:
		len = MIN(data->data_len, NAME_LEN - 1);
		memcpy(name, data->data, len);
		name[len] = '\0';
		return false;
		return true;
static const char *phy2str(uint8_t phy)
	switch (phy) {
	case 0: return "No packets";
	case BT_GAP_LE_PHY_1M: return "LE 1M";
	case BT_GAP_LE_PHY_2M: return "LE 2M";
	case BT_GAP_LE_PHY_CODED: return "LE Coded";
	default: return "Unknown";
static void scan_recv(const struct bt_le_scan_recv_info *info,
		      struct net_buf_simple *buf)
	char le_addr[BT_ADDR_LE_STR_LEN];
	char name[NAME_LEN];
	(void)memset(name, 0, sizeof(name));
	bt_data_parse(buf, data_cb, name);
	bt_addr_le_to_str(info->addr, le_addr, sizeof(le_addr));
	printk("[DEVICE]: %s, AD evt type %u, Tx Pwr: %i, RSSI %i %s "
	       "C:%u S:%u D:%u SR:%u E:%u Prim: %s, Secn: %s, "
	       "Interval: 0x%04x (%u ms), SID: %u\n",
	       le_addr, info->adv_type, info->tx_power, info->rssi, name,
	       (info->adv_props & BT_GAP_ADV_PROP_CONNECTABLE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_SCANNABLE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_DIRECTED) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_SCAN_RESPONSE) != 0,
	       (info->adv_props & BT_GAP_ADV_PROP_EXT_ADV) != 0,
	       phy2str(info->primary_phy), phy2str(info->secondary_phy),
	       info->interval, info->interval * 5 / 4, info->sid);
	if (!per_adv_found && info->interval) {
		per_adv_found = true;
		per_sid = info->sid;
		bt_addr_le_copy(&per_addr, info->addr);
		k_sem_give(&sem_per_adv);
static struct bt_le_scan_cb scan_callbacks = {
	.recv = scan_recv,
static void sync_cb(struct bt_le_per_adv_sync *sync,
		    struct bt_le_per_adv_sync_synced_info *info)
	printk("PER_ADV_SYNC[%u]: [DEVICE]: %s synced, "
	       "Interval 0x%04x (%u ms), PHY %s\n",
	       bt_le_per_adv_sync_get_index(sync), le_addr,
	       info->interval, info->interval * 5 / 4, phy2str(info->phy));
	k_sem_give(&sem_per_sync);
static void term_cb(struct bt_le_per_adv_sync *sync,
		    const struct bt_le_per_adv_sync_term_info *info)
	printk("PER_ADV_SYNC[%u]: [DEVICE]: %s sync terminated\n",
	       bt_le_per_adv_sync_get_index(sync), le_addr);
	k_sem_give(&sem_per_sync_lost);
static void recv_cb(struct bt_le_per_adv_sync *sync,
		    const struct bt_le_per_adv_sync_recv_info *info,
	char data_str[129];
	bin2hex(buf->data, buf->len, data_str, sizeof(data_str));
	printk("PER_ADV_SYNC[%u]: [DEVICE]: %s, tx_power %i, "
	       "RSSI %i, CTE %u, data length %u, data: %s\n",
	       bt_le_per_adv_sync_get_index(sync), le_addr, info->tx_power,
	       info->rssi, info->cte_type, buf->len, data_str);
static struct bt_le_per_adv_sync_cb sync_callbacks = {
	.synced = sync_cb,
	.term = term_cb,
	.recv = recv_cb
void main(void)
	struct bt_le_per_adv_sync_param sync_create_param;
	struct bt_le_per_adv_sync *sync;
	int err;
	printk("Starting Periodic Advertising Synchronization Demo\n");
	/* Initialize the Bluetooth Subsystem */
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Scan callbacks register...");
	bt_le_scan_cb_register(&scan_callbacks);
	printk("success.\n");
	printk("Periodic Advertising callbacks register...");
	bt_le_per_adv_sync_cb_register(&sync_callbacks);
	printk("Success.\n");
	printk("Start scanning...");
	err = bt_le_scan_start(BT_LE_SCAN_ACTIVE, NULL);
	if (err) {
		printk("failed (err %d)\n", err);
		return;
	do {
		printk("Waiting for periodic advertising...\n");
		per_adv_found = false;
		err = k_sem_take(&sem_per_adv, K_FOREVER);
		if (err) {
			return;
		printk("Found periodic advertising.\n");
		printk("Creating Periodic Advertising Sync...");
		bt_addr_le_copy(&sync_create_param.addr, &per_addr);
		sync_create_param.options = 0;
		sync_create_param.sid = per_sid;
		sync_create_param.skip = 0;
		sync_create_param.timeout = 0xa;
		err = bt_le_per_adv_sync_create(&sync_create_param, &sync);
		if (err) {
			return;
		printk("Waiting for periodic sync...\n");
		err = k_sem_take(&sem_per_sync, TIMEOUT_SYNC_CREATE);
		if (err) {
			printk("Deleting Periodic Advertising Sync...");
			err = bt_le_per_adv_sync_delete(sync);
			if (err) {
				return;
			continue;
		printk("Periodic sync established.\n");
		printk("Waiting for periodic sync lost...\n");
		err = k_sem_take(&sem_per_sync_lost, K_FOREVER);
		if (err) {
			return;
		printk("Periodic sync lost.\n");
	} while (true);
    There are a few different ways to do this.
    I am not sure whether you are aware or not, but it would be possible to scan and advertise at the same time. There will be some collisions so from time to time an advertisement or scan window will be skipped, but that is usually fine.
    However, if you want to either scan or advertise, that is perfectly fine as well.
    Either you can use a repeated timer, and swap between scanning and advertising in the timeout events. Then you can just use the API to e.g. stop advertising and start scanning, or vice versa.
    The other alternative is to set up both scanning and advertising with a timeout. I have not looked at the "periodic _sync", but looking at the central_uart sample found in:
    NCS\nrf\samples\bluetooth\central_uart
    You can change:
    	int err;
    	struct bt_scan_init_param scan_init = {
    		.connect_if_match = 1,
    to
    	int err;
        struct bt_le_scan_param scan_param = {
            .timeout = 200,
            .scan_param = &scan_param,
    The .timeout parameter is units of 10ms, so 200 will be 2000ms = 2 seconds.
    When the scanning times out, you will get a callback, in which you can start scanning.
    I have not tested this, so you may need to populate more of the scan_param struct, in order for it to work properly (other than setting only the .timeout = 200).
    Edvin
  • Thanks for the answer, I will try to implement this
  •  Hi I tried to implement but I can't find bt_scan_init_param this struct in bluetooth.h file.
  • Whatever you input into your scan init function, is the parameter that holds the scan parameters. Perhaps your scan init function just uses a macro holding some default parameters. If you can't find it, perhaps you can show me what the function that initializes your scanning looks like, and let me know what NCS version you are using.
    Edvin
