pdn: Failed to configure CID 0, err, -1 after upgrading the SPI flash memory
I would like to carry the full modem update.
Based on nordic website I need at least 4MBytes of flash for doing a full modem update on the nRF9160:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nrf9160/http_update/full_modem_update/README.html
Currently i am using the Winbond W25Q64JV 8MBytes flash memory.
www.digikey.com/.../5803999
My Environment
Device: nRF9160
SDK vesion: v1.9.1
prj.conf
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
# General config
CONFIG_REBOOT=y
CONFIG_RING_BUFFER=y
# LOGGNG
CONFIG_LOG=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_LOG2_MODE_DEFERRED=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_LOG_DEFAULT_LEVEL=4
# Console
CONFIG_PRINTK=y
CONFIG_UART_CONSOLE=n
CONFIG_SHELL=y
CONFIG_KERNEL_SHELL=y
CONFIG_DEVICE_SHELL=y
CONFIG_POSIX_CLOCK=y
CONFIG_DATE_SHELL=y
CONFIG_SHELL_STACK_SIZE=1024
CONFIG_SHELL_BACKEND_SERIAL=n
CONFIG_SHELL_LOG_BACKEND=y
CONFIG_SHELL_RTT_LOG_LEVEL_DBG=y
CONFIG_SHELL_RTT_INIT_LOG_LEVEL_WRN=y
CONFIG_THREAD_MONITOR=y
CONFIG_INIT_STACKS=y
CONFIG_BOOT_BANNER=n
CONFIG_THREAD_NAME=y
#enable RTT shell
CONFIG_USE_SEGGER_RTT=y
CONFIG_SHELL_BACKEND_RTT=y
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=32
# UART
CONFIG_UART_ASYNC_API=y
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_MODEM_INFO=y
CONFIG_MODEM_KEY_MGMT=y
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_NEWLIB_LIBC=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_LOCK_BANDS=y
CONFIG_LTE_LOCK_BAND_MASK="0000000001000000000000000001"
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# PDN library
CONFIG_PDN=y
CONFIG_PDN_SYS_INIT=y
CONFIG_PDN_DEFAULTS_OVERRIDE=y
CONFIG_PDN_DEFAULT_APN="my apn here"
CONFIG_PDN_DEFAULT_FAM_IPV4=y
CONFIG_PDN_DEFAULT_AUTH_CHAP=y
CONFIG_PDN_DEFAULT_USERNAME="my username"
CONFIG_PDN_DEFAULT_PASSWORD="my password"
# Stacks and heaps
CONFIG_HEAP_MEM_POOL_SIZE=16384
# for debug
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_OPENOCD_SUPPORT=y
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
# Flash
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_SPI_NOR=y
# I2C
CONFIG_I2C_NRFX=y
CONFIG_I2C=y
#IMU
CONFIG_SENSOR=y
CONFIG_ICM42605=y
CONFIG_ICM42605_TRIGGER_NONE=y
# json
CONFIG_JSON_LIBRARY=y
# for Zmod library
CONFIG_FPU=y
CONFIG_FPU_SHARING=y
CONFIG_FP_HARDABI=y
CONFIG_CPU_LOAD=y
CONFIG_CPU_LOAD_LOG_INTERVAL=2000
CONFIG_CPU_LOAD_LOG_PERIODIC=y
CONFIG_DATE_TIME=y
CONFIG_APP_VERSION="v0.0.4"
CONFIG_WARNING_BUZZER=n
CONFIG_DEVELOP_MODE=n
CONFIG_STAGING_FLG=n
# appication fota update configuration
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_SOCKET_RETRIES=5
CONFIG_DOWNLOAD_HOST="stg-domain.com"
CONFIG_DOWNLOAD_FILE="https://stg-domain.com/app_update.bin"
CONFIG_DOWNLOAD_HOST_PROD="prd-domain.com"
CONFIG_DOWNLOAD_FILE_PROD="https://prd-domain.com/app_update.bin"
#DFU
CONFIG_DFU_TARGET=y
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMG_MANAGER=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# Download client
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2048
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=n
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG=y
CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS=y
