NRF52833 DCDC OUPUT CURRENT
WHAT IS THE MAXIMUM  OUTPUT CURRENT OF DCDC IN NRF52833 OUTPUT IN HIGH VOLTAGE AND NORMAL VOLTAGE MODE?
I AM POWERING UP TWO SENSORS WITH IT THAT USES CURRENT IN MICRO AMPS .
I AM NOT USING ANY EXTERNAL LDO FOR MY CIRCUIT I AM USING ONLY INTERNAL DCDC OF THE NRF52833 .
Parents Reply
  • To be precise, in High Voltage Mode, VDD will be equal to the output of REG0. The ouput of REG0 can be adjusted by writing to the REGOUT0 register in the UICR. If you set the output of REG0 to 2V4 then VDD will also be 2V4 and so will the GPIO high voltage.
    zuhaib said:
    i did not understand what do you mean by state of the regulator
    I was referring to the REG1 regulator.
    regards
    Jared
