nRF9160dk FOTA using external flash, ncs 2.0.2
I am using nRf9160dk with mcuboot secondary image on external flash base on AZURE_FOTA example, ncs 2.0.2.
Found the bootloader cannot runs primary image.
So, I need advice on how to set up the mcuboot secondary with SPI flash.
*** Booting Zephyr OS build v3.0.99-ncs1-1  ***
I: Starting bootloader
W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=128 - too small?
E: Image in the primary slot is not valid!
E: Unable to find bootable image
Checked the partition with west build -t partition_manager_report .
| 0x0: external_flash (0x800000 - 8192kB)  |
| 0x0: mcuboot_secondary (0x70000 - 448kB) |
  flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB)                     |
| 0xc000: EMPTY_0 (0x4000 - 16kB)                  |
+---0x10000: mcuboot_primary (0xe8000 - 928kB)-----+
+---0x10000: tfm_secure (0xc200 - 48kB)------------+
| 0x10000: mcuboot_pad (0x200 - 512B)              |
+---0x10200: mcuboot_primary_app (0xe7e00 - 927kB)-+
| 0x10200: tfm (0xc000 - 48kB)                     |
+---0x1c200: tfm_nonsecure (0xdbe00 - 879kB)-------+
| 0x1c200: app (0xdbe00 - 879kB)                   |
+---0xf8000: nonsecure_storage (0x8000 - 32kB)-----+
| 0xf8000: settings_storage (0x2000 - 8kB)         |
| 0xfa000: littlefs_storage (0x6000 - 24kB)        |
  otp (0x2f4 - 756B):
| 0xff8108: otp (0x2f4 - 756B) |
  sram_primary (0x40000 - 256kB):
+---0x20000000: sram_secure (0x10000 - 64kB)-------+
| 0x20000000: tfm_sram (0x10000 - 64kB)            |
+---0x20010000: sram_nonsecure (0x30000 - 192kB)---+
+---0x20010000: nrf_modem_lib_sram (0x44e8 - 17kB)-+
| 0x20010000: nrf_modem_lib_ctrl (0x4e8 - 1kB)     |
| 0x200104e8: nrf_modem_lib_tx (0x2000 - 8kB)      |
| 0x200124e8: nrf_modem_lib_rx (0x2000 - 8kB)      |
| 0x200144e8: sram_primary (0x2bb18 - 174kB)       |
My configuration as follows:
child_image\mcuboot\boards\nrf9160dk_nrf9160_mcuboot.overlay
	chosen {
		nordic,pm-ext-flash = &mx25r64;
&spi3 {
	status = "okay";
	pinctrl-0 = <&spi3_default_alt>;
	pinctrl-1 = <&spi3_sleep_alt>;
	cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
	mx25r64: mx25r6435f@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <80000000>;
		label = "MX25R64";
		jedec-id = [c2 28 17];
		size = <67108864>;
&pinctrl {
	spi3_default_alt: spi3_default_alt {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 13)>,
				<NRF_PSEL(SPIM_MOSI, 0, 11)>,
				<NRF_PSEL(SPIM_MISO, 0, 12)>;
	spi3_sleep_alt: spi3_sleep_alt {
		group1 {
			low-power-enable;
child_image\mcuboot\prj_mcuboot.conf
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_MULTITHREADING=y
# MCUboot requires a large stack size, otherwise an MPU fault will occur
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_DEBUG_OPTIMIZATIONS=y
# Enable flash operations
CONFIG_FLASH=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
nrf9160dk_nrf9160_ns.overlay
    	chosen {
&spi3 {
	status = "okay";
		reg = <0>;
		label = "MX25R64";
		size = <67108864>;
&pinctrl {
		group1 {
		group1 {
			low-power-enable;
pm_static.yml
#include <autoconf.h>
#include <devicetree_legacy_unfixed.h>
external_flash:
  address: 0x0
  device: mx25r6435f
  region: external_flash
mcuboot_secondary:
  address: 0x0
  device: mx25r6435f
prj.conf
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
CONFIG_REBOOT=y