#modem delta update configuartion
CONFIG_MODEM_DELTA_UPDATE_VERSION="mfw_nrf9160_1.3.2"
CONFIG_DOWNLOAD_DELTA_MODEM_FILE="https://stg-domain.com/mfw_nrf9160_update_from_1.3.1_to_1.3.2.bin"
CONFIG_DOWNLOAD_DELTA_MODEM_FILE_PROD="https://prd-domain.com/mfw_nrf9160_update_from_1.3.1_to_1.3.2.bin"
nrf9160_common.dts
 * Copyright (c) 2018-2020 Nordic Semiconductor ASA
	model = "modelname";
	compatible = "modelname";
	/* These aliases are provided for compatibility with samples */
	aliases {
		led-pwm = &pwm0;
		buzzer-pwm = &pwm1;
&adc {
	status = "okay";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
/* PWM0 is intended for LED(PWM Serial) control */
&pwm0 {
	status = "okay";
	ch0-pin = <12>;
/* PWM1 is intended for buzzer control */
&pwm1 {
	status = "okay";
	ch0-pin = <1>;
	ch1-pin = <0>;
	ch1-inverted;
&uart0 {
	current-speed = <9600>;
	status = "okay";
	tx-pin = <15>;
	rx-pin = <16>;
&i2c1 {
	status = "okay";
	sda-pin = <4>;
	scl-pin = <3>;
	clock-frequency = <100000>;
&spi2 {
	status = "okay";
	sck-pin = <8>;
	mosi-pin = <10>;
	miso-pin = <9>;
	miso-pull-up;
	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
	icm42605@0 {
		compatible = "invensense,icm42605";
		label = "ICM-42605";
		spi-max-frequency = <1000000>;
		accel-hz = <100>;
		gyro-hz = <100>;
		accel-fs = <2>;
		reg = <0>;
		int-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>;
&spi3 {
	status = "okay";
	sck-pin = <27>;
	mosi-pin = <28>;
	miso-pin = <30>;
	cs-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
	w25q64jv: w25q64jv@0 {
		compatible = "jedec,spi-nor";
		label = "w25q64jv";
		size = <0x4000000>; // 32MBit
		spi-max-frequency = <40000000>;
		reg = <0>;
		jedec-id = [ ef 40 17 ]; // 64MBit
		wp-gpios = <&gpio0 29 0>;
		hold-gpios = <&gpio0 26 0>;
&timer0 {
	status = "okay";
&timer1 {
	status = "okay";
&timer2 {
	status = "okay";
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0x10000>;
		slot0_partition: partition@10000 {
			label = "image-0";
		slot0_ns_partition: partition@50000 {
			label = "image-0-nonsecure";
		slot1_partition: partition@80000 {
			label = "image-1";
		slot1_ns_partition: partition@c0000 {
			label = "image-1-nonsecure";
		scratch_partition: partition@f0000 {
			label = "image-scratch";
			reg = <0x000f0000 0xa000>;
		storage_partition: partition@fa000 {
			label = "storage";
			reg = <0x000fa000 0x00006000>;
	reserved-memory {
		#size-cells = <1>;
		ranges;
		sram0_s: image_s@20000000 {
			/* Secure image memory */
		sram0_modem: image_modem@20016000 {
			/* Modem (shared) memory */
		sram0_ns: image_ns@20020000 {
			/* Non-Secure image memory */
/* Include partition configuration file */
#include "nrf9160_partition_conf.dts"
nrf1960_partition_conf.dts
&slot0_partition {
	reg = <0x00010000 0x40000>;
&slot0_ns_partition {
	reg = <0x00050000 0x30000>;
&slot1_partition {
	reg = <0x00080000 0x40000>;
&slot1_ns_partition {
	reg = <0x000c0000 0x30000>;
&sram0_s {
	reg = <0x20000000 DT_SIZE_K(88)>;
&sram0_modem {
	reg = <0x20016000 DT_SIZE_K(40)>;
&sram0_ns {
	reg = <0x20020000 DT_SIZE_K(128)>;
device_get_binding for w25q64jv flash memory
flash_dev = DEVICE_DT_GET(DT_NODELABEL(w25q64jv));
the above device binding information got from this ticket link
SPI flash driver w25q64jv was found successfully.
