How to get pairing/bonding to work in e.g. ble_app_uart
   Hello List,
First some context: I am working with SDK 17.1.0 on a nrf52840 (arduino nano ble).
Created a variant of the ble_app_uart example and want to add pairing/bonding with it. Started looking at ble_app_hrs to start.
Basically I added functions "peer_manager_init" and "pm_evt_handler" and some changes to "sdk_config.h", but now am stuck. Please see below for that code.
With this code it just works, but without pairing/bonding.
If I remove the "pm_conn_sec_params_reply" call from "pm_evt_handler" the smartphone pops up a window and asks whether there should be a pairing, which then fails as can be seen using the RTT-log:
<error> peer_manager_sm: Could not perform security procedure. smd_params_reply() or smd_link_secure() returned NRF_ERROR_INVALID_ADDR. conn_handle: 0
<error> peer_manager_handler: Unexpected fatal error occurred: error: NRF_ERROR_INVALID_ADDR
<error> peer_manager_handler: Asserting.
<error> app: Fatal error
One thing that is missing is setting the pin code in the program, how is that to be done?
Hopefully someone can help me in the right direction.
Thanks in advance, Sietse
Here the code snipped.
// peer_manager stuff in main.c
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      1                                       /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
	advertising_start();
      case  PM_EVT_CONN_SEC_SUCCEEDED:
	NRF_LOG_INFO("--> PM_EVT_CONN_SEC_SUCCEEDED");
      case  PM_EVT_CONN_SEC_PARAMS_REQ:
	NRF_LOG_INFO("--> PM_EVT_CONN_SEC_PARAMS_REQ");
	pm_conn_sec_params_reply(p_evt->conn_handle,
				 p_evt->params.conn_sec_params_req.p_peer_params,
				 p_evt->params.conn_sec_params_req.p_context);
	NRF_LOG_INFO("--> pm_evt_handler %d", p_evt->evt_id);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    ret_code_t           err_code;
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
  • forgot to mention that I had to remove -Werror from the CFLAGS in the Makefile. Otherwise I get the following error:
    ... commands.c:1005:39: warning: passing argument 2 of 'pm_conn_sec_params_reply' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
    1005 | p_evt->params.conn_sec_params_req.p_peer_params,
    In file included from ../../../main.c:61:
    /home/sietse/Radio/Software/Nordic/nRF5_SDK_17.1.0_ddde560/components/ble/peer_manager/peer_manager.h:220:60: note: expected 'ble_gap_sec_params_t *' but argument is of type 'const ble_gap_sec_params_t * const'
    220 | ble_gap_sec_params_t * p_sec_params,
  • Hi
    This error seems very strange, as the  smd_params_reply() or smd_link_secure() don't have NRF_ERROR_INVALID_ADDR as a return value, so the error message doesn't make much sense to me. Have you checked out the Peer Manager documentation and the Usage chapter that shows how to typically add the Peer Manager and thus pairing/bonding to an application?
    The project you're making is for a peripheral device, is that correct? What device are you trying to pair/bond to exactly? Another nRF device or a phone/computer?
    Simon
  • Thanks for the reply!
    I am indeed trying do make a periphiral (ble_periphiral/ble_app_uart) and connect to android or PC (Linux).
    I now created a version that ONLY added the (hopefully) relevant parts from ble_app_hrs to ble_app_uart_pair.
    For completeness here the code.
    ble_app_uart_pair.zip
    See the diff between main.c and main.c_org for the additions.
    There also are some differences in sdk_config.h and the Makefile of course.
    The Makefile_pca10056 is a version for use with BOARD_PCA10056.
    Now to my problem.
    I re-read the documentation about the peer manager and found one error I think.
    I mistakenly had "PM_CENTRAL_ENABLE 1" in sdk_config.h. Changed this to 0, but nothing changed.
    So, the app works fine (with android and PC), but there is no pairing at all!
    Here RTT log from a short session:
    <info> app: --> PM_EVT_CONN_SEC_PARAMS_REQ
    <debug> app: --> pm_conn_secure return: 0
    <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
    <info> app: Data len is set to 0xF4(244)
    <debug> app: ATT MTU exchange completed. central 0xF7 peripheral 0xF7
    <debug> nrf_ble_gatt: Data length updated to 251 on connection 0x0.
    <debug> nrf_ble_gatt: max_rx_octets: 251
    <debug> nrf_ble_gatt: max_tx_octets: 251
    <debug> nrf_ble_gatt: max_rx_time: 2120
    <debug> nrf_ble_gatt: max_tx_time: 2120
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 517 bytes.
    <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 247) on connection 0x0.
    <debug> app: Received data from BLE NUS. Writing data on UART.
    <debug> app: 66 20 67 20 66 |f g f
    <info> app: Disconnected
    Note that pm_conn_service is called but there is no PM_EVT_CONN_SEC_START event!