# Log
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M=n
CONFIG_LTE_NETWORK_MODE_NBIOT=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_KEEPALIVE=900
# Azure IoT Hub library
CONFIG_AZURE_IOT_HUB=y
CONFIG_AZURE_IOT_HUB_DEVICE_ID="nordic_960074368"
# Host name must be configured if DPS is not used
CONFIG_AZURE_IOT_HUB_HOSTNAME=""
# Change the security tag to the tag where relevant certificates are provisioned
CONFIG_AZURE_IOT_HUB_SEC_TAG=11
# Uncomment to get more verbose logging when debugging
# CONFIG_AZURE_IOT_HUB_LOG_LEVEL_DBG=y
# Uncomment and configure the options below to use DPS for device provisioning
CONFIG_AZURE_IOT_HUB_DPS=y
CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="0ne0053A4FD"
# Azure FOTA
CONFIG_CJSON_LIB=y
CONFIG_AZURE_FOTA=y
CONFIG_AZURE_FOTA_APP_VERSION_AUTO=n
CONFIG_AZURE_FOTA_APP_VERSION="v0.0.1"
CONFIG_AZURE_FOTA_TLS=y
# Change the security tag to the tag where the certificates are provisioned
# for the server where the FOTA image is hosted
CONFIG_AZURE_FOTA_SEC_TAG=10
# Uncomment the below line to get more debug logging
# CONFIG_AZURE_FOTA_LOG_LEVEL_DBG=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=6144
CONFIG_MAIN_STACK_SIZE=1536
# Settings, needed for Azure Device Provisioning Service
CONFIG_FLASH=y
CONFIG_FCB=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
# Modem library
CONFIG_NRF_MODEM_LIB=y
# newlibc
CONFIG_NEWLIB_LIBC=y
# FOTA Download
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
CONFIG_AZURE_FOTA_FILE_PATH_MAX_LEN=200
# Download Client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_INF=y
CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300
# DFU Target
CONFIG_DFU_TARGET=y
# Application update support
CONFIG_BOOTLOADER_MCUBOOT=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# Config using external flash memory and littleFS.
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=32
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
# Need this when storage is on flash
# CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    Yes, this issue was resolved with this PR:
    https://github.com/nrfconnect/sdk-nrf/pull/8363
    It is present in ncs v2.1.0.
    Rung said:
    If so, could you describe how to use it?
    Based on your previously used project, you take away the SPM config:
    CONFIG_BUILD_WITH_TFM=y
    # CONFIG_SPM=n
    Could you try this and see if this works as expected?
    Håkon
  • Hi   I'm having a similar problem, for the last couple of weeks.
    NCS 2.1.0
    I'm using the HTTP application update, and it works OK when using FOTA and internal flash however it doesn't work when using external flash.
    I get an error
    Failed reading sectors; BOOT_MAX_IMG_SECTORS=256 - too small?
    Cannot upgrade: not a compatible amount of sectors
    [00:00:00.*** Booting Zephyr OS build v3.1.99-ncs1 ***
    HTTP application update sample started
    Using version 1
    [00:00:00.368,041] <dbg> os: k_sched_unlock: scheduler unlocked (0x2000cce0:0)
    [00:00:05.556,610] <inf> mcuboot: Starting bootloader
    [00:00:05.556,640] <dbg> os: setup_thread_stack: stack 0x2000ebb8 for thread 0x2000c708: obj_size=768 buf_start=0x2000c97d  buf_size 768 stack_ptr=0x2000c97f
    [00:00:05.556,915] <wrn> mcuboot: Failed reading sectors; BOOT_MAX_IMG_SECTORS=256 - too small?