I am getting below error
RTT Error log
rtt:~$ Found SPI flash driver w25q64jv
[00:02:30.951,354] <err> pdn: Failed to configure CID 0, err, -1
[00:02:30.951,385] <err> pdn: Failed to configure default CID, err -1
NOTE:
PDN error won't occur in other device with w25q32jv 4Mbytes flash memory.
It is occurring only in device with w25q64jv 8Mbytes flash memory.
am i missing anything in spi3 configuration of device tree?
Please guide to overcome this problem.
Best Regards
Praveen Deshmane
    The error returned (-1) from pdn_init() indicates that the modem lib is not yet initialized.
    I would recommend that you initalize the pdn connection in your application by setting :
    CONFIG_PDN_SYS_INIT=n
    And initialize PDN prior to executing AT+CFUN=1 (ie. before lte_lc_init()), similar to what is done in the lwm2m sample:
    https://github.com/nrfconnect/sdk-nrf/blob/v2.0.0/samples/nrf9160/lwm2m_client/src/main.c#L407-L413
    Could you try this and see if this works better?
    Håkon
  • Hi Hakon,
    Thank you for your reply and time.
    As you recommended, I set pdn connection in prj.conf
    lte.c
    #if !defined(CONFIG_NRF_MODEM_LIB_SYS_INIT)
    	ret = nrf_modem_lib_init(NORMAL_MODE);
    	LOG_DBG("inside normal mode\n");
    #else
    	/* If nrf_modem_lib is initialized on post-kernel we should
    	* fetch the returned error code instead of nrf_modem_lib_init
    	ret = nrf_modem_lib_get_init_ret();
    	LOG_DBG("nrf_modem_lib_get_init_ret\n");
    	switch (ret) {
    	case MODEM_DFU_RESULT_OK:
    		LOG_DBG("Modem firmware update successful!\n");
    		LOG_DBG("Modem will run the new firmware after reboot\n");
    		sys_reboot(0);
    	case MODEM_DFU_RESULT_UUID_ERROR:
    	case MODEM_DFU_RESULT_AUTH_ERROR:
    		LOG_DBG("Modem firmware update failed\n");
    		LOG_DBG("Modem will run non-updated firmware on reboot.\n");
    		sys_reboot(0);
    	case MODEM_DFU_RESULT_HARDWARE_ERROR:
    	case MODEM_DFU_RESULT_INTERNAL_ERROR:
    		LOG_DBG("Fatal error.\n");
    	case -1:
    		LOG_DBG("Could not initialize momdem library.\n");
    #if defined (SDK_UPDATE_1_9_1)
    #else	// #if defined (SDK_UPDATE_1_9_1)
    	/* Initialize AT comms in order to provision the certificate */
    	ret = at_comms_init();
    	if (ret) {
    		LOG_ERROR("Faild to at_comms_init(): %d", ret);
    		return ret;
    #endif	// #if defined (SDK_UPDATE_1_9_1)
    	LOG_DEBUG("%s", "write certificates");
    	/* Provision certificates before connecting to the LTE network */
    	ret = carrier_certs_provision();
    	if (ret) {
    		LOG_ERROR("%s", "write certificates error");
    		return ret;
    	LOG_DEBUG("%s", "PDN connection start");
