dfu upgrade failed
Customers have reported the problem of dfu upgrade failure, and we also use the same type of mobile phone (iPhone 11 & iPhone XR) for testing. It is found that there is indeed a problem of upgrade failure, but this failure is random and does not happen often. And, once there is an upgrade failure, it will keep appearing. At least for a while, the upgrade was unsuccessful. The current software uses sdk 17.1 and flash_s140_nrf52_7.3.0_softdevice.
Some logs on failure:
Parts: 1
Soft Device Size: Zero KB
Bootloader Size: Zero KB
Connecting to Bt_test
Connected to Bt_test
Discovering services...
Services discovered
Starting Secure DFU...
Services discovered
Secure DFU Service found
Discovering characteristics in DFU Service...
DFU characteristics discovered
Enabling indications for 8EC90003-F315-4F60-9FB8-838830DAEA50...
Indications enabled for 8EC90003-F315-4F60-9FB8-838830DAEA50
Buttonless DFU indications enabled
Application with buttonless update found
Trying setting bootloader name to Dfu10658
Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50...
Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50
Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200204
Error 4: Operation failed
Disconnecting...
Disconnected
Some logs when the upgrade is successful:
Parts: 1
Services discovered
Services discovered
Trying setting bootloader name to Dfu33136
Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200201
Response (Op Code = Set Name, Status = Success) received
Bootloader name changed successfully
Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200101
Response (Op Code = Enter Bootloader, Status = Success) received
Disconnected.
Disconnected by the remote device
Scanning for the DFU Bootloader...
DFU Bootloader found with name Dfu33136
Connecting to Dfu36593...
Connected to Dfu36593
Services discovered
MTU set to 247
Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50...
Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
This seems to be a probabilistic problem, how can I fix it?
thanks.
  • Hi
    Is this reproducible with the buttonless_DFU example project in SDK 17.1.0 or has the customer made any changes to it to trig these errors?
    The error you're seeing indicates that the bootloader failed to store the new advertisement name to flash, possibly due to a flash timeout.
    A flash timeout means that the SoftDevicewas unable  to schedule a flash operation which was successfully requested by the application/bootloader. This should not happen unless there is a lot of BLE activity in parallel with the flash writes. Please have a look at table 1 in the Flash memory API chapter and see if your application meets any of the criteria for low to medium probability of success.
    Simon
    This is some current configuration and I don't know how to analyze it.
    #define APP_ADV_INTERVAL                874
    #define APP_ADV_DURATION                0//18000
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(30, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)
    #define SLAVE_LATENCY                   0
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)
    The broadcast channel has not been modified, and the data channel is currently set to BLE_GAP_PHY_AUTO.
  • Okay, your advertising parameters look good, just the APP_ADV_INTERVAL being set to 874 seems a little off, although it shouldn't cause any issues. Any specific reason it is set to 874?
    If it's not too hard to reproduce, it would be great if we could confirm whether this was a flash timeout or not. You can place a breakpoint or blink a LED in  bootloader-> nrf_dfu_scvi_handler.c-> nrf_dfu_set_adv_name_on_sys_evt->NRF_EVT_FLASH_OPERATION_ERROR for example to verify this.
    Simon
  • According to the design parameters of ios, we choose 546.25ms, so 874*0.265 = 546.25ms. (I hope I am not wrong).
    Does the parameter "NRF_BLE_GATT_MTU_EXCHANGE_INITIATION_ENABLED" affect the upgrade?