    [00:00:05.556,945] <wrn> mcuboot: Cannot upgrade: not a compatible amount of sectors
    Using version 1
      external_flash (0x400000 - 4096kB):
    | 0x0: mcuboot_secondary (0xf0000 - 960kB)    |
    | 0xf0000: external_flash (0x310000 - 3136kB) |
    | 0x0: mcuboot (0x10000 - 64kB)                    |
    +---0x10000: mcuboot_primary (0xf0000 - 960kB)-----+
    +---0x10200: mcuboot_primary_app (0xefe00 - 959kB)-+
    +---0x1c200: tfm_nonsecure (0xe3e00 - 911kB)-------+
    | 0x1c200: app (0xe3e00 - 911kB)                   |
      otp (0x2f4 - 756B):
    +---0x20000000: sram_secure (0x8000 - 32kB)--------+
    | 0x20000000: tfm_sram (0x8000 - 32kB)             |
    +---0x20008000: sram_nonsecure (0x38000 - 224kB)---+
    +---0x20008000: nrf_modem_lib_sram (0x44e8 - 17kB)-+
    | 0x20008000: nrf_modem_lib_ctrl (0x4e8 - 1kB)     |
    | 0x200084e8: nrf_modem_lib_tx (0x2000 - 8kB)      |
    | 0x2000a4e8: nrf_modem_lib_rx (0x2000 - 8kB)      |
    | 0x2000c4e8: sram_primary (0x33b18 - 206kB)       |
    prj.conf
    # Copyright (c) 2019 Nordic Semiconductor ASA
    # General config
    CONFIG_NCS_SAMPLES_DEFAULTS=y
    CONFIG_REBOOT=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_NATIVE=n
    # LTE link control
    # Modem library
    CONFIG_NRF_MODEM_LIB_SYS_INIT=n
    # Shell configurations
    CONFIG_SHELL=y
    CONFIG_SHELL_WILDCARD=n
    CONFIG_SHELL_CMD_BUFF_SIZE=128
    # Library for buttons and LEDs
    CONFIG_DK_LIBRARY=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    CONFIG_MAIN_STACK_SIZE=8192
    # Image manager
    CONFIG_FLASH=y
    # GPIO
    CONFIG_GPIO=y
    # FOTA library
    # Download client
    # DFU Target
    CONFIG_DFU_TARGET=y
    # Modem key management
    CONFIG_MODEM_KEY_MGMT=y
    # Application Upgrade support
    # Sample configuration
    CONFIG_DOWNLOAD_HOST="nrfconnectsdk.s3.eu-central-1.amazonaws.com"
    CONFIG_DOWNLOAD_FILE_V2="app_update.bin"
    CONFIG_DOWNLOAD_FILE_V1="app_downgrade.bin"
    CONFIG_APPLICATION_VERSION=1
    CONFIG_NRFX_SPIM3=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR=n
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_STREAM_FLASH=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_STREAM_FLASH_LOG_LEVEL_DBG=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    CONFIG_IMG_MANAGER_LOG_LEVEL_DBG=y
    #turn off compiler optimisations so we can debug it
    #CONFIG_NO_OPTIMIZATIONS=y
    circuitdojo_feather_nrf9160_ns.overlay
    // To get started, press Ctrl+Space to bring up the completion menu and view the available nodes.
    // You can also use the buttons in the sidebar to perform actions on nodes.
    // Actions currently available include:
    // * Enabling / disabling the node
    // * Adding the bus to a bus
    // * Removing the node
    // * Connecting ADC channels
    // For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
    // You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
    	chosen {
    		nordic,pm-ext-flash = &is25lp032d;
    	aliases {
    		spi-flash0 = &is25lp032d;
            led0 = &blue_led;
            led1 = &blue_led;
        leds {
            compatible = "gpio-leds";
            blue_led: led_0 {
                gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
                label = "Blue LED (D7)";
    &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    &spi3 {
    	status = "okay";
    	/delete-node/ w25q32jv@0;
    	cs-gpios = < &gpio0 7 GPIO_ACTIVE_LOW >;
    	is25lp032d: is25lp032d@0 {
    		label = "IS25LP032D";
    		reg = < 0 >;
    		spi-max-frequency = < 40000000 >;
    		wp-gpios = < &gpio0 8 GPIO_ACTIVE_LOW >;
    		hold-gpios = < &gpio0 10 GPIO_ACTIVE_LOW >;
    		size = < 0x2000000 >;
    		has-dpd;
    		t-enter-dpd = < 3000 >;
    		t-exit-dpd = < 30000 >;
    		jedec-id = [ 9d 60 16  ];
    child_image/mcuboot.conf
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_NRFX_SPIM3=y
    CONFIG_FLASH=y
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    # Size of mcuboot partition
    CONFIG_SIZE_OPTIMIZATIONS=y
    CONFIG_MCUBOOT_SERIAL=n #make sure this is set to n if you want to log stuff.
    CONFIG_LOG_MODE_MINIMAL=n
    CONFIG_LOG_OVERRIDE_LEVEL=4
    CONFIG_UART_CONSOLE=y
    CONFIG_CONSOLE=y
    CONFIG_BOOT_ERASE_PROGRESSIVELY=y
    #CONFIG_MCUBOOT_OVERWRITE_ONLY=y
    child_image/mcuboot/boards/circuitdojo_feather_nrf9160.overlay
     * Copyright (c) 2021 Nordic Semiconductor ASA
     //MKB added this entire file in the child image directory to try and enable external flash as
     //the second slot, so that we can get more primary flash for a larger application.