    But, if the pairing is initiated on linux, by doing a "bluetoothctl pair E7:05:43:10:93:D3" I get the following reaction:
    On linux:
    Attempting to pair with E7:05:43:10:93:D3
    [CHG] Device E7:05:43:10:93:D3 Connected: yes
    [CHG] Device E7:05:43:10:93:D3 Connected: no
    Failed to pair: org.bluez.Error.AuthenticationCanceled
    and via RTT from the target:
    <info> app: --> pm_evt_handler 2
    Note that "pm_evt_handler 2" is PM_EVT_CONN_SEC_START
    So now we get a little bit further.
    But, why the fatal error?
    Thanks again, Sietse
    PS. And if it had worked, where could I have set the required pincode on the target?
  • Hi again
    Is there a reason you are using ble_app_hrs as a template for adding pairing/bonding? That example project does neither, and I would recommend looking at ble_app_bms or ble_app_gls instead which actually do pairing/bonding.
    The "pm_evt_handler" with event ID 2 could be that it disconnects on a security failure perhaps.
    Simon
  • Hello again,
    I was using ble_app_hrs because somewhere I was pointed to it for pairing/bonding.
    I now tried _bms en _gls that both work.
    Then I tried to get the pair/bond stuff into my ble_app_uart_pair, here the new main.c,
    the only file that changed.
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
     With pairing/bonding from ble_app_gls.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    // added for peer manager
    #include "nrf_ble_lesc.h"
    #include "fds.h"
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_MITM                      1                                       /**< Man In The Middle protection required (applicable when display module is detected). */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_DISPLAY_ONLY            /**< Display I/O capabilities. */
    #define PASSKEY_TXT                     "Passkey:"                                  /**< Message to be displayed together with the pass-key. */
    #define PASSKEY_TXT_LENGTH              8                                           /**< Length of message to be displayed together with the pass-key. */
    #define PASSKEY_LENGTH                  6                                           /**< Length of pass-key received by the stack for display. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static void advertising_start(bool erase_bonds);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    	pm_conn_sec_status_t conn_sec_status;
    	// Check if the link is authenticated (meaning at least MITM).
    	err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
    	if (conn_sec_status.mitm_protected)
    	    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
    			 ble_conn_state_role(p_evt->conn_handle),
    			 p_evt->conn_handle,
    			 p_evt->params.conn_sec_succeeded.procedure);
    	    // The peer did not use MITM, disconnect.
    	    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
    	    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
    	    err_code = sd_ble_gap_disconnect(m_conn_handle,
          case PM_EVT_CONN_SEC_FAILED:
    	advertising_start(false);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_DISPLAY);
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
        // SEC_JUST_WORKS?
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
        pm_handler_secure_on_connection(p_ble_evt);
                NRF_LOG_INFO("Disconnected");
                // Check if the last connected peer had not used MITM, if so, delete its bond information.
                if (m_peer_to_be_deleted != PM_PEER_ID_INVALID)
                    err_code = pm_peer_delete(m_peer_to_be_deleted);
                    NRF_LOG_DEBUG("Collector's bond deleted");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
    	    /* needed ?
                err_code = pm_conn_secure(p_ble_evt->evt.gap_evt.conn_handle, false);
                if (err_code != NRF_ERROR_BUSY)
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_GAP_EVT_PASSKEY_DISPLAY:
                char passkey[PASSKEY_LENGTH + 1];
                memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, PASSKEY_LENGTH);
                passkey[PASSKEY_LENGTH] = 0;
                NRF_LOG_INFO("Passkey: %s", nrf_log_push(passkey));
            } break;
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_AUTH_KEY_REQUEST");
            case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
                NRF_LOG_INFO("BLE_GAP_EVT_LESC_DHKEY_REQUEST");
             case BLE_GAP_EVT_AUTH_STATUS:
                 NRF_LOG_INFO("BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                              p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                              p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                              p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance = true;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        err_code = nrf_ble_lesc_request_handler();
            nrf_pwr_mgmt_run();
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    This works, but still no pairing/bonding!
    Here a few questions about my port.
    In services_init of ble_app_gls there is:
         // Here the sec level for the Glucose Service can be changed/increased.
         gls_init.gl_meas_cccd_wr_sec = SEC_JUST_WORKS;
    There are no such fields in ble_nus_init_t. Is this relevant? I guess not because there is mentioning of "changed/increased" and not of initialize/configure.
    In the ble_evt_handler of ble_app_gls there is NO call to pm_conn_secure.
    I thought that this was needed (see peer manager functionality documentation).
    I thought that encryption was enabled via SEC_PARAM_LESC.
    Finally here a short RTT log:
        <info> app_timer: RTC: initialized.
        <debug> nrf_ble_lesc: Initialized nrf_crypto.
        <debug> nrf_ble_lesc: Initialized nrf_ble_lesc.
        <debug> nrf_ble_lesc: Generating ECC key pair
        <info> app: Debug logging for UART over RTT started.
        <info> app: Fast advertising
        <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
        <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
        <info> app: --> pm_evt_handler 1
       <info> app: Connected
        0xF7
    I seemed to have missed something, but what?
    Thanks again,
    Sietse
