Customers have reported the problem of dfu upgrade failure, and we also use the same type of mobile phone (iPhone 11 & iPhone XR) for testing. It is found that there is indeed a problem of upgrade failure, but this failure is random and does not happen often. And, once there is an upgrade failure, it will keep appearing. At least for a while, the upgrade was unsuccessful. The current software uses sdk 17.1 and flash_s140_nrf52_7.3.0_softdevice.
Some logs on failure:
Parts: 1 Size: 303 KB Soft Device Size: Zero KB Bootloader Size: Zero KB Connecting to Bt_test Connected to Bt_test Discovering services... Services discovered Starting Secure DFU... Connected to Bt_test Services discovered Secure DFU Service found Discovering characteristics in DFU Service... DFU characteristics discovered Enabling indications for 8EC90003-F315-4F60-9FB8-838830DAEA50... Indications enabled for 8EC90003-F315-4F60-9FB8-838830DAEA50 Buttonless DFU indications enabled Application with buttonless update found Trying setting bootloader name to Dfu10658 Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50... Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50 Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200204 Error 4: Operation failed Disconnecting... Disconnected
Some logs when the upgrade is successful:
Parts: 1 Size: 303 KB Soft Device Size: Zero KB Bootloader Size: Zero KB Connecting to Bt_test Connected to Bt_test Discovering services... Services discovered Starting Secure DFU... Connected to Bt_test Services discovered Secure DFU Service found Discovering characteristics in DFU Service... DFU characteristics discovered Enabling indications for 8EC90003-F315-4F60-9FB8-838830DAEA50... Indications enabled for 8EC90003-F315-4F60-9FB8-838830DAEA50 Buttonless DFU indications enabled Application with buttonless update found Trying setting bootloader name to Dfu33136 Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50... Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50 Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200201 Response (Op Code = Set Name, Status = Success) received Bootloader name changed successfully Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50... Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50 Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200101 Response (Op Code = Enter Bootloader, Status = Success) received Disconnected. Disconnected by the remote device Scanning for the DFU Bootloader... DFU Bootloader found with name Dfu33136 Connecting to Dfu36593... Connected to Dfu36593 Discovering services... Services discovered Secure DFU Service found Discovering characteristics in DFU Service... DFU characteristics discovered MTU set to 247 Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50... Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
This seems to be a probabilistic problem, how can I fix it?
thanks.
