ble_hts_is_indication_enabled always false on re-connection
I'm developing a peripheral that expose the HTS service. I have the on_hts_evt event handler to handle BLE_HTS_EVT_INDICATION_ENABLED and BLE_HTS_EVT_INDICATION_DISABLED to start and stop a timer that sends temperature value. Suppose I enable indication from central side (a smartphone) ... it works great ... the indication is enabled and the temperature value is received (on the central). Suppose I disconnect from peripheral without disabling indication first. When I reconnect, handling the DM_EVT_LINK_SECURED event in the device_manager_evt_handler event handler, I use the ble_hts_is_indication_enabled to check if indication is enabled (I get the code from ble_app_hts example). However, the above function returns always false even if as I said I disconnected from peripheral without disabling the indication.
Why ?
Thanks, Paolo.
