Firmware transfer over BLE for another MCU
For our application, we need to transfer binary (.bin) file from Phone and nRF5340 over BLE and store it into the SD card. Later, another MCU will read the file and update its firmware.
I went through two other queries query_1 and query_2, but those are for transferring data over UART. However, I want to store the file first on an external SD card connected to the SoC, rather than directly transmitting over UART.
I cannot find any example for the same in nRF Connect SDK V2.0.0. Please let me know if I can use any example or a can follow a procedure.
Thanks
  • ShuMan said:
    However, I see the nRF5340 freezes after certain ble writes
    Do these BLE writes have anything in common?
    Are there other BLE writes which this never happens on?
    How often does this happen?
  • Do these BLE writes have anything in common?
    Observing this while sending around 10 MB data continuously in small packet from mobile app to nRF5340, where each packet of size 495 bytes. I have decided the packet size due to CONFIG_BT_L2CAP_TX_MTU=498 in prj.conf. The mobile app sends 495 bytes continuously without any delay in between. As soon as the data with'$' at the start is received, it is written to SD card. Approximately after few thousand writes, the issue occurs.
    Another BLE write which is used to trigger below functionality, issue doesn't occur. These writes happen only to update connection related aspects.
    update_connection_parameters();
    request_mtu_exchange();
    request_data_len_update();
    request_phy_update();
    With many thousand writes, issue occurs.
  • So it is either the BLE, the SD card writing or the combination of these.
    Can you try to write dummy data without BLE to the SD card some thousand times and see if this happens?
    Then receive data from BLE the same amount and not write data to SD card, but discard it instead, and see if this happens?
    With this, we can find if it is an SD Card or BLE specific issue.
    Edit: A collegua also suggests this:
    " Sounds a bit like a flow control issue, yes. Ideally you should stop processing packets from the Bluetooth stack if your local buffers fill up, then the SDC will start NAKing incoming data. "
  • " Sounds a bit like a flow control issue, yes. Ideally you should stop processing packets from the Bluetooth stack if your local buffers fill up, then the SDC will start NAKing incoming data. "
    Is there a method to let mobile application tell that nRF5340 side local buffers already filled and it has to wait?
  • As I see it you have two alternatives:
    • Doing some "trick" in BLE to give the mobile a callback for something. For example time the send out and react on that. I could ask our BLE experts about this if you want?
    •  The more structured method would be to implement a notification service in the nRF5340 which tells the mobile application when it is ready for data and how much data it is ready for. This way the mobile always knows how much it can send. I beleive this is more or less the method we use for DFU.