     //https://devzone.nordicsemi.com/f/nordic-q-a/91180/nrf9160dk-fota-using-external-flash-ncs-2-0-2
     //note that the file name is thingy91_nrf9160.overlay (no "ns" in the file name) as mcuboot runs secure.
    	chosen {
    	aliases {
    &uart0 {
    	status = "okay";
    &spi3 {
    	status = "okay";
    		reg = < 0 >;
    		has-dpd;
    the image is loading into external flash
    uart:~$ mcuboot
    swap type: test
    confirmed: 0
    primary area (3):
      version: 0.0.0+0
      image size: 192552
      magic: unset
      swap type: none
      copy done: unset
      image ok: unset
    secondary area (1):
      version: 0.0.0+0
      image size: 192432
      magic: good
      swap type: test
      copy done: unset
      image ok: unset
    uart:~$ [00:00:35.131,164] <inf> mcuboot_util: Swap type: test
    shell read of flash - not sure if this is a valid result, but it looks promising.
    uart:~$ flash read IS25LP032D 0 0x1000
    00000000: 3d b8 f3 96 00 00 00 00  00 02 00 00 b0 ef 02 00 |=....... ........|
    00000010: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00 |........ ........|
    00000020: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000030: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000040: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000050: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000060: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000070: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000080: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000090: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000A0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000B0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000C0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000D0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000E0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000000F0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000100: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000110: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000120: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000130: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000140: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000150: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000160: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000170: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000180: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000190: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001A0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001B0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001C0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001D0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001E0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    000001F0: ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff |........ ........|
    00000200: 00 0c 00 20 45 03 01 00  c7 03 01 00 61 12 01 00 |... E... ....a...|
    00000210: 6b 12 01 00 75 12 01 00  89 12 01 00 7f 12 01 00 |k...u... ........|
    00000220: 00 00 00 00 00 00 00 00  00 00 00 00 95 20 01 00 |........ ..... ..|
    00000230: e3 03 01 00 00 00 00 00  59 20 01 00 eb 03 01 00 |........ Y ......|
    00000240: 00 00 00 00 00 00 00 00  00 00 00 00 ef 03 01 00 |........ ........|
    00000250: 00 00 00 00 f3 03 01 00  00 00 00 00 00 00 00 00 |........ ........|
    00000260: f7 03 01 00 fb 03 01 00  ff 03 01 00 03 04 01 00 |........ ........|
    00000270: 00 00 00 00 07 04 01 00  0b 04 01 00 0f 04 01 00 |........ ........|
    00000280: 13 04 01 00 17 04 01 00  00 00 00 00 00 00 00 00 |........ ........|
    00000290: 1b 04 01 00 1f 04 01 00  00 00 00 00 00 00 00 00 |........ ........|
    000002A0: 23 04 01 00 00 00 00 00  00 00 00 00 27 04 01 00 |#....... ....'...|
    I'd really appreciate a bit of help its driving me nuts.
    This is me as well.....
    https://devzone.nordicsemi.com/f/nordic-q-a/93387/fota-to-external-flash
    Thanks
    Marshall
  • Hi  and
    My deepest apologies for the inconvenience.
    Unfortunately, there is another breaking change in NCS v2.1.0, that blocks for using SPI based flash ("spi_nor") in mcuboot.
    You will need in total 2 changes:
    1. in your child_image/mcuboot.conf, you will need to add this symbol when using SPI and flash:
    2. In addition, there is a bug with the flash_device that mcuboot picks up through the "partition manager" script system.
    This line in ncs_v2.1.0/nrf/cmake/partition_manager.cmake:
    https://github.com/nrfconnect/sdk-nrf/blob/v2.1.2/cmake/partition_manager.cmake#L215
    Shall be changed to:
        DEVICE "DT_CHOSEN(nordic_pm_ext_flash)"
    The second point is handled in this PR, but due to release-note changes as well, it is not easy to cherry pick directly:
    https://github.com/nrfconnect/sdk-nrf/pull/9169
    Could you try these two steps and report back if this helps the scenario?
    Håkon
  • Oh my goodness..... IT WORKS
    Thanks so much for the support.
    Regards
    Marshall
  • Hi Marshall,
    I'm glad to hear that it is working at your end now.
    I'll pursue this issue internally, and make sure it is handled.
    Håkon
