I'm working on implementing the buttonless DFU feature in my application. For now, I'm following this nrf52-ota-dfu-ble-part-4 and nRF52832-buttonless-dfu-development-tutorial. I implemented the DFU on a Blinky application, just to test it and to understand how it would work, but even following the NovelBits tutorial I'm getting the following error:
<error> app: No bootloader was found
<error> app: ERROR 4 [NRF_ERROR_NO_MEM] at C:\Nordic_SDK\nRF5_SDK_17.0.2_d674dde2\examples\ble_peripheral\ble_app_blinky132v1\main.c:684
PC at: 0x0002EB19
<error> app: End of error report
The error on line 684 refers to:
err_code = ble_dfu_buttonless_async_svci_init();
It only seemed to work when I flashed my application after flashing sd_s132_bootloader_buttonless_with_setting_page_dfu_secure_ble_debug_without_bonds.hex
This is how the memory layout on sd_s132_bootloader_buttonless_with_setting_page_dfu_secure_ble_debug_without_bonds.hex looks like.
And this is how my application's memory layout looks like.
Any thoughts on how I should proceed?
Thanks in advance.
7271.bl_settings.hex2313.application.hex04025.bootloader.hex3036.softdevice.hex
/** * Copyright (c) 2015 - 2021, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /** * @brief Blinky Sample Application main file. * * This file contains the source code for a sample server application using the LED Button service. */ #include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "app_error.h" #include "ble.h" #include "ble_err.h" #include "ble_hci.h" #include "ble_srv_common.h" #include "ble_advdata.h" #include "ble_conn_params.h" #include "nrf_sdh.h" #include "nrf_sdh_ble.h" #include "boards.h" #include "app_timer.h" #include "app_button.h" #include "ble_lbs.h" #include "nrf_ble_gatt.h" #include "nrf_ble_qwr.h" #include "nrf_pwr_mgmt.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" // DFU-related #includes #include "nrf_power.h" #include "nrf_dfu_ble_svci_bond_sharing.h" #include "nrf_svci_async_function.h" #include "nrf_svci_async_handler.h" #include "ble_dfu.h" #include "nrf_bootloader_info.h" #define ADVERTISING_LED BSP_BOARD_LED_0 /**< Is on when device is advertising. */ #define CONNECTED_LED BSP_BOARD_LED_1 /**< Is on when device has connected. */ #define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to be toggled with the help of the LED Button Service. */ #define LEDBUTTON_BUTTON BSP_BUTTON_0 /**< Button that will trigger the notification event with the LED Button Service */ #define DEVICE_NAME "Blinky_DFU" /**< Name of device. Will be included in the advertising data. */ #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */ #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */ #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */ #define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */ #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */ #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */ #define SLAVE_LATENCY 0 /**< Slave latency. */ #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */ #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ #define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */ #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */ BLE_LBS_DEF(m_lbs); /**< LED Button Service instance. */ NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */ NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/ static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */ static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */ static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */ /**@brief Struct that contains pointers to the encoded advertising data. */ static ble_gap_adv_data_t m_adv_data = { .adv_data = { .p_data = m_enc_advdata, .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX }, .scan_rsp_data = { .p_data = m_enc_scan_response_data, .len = BLE_GAP_ADV_SET_DATA_SIZE_MAX } }; /**@brief Function for assert macro callback. * * @details This function will be called in case of an assert in the SoftDevice. * * @warning This handler is an example only and does not fit a final product. You need to analyze * how your product is supposed to react in case of Assert. * @warning On assert from the SoftDevice, the system can only recover on reset. * * @param[in] line_num Line number of the failing ASSERT call. * @param[in] p_file_name File name of the failing ASSERT call. */ void assert_nrf_callback(uint16_t line_num, const uint8_t * p_file_name) { app_error_handler(DEAD_BEEF, line_num, p_file_name); } /**@brief Function for the LEDs initialization. * * @details Initializes all LEDs used by the application. */ static void leds_init(void) { bsp_board_init(BSP_INIT_LEDS); } /**@brief Handler for shutdown preparation. * * @details During shutdown procedures, this function will be called at a 1 second interval * untill the function returns true. When the function returns true, it means that the * app is ready to reset to DFU mode. * * @param[in] event Power manager event. * * @retval True if shutdown is allowed by this power manager handler, otherwise false. */ //--------------------DFU ------------------------------------------------------------------------------------ static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event) { switch (event) { case NRF_PWR_MGMT_EVT_PREPARE_DFU: NRF_LOG_INFO("Power management wants to reset to DFU mode."); // YOUR_JOB: Get ready to reset into DFU mode // // If you aren't finished with any ongoing tasks, return "false" to // signal to the system that reset is impossible at this stage. // // Here is an example using a variable to delay resetting the device. // // if (!m_ready_for_reset) // { // return false; // } // else //{ // // // Device ready to enter // uint32_t err_code; // err_code = sd_softdevice_disable(); // APP_ERROR_CHECK(err_code); // err_code = app_timer_stop_all(); // APP_ERROR_CHECK(err_code); //} break; default: // YOUR_JOB: Implement any of the other events available from the power management module: // -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF // -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP // -NRF_PWR_MGMT_EVT_PREPARE_RESET return true; } NRF_LOG_INFO("Power management allowed to reset to DFU mode."); return true; } /**@brief Register application shutdown handler with priority 0. */ NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0); static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context) { if (state == NRF_SDH_EVT_STATE_DISABLED) { // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot. nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC); //Go to system off. nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF); } } /* nrf_sdh state observer. */ NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) = { .handler = buttonless_dfu_sdh_state_observer, }; static void ble_dfu_buttonless_evt_handler(ble_dfu_buttonless_evt_type_t event) { ret_code_t err_code; switch (event) { case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE: NRF_LOG_INFO("Device is preparing to enter bootloader mode\r\n"); break; case BLE_DFU_EVT_BOOTLOADER_ENTER: NRF_LOG_INFO("Device will enter bootloader mode\r\n"); break; case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED: NRF_LOG_ERROR("Device failed to enter bootloader mode\r\n"); break; default: NRF_LOG_INFO("Unknown event from ble_dfu.\r\n"); break; } } //-------------------------------------------------------------------------------------------------------------------- /**@brief Function for the Timer initialization. * * @details Initializes the timer module. */ static void timers_init(void) { // Initialize timer module, making it use the scheduler ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for the GAP initialization. * * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the * device including the device name, appearance, and the preferred connection parameters. */ static void gap_params_init(void) { ret_code_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL; gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL; gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the GATT module. */ static void gatt_init(void) { ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the Advertising functionality. * * @details Encodes the required advertising data and passes it to the stack. * Also builds a structure to be passed to the stack when starting advertising. */ static void advertising_init(void) { ret_code_t err_code; ble_advdata_t advdata; ble_advdata_t srdata; ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}}; // Build and set advertising data. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_FULL_NAME; advdata.include_appearance = true; advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; memset(&srdata, 0, sizeof(srdata)); srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]); srdata.uuids_complete.p_uuids = adv_uuids; err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len); APP_ERROR_CHECK(err_code); err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len); APP_ERROR_CHECK(err_code); ble_gap_adv_params_t adv_params; // Set advertising parameters. memset(&adv_params, 0, sizeof(adv_params)); adv_params.primary_phy = BLE_GAP_PHY_1MBPS; adv_params.duration = APP_ADV_DURATION; adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; adv_params.p_peer_addr = NULL; adv_params.filter_policy = BLE_GAP_ADV_FP_ANY; adv_params.interval = APP_ADV_INTERVAL; err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params); APP_ERROR_CHECK(err_code); } /**@brief Function for handling Queued Write Module errors. * * @details A pointer to this function will be passed to each service which may need to inform the * application about an error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for handling write events to the LED characteristic. * * @param[in] p_lbs Instance of LED Button Service to which the write applies. * @param[in] led_state Written/desired state of the LED. */ static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state) { if (led_state) { bsp_board_led_on(LEDBUTTON_LED); NRF_LOG_INFO("Received LED ON!"); } else { bsp_board_led_off(LEDBUTTON_LED); NRF_LOG_INFO("Received LED OFF!"); } } /**@brief Function for initializing services that will be used by the application. */ static void services_init(void) { ret_code_t err_code; ble_lbs_init_t init = {0}; nrf_ble_qwr_init_t qwr_init = {0}; // Initialize Queued Write Module. qwr_init.error_handler = nrf_qwr_error_handler; err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); APP_ERROR_CHECK(err_code); // Initialize LBS. init.led_write_handler = led_write_handler; err_code = ble_lbs_init(&m_lbs, &init); APP_ERROR_CHECK(err_code); // Initialize the DFU service ble_dfu_buttonless_init_t dfus_init = { .evt_handler = ble_dfu_buttonless_evt_handler }; err_code = ble_dfu_buttonless_init(&dfus_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module that * are passed to the application. * * @note All this function does is to disconnect. This could have been done by simply * setting the disconnect_on_fail config parameter, but instead we use the event * handler mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { ret_code_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } } /**@brief Function for handling a Connection Parameters error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static void conn_params_init(void) { ret_code_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for starting advertising. */ static void advertising_start(void) { ret_code_t err_code; err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG); APP_ERROR_CHECK(err_code); bsp_board_led_on(ADVERTISING_LED); } /**@brief Function for handling BLE events. * * @param[in] p_ble_evt Bluetooth stack event. * @param[in] p_context Unused. */ static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context) { ret_code_t err_code; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_CONNECTED: NRF_LOG_INFO("Connected"); bsp_board_led_on(CONNECTED_LED); bsp_board_led_off(ADVERTISING_LED); m_conn_handle = p_ble_evt->evt.gap_evt.conn_handle; err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_conn_handle); APP_ERROR_CHECK(err_code); err_code = app_button_enable(); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_DISCONNECTED: NRF_LOG_INFO("Disconnected"); bsp_board_led_off(CONNECTED_LED); m_conn_handle = BLE_CONN_HANDLE_INVALID; err_code = app_button_disable(); APP_ERROR_CHECK(err_code); advertising_start(); break; case BLE_GAP_EVT_SEC_PARAMS_REQUEST: // Pairing not supported err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL); APP_ERROR_CHECK(err_code); break; case BLE_GAP_EVT_PHY_UPDATE_REQUEST: { NRF_LOG_DEBUG("PHY update request."); ble_gap_phys_t const phys = { .rx_phys = BLE_GAP_PHY_AUTO, .tx_phys = BLE_GAP_PHY_AUTO, }; err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys); APP_ERROR_CHECK(err_code); } break; case BLE_GATTS_EVT_SYS_ATTR_MISSING: // No system attributes have been stored. err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0); APP_ERROR_CHECK(err_code); break; case BLE_GATTC_EVT_TIMEOUT: // Disconnect on GATT Client timeout event. NRF_LOG_DEBUG("GATT Client Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; case BLE_GATTS_EVT_TIMEOUT: // Disconnect on GATT Server timeout event. NRF_LOG_DEBUG("GATT Server Timeout."); err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); APP_ERROR_CHECK(err_code); break; default: // No implementation needed. break; } } /**@brief Function for initializing the BLE stack. * * @details Initializes the SoftDevice and the BLE event interrupt. */ static void ble_stack_init(void) { ret_code_t err_code; err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); // Configure the BLE stack using the default settings. // Fetch the start address of the application RAM. uint32_t ram_start = 0; err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start); APP_ERROR_CHECK(err_code); // Enable BLE stack. err_code = nrf_sdh_ble_enable(&ram_start); APP_ERROR_CHECK(err_code); // Register a handler for BLE events. NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL); } /**@brief Function for handling events from the button handler module. * * @param[in] pin_no The pin that the event applies to. * @param[in] button_action The button action (press/release). */ static void button_event_handler(uint8_t pin_no, uint8_t button_action) { ret_code_t err_code; switch (pin_no) { case LEDBUTTON_BUTTON: NRF_LOG_INFO("Send button state change."); err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action); if (err_code != NRF_SUCCESS && err_code != BLE_ERROR_INVALID_CONN_HANDLE && err_code != NRF_ERROR_INVALID_STATE && err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING) { APP_ERROR_CHECK(err_code); } break; default: APP_ERROR_HANDLER(pin_no); break; } } /**@brief Function for initializing the button handler module. */ static void buttons_init(void) { ret_code_t err_code; //The array must be static because a pointer to it will be saved in the button handler module. static app_button_cfg_t buttons[] = { {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler} }; err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY); APP_ERROR_CHECK(err_code); } static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); NRF_LOG_DEFAULT_BACKENDS_INIT(); } /**@brief Function for initializing power management. */ static void power_management_init(void) { ret_code_t err_code; err_code = nrf_pwr_mgmt_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for handling the idle state (main loop). * * @details If there is no pending log operation, then sleep until next the next event occurs. */ static void idle_state_handle(void) { if (NRF_LOG_PROCESS() == false) { nrf_pwr_mgmt_run(); } } /**@brief Function for application main entry. */ int main(void) { ret_code_t err_code; // Initialize. log_init(); // Initialize the async SVCI interface to bootloader before any interrupts are enabled. err_code = ble_dfu_buttonless_async_svci_init(); APP_ERROR_CHECK(err_code); leds_init(); timers_init(); buttons_init(); power_management_init(); ble_stack_init(); gap_params_init(); gatt_init(); services_init(); advertising_init(); conn_params_init(); // Start execution. NRF_LOG_INFO("Blinky example started."); advertising_start(); // Enter main loop. for (;;) { idle_state_handle(); } } /** * @} */