    	if(gl_cid != 0)
    		int ret2 = pdn_ctx_destroy(gl_cid);
    		LOG_INFO("pdn_ctx_destroy() ret2=%d", ret2);
    		gl_cid = 0;
    	/* Register to the necessary packet domain AT notifications */
    	ret = nrf_modem_at_printf("AT+CNEC=16");
    	ret = at_cmd_write("AT+CNEC=16", NULL, 0, NULL);
    	if (ret)
    		LOG_ERROR("AT+CNEC=16 failed, err %d", ret);
    		return ret;
    	ret = nrf_modem_at_printf("AT+CGEREP=1");
    	ret = at_cmd_write("AT+CGEREP=1", NULL, 0, NULL);
    	if (ret)
    		LOG_ERROR("AT+CGEREP=1 failed, err %d", ret);
    		return ret;
    	ret = pdn_init();
    	if (ret)
    		LOG_ERROR("pdn_init, err %d", ret);
    		return ret;
    	ret = pdn_default_apn_get(apn, sizeof(apn));
    	if (ret)
    		LOG_ERROR("pdn_default_apn_get() failed, err %d", ret);
    		return ret;
    	LOG_INFO("APN is %s", apn);
    	/* Setup a callback for the default PDP context (zero).
    	 * Do this before switching to function mode 1 (CFUN=1)
    	 * to receive the first activation event.
    	ret = pdn_default_callback_set(pdn_event_handler);
    	if (ret)
    		LOG_ERROR("pdn_default_callback_set() failed, err %d", ret);
    		return ret;
    	LOG_DEBUG("pdn_default_callback_set() passed, ret %d", ret);
    	ret = lte_lc_init_and_connect();
    	if (ret && ret != -EALREADY)
    		LOG_ERROR("lte_lc_init_and_connect() failed, err %d", ret);
    		return ret;
    	/* Create a PDP context and assign an event handler to receive events */
    	ret = pdn_ctx_create(&gl_cid, pdn_event_handler);
    	if (ret)
    		LOG_ERROR("pdn_ctx_create() failed, err %d", ret);
    		return ret;
    	/* Configure a PDP context with APN and Family */
    	ret = pdn_ctx_configure(gl_cid, apn, PDN_FAM_IPV4, NULL);
    	if (ret)
    		LOG_ERROR("pdn_ctx_configure() failed, err %d", ret);
    		return ret;
    	/* Configure a PDP context with AUTH */
    	ret = pdn_ctx_auth_set(gl_cid, PDN_AUTH_CHAP, "mobile@iij", "iij");
    	if (ret)
    		return ret;
    	/* Activate a PDN connection */
    	ret = pdn_activate(gl_cid, &esm, &fam);
    	ret = pdn_activate(gl_cid, &esm);
    	if (ret)
    		LOG_ERROR("pdn_activate() failed, err %d esm %d %s",
    				ret, esm, esm_strerr(esm));
    		return ret;
    I am getting below warning now
    modem_key_mgmt: Failed to retrieve CMEE status, err -77
    Please tell me what is wrong.
    Best Regards
    Praveen Deshmane
    The pdn_ctx_destroy is potentially called before pdn_init. is this intentional?
    Could you share a larger log to see where you get this warning returned?
    Does everything else work as intended?
    Håkon
  • Hello Hakon,
    Thank you for your reply and also sorry for replying late.
    As you asked here it is the larger log
    [00:00:00.288,024] <wrn> date_time: Valid time not currently available
    [00:00:00.294,281] <wrn> modem_key_mgmt: Failed to retrieve CMEE status, err -77
    [00:00:00.295,471] <err> LTE: write certificates error
    [00:00:00.295,562] <wrn> date_time: Valid time not currently available
    [00:00:00.295,593] <wrn> LTE_TH: lte_init error ret=-1
    [00:00:00.295,684] <wrn> date_time: Valid time not currently available
    [00:00:00.302,520] <wrn> LOGGER_TH: erase! boot_info initial
    [00:00:00.302,612] <wrn> date_time: Valid time not currently available
    carrier_certs.c
    #include <stdint.h>
    #include <string.h>
    #include <toolchain.h>
    #include <sys/util.h>
    #include <modem/modem_key_mgmt.h>
    #include <logging/log.h>
    #include "carrier_certs.h"
    #if (CONFIG_DEVELOP_MODE == 1)
    LOG_MODULE_REGISTER(carrier_certs, CONFIG_LOG_MAX_LEVEL);
    #else	//#if (CONFIG_DEVELOP_MODE == 1)
    LOG_MODULE_REGISTER(carrier_certs, CONFIG_LOG_OVERRIDE_LEVEL);
    #endif	//#if (CONFIG_DEVELOP_MODE == 1)
    #define TLS_MC_API_SEC_TAG	42
    #if 0
    #define TLS_FOTA_SEC_TAG	43
    #endif //end if 0
    /* The order of the tags in this array specifies which tag is used first */
    #if 0
    static int tags[] = { TLS_MC_API_SEC_TAG, TLS_FOTA_SEC_TAG };
    #endif //end if 0
    static int tags[] = { TLS_MC_API_SEC_TAG };
    static const char ca42[] = {
    	#include "./certs/mc_api.cer"
    #if 0
    static const char ca43[] = {
    	/* FOTA server certificate */
    	#include "./certs/fota.cer"
    #endif //end if 0
    BUILD_ASSERT(sizeof(ca42) < KB(4), "Cert is too large");
    #if 0
    BUILD_ASSERT(sizeof(ca43) < KB(4), "Cert is too large");
    #endif //end if 0
    static const struct {
    	uint16_t tag;
    	const char *data;
    } certs[] = {
    		.tag = TLS_MC_API_SEC_TAG,
    		.data = ca42,
    	#if 0
    		.tag = TLS_FOTA_SEC_TAG,
    		.data = ca43,
    	#endif //end if 0
    int carrier_certs_provision()
    	int err;
    	bool mismatch = 0;
    	bool provisioned;
    	for (int i = 0; i < ARRAY_SIZE(certs); i++) {
    		err = modem_key_mgmt_exists(
    			certs[i].tag, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &provisioned);
    		if (err) {
    			goto cert_exit_empty;
    		if (provisioned) {
    			err = modem_key_mgmt_cmp(
    				certs[i].data, strlen(certs[i].data));
    			/* 0 on match, 1 otherwise; like memcmp() */
    			mismatch = err;
    			LOG_DBG("Certificate found, tag %d: %s", certs[i].tag,
    				mismatch ? "mismatch" : "match");
    		} else {
    			LOG_DBG("Certificate tag %d not found", certs[i].tag);
    		if (mismatch || !provisioned) {
    			/* overwrite the certificate */
    			err = modem_key_mgmt_write(
    			if (err) {
    				LOG_ERR("Unable to provision certificate, error: %d", err);
    			LOG_DBG("Certificate provisioned, tag %d", certs[i].tag);
    	return 0;
    cert_exit_empty:
    	return -1;
    It has written by some other developer. I commented that code, i still getting the problem
    we have increased flash memory to 8Mbytes does it affecting?
    Best Reagrds
    Praveen Deshmane
    I am not sure how changing only the spi memory overlay shall give you this sort of behavior.
    Are you certain that you have updated the modem firmware on the new device?
    All the return codes indicate that the modem fw isn't fully initialized, while the SPI flash seems to be detected as expected.
    Håkon
  • Hello Hakon,
    I figured out myself and solved this problem yesterday itself. It was modem firmware update problem.
    Thank you for reply too. I really appreciate it.
    Regards
    Praveen Deshmane
  • Hi Praveen,
    I am glad to hear that you found the root cause.
    Hope you have a wonderful day!
    Cheers,
    Håkon
