Error Programming BC833M
I am working on a custom board using the BC833M (https://www.digikey.com/en/products/detail/fanstel-corp/BC833M/13174321) which uses an nRF52833.  I am using a rigid board connected to a battery on a flexible board which provides the power.  We have multiple flexible boards which allow programming to work while others don't.  The flexible board that doesn't work only reads 2.45V so I suspect it may be too low for some operation in programming, but the board is still detected by the programmer so I was not sure. Please let me know if this is the issue.  Here are the logs generated:
[2022-Aug-23 12:05:03] [ info] --------------------------------------------------------------------------------
[2022-Aug-23 12:05:03] [ info] C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe -f nrf52 --program Debug_HiveMed11_combined.hex --sectorerase --verify --log
[2022-Aug-23 12:05:03] [ info] nrfjprog version 10.15.4 external
[2022-Aug-23 12:05:03] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2022-Aug-23 12:05:03] [ info] Library loaded, loading member functions.
[2022-Aug-23 12:05:03] [ info] Member functions succesfully loaded.
[2022-Aug-23 12:05:03] [debug] [ Client] - open
[2022-Aug-23 12:05:03] [debug] [ Client] - start
[2022-Aug-23 12:05:03] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 28571600-0a2b-4e36-b9f2-b2838afdf371.
[2022-Aug-23 12:05:03] [trace] [ Client] - Command open executed for 41 milliseconds with result 0
[2022-Aug-23 12:05:03] [debug] [ Client] - enum_emu_snr
[2022-Aug-23 12:05:03] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2022-Aug-23 12:05:03] [debug] [ Client] - connect_to_emu_with_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Aug-23 12:05:03] [debug] [ JLink] - Logger sink registered in JLink logger
[2022-Aug-23 12:05:03] [debug] [ nRF52] - open
[2022-Aug-23 12:05:03] [debug] [ nRF52] - just_check_family
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - open_dll
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Aug-23 12:05:03] [ info] [SeggerBackend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLink_x64.dll.
[2022-Aug-23 12:05:03] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Aug-23 12:05:03] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - dll_version
[2022-Aug-23 12:05:03] [ info] [SeggerBackend] - Segger dll version 7.58.b loaded.
[2022-Aug-23 12:05:03] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2022-Aug-23 12:05:03] [debug] [ nRF52] - enum_emu_con_info
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Aug-23 12:05:03] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
[2022-Aug-23 12:05:03] [debug] [ nRF52] - connect_to_emu_with_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Aug-23 12:05:03] [trace] [ JLink] - Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Feb 2 2021 16:47:20
[2022-Aug-23 12:05:03] [trace] [ JLink] - Hardware: V1.00
[2022-Aug-23 12:05:03] [trace] [ JLink] - S/N: 682281589
[2022-Aug-23 12:05:03] [trace] [ JLink] - OEM: SEGGER
[2022-Aug-23 12:05:03] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2022-Aug-23 12:05:03] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2022-Aug-23 12:05:03] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Aug-23 12:05:03] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 40.609ms returns "O.K."
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_HasError()
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_Lock()
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.191ms returns 0
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.001ms returns 0x01
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.001ms returns 0x00
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.003ms returns 0x00
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.007ms returns 0
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 1.011ms returns 0x00
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.215ms
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_GetSN()
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.003ms returns 682281589
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - read_debug_port_register
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - coresight_configure
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 101.284ms returns 0
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.866ms returns -1
[2022-Aug-23 12:05:03] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.767ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.789ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.871ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.843ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.853ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.752ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.819ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.979ms returns -1
[2022-Aug-23 12:05:03] [trace] [ Client] - Command connect_to_emu_with_snr executed for 214 milliseconds with result -102
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.845ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.859ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.761ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.807ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.848ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.856ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.867ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.745ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.755ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.801ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.860ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.906ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.835ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.833ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.832ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.795ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.014ms
[2022-Aug-23 12:05:03] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 200 milliseconds with result -102
[2022-Aug-23 12:05:03] [debug] [ nRF52] - close
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_IsOpen()
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.009ms returns 0x01
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - close
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - is_connected_to_device
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_IsConnected()
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.003ms returns FALSE
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.805ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.868ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.748ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.831ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.874ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.747ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.852ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.847ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.879ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.844ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.751ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.846ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.776ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.827ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.823ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.750ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.861ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.808ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.760ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.862ms returns -1
[2022-Aug-23 12:05:03] [trace] [ JLink] - - 0.011ms
[2022-Aug-23 12:05:03] [trace] [ JLink] - JLINK_Close()
[2022-Aug-23 12:05:03] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Aug-23 12:05:03] [debug] [ nRF52] - nRF family DLL closed
[2022-Aug-23 12:05:03] [trace] [ Client] - Command close executed for 62 milliseconds with result 0
[2022-Aug-23 12:05:03] [debug] [ Client] - terminate
[2022-Aug-23 12:05:03] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2022-Aug-23 12:05:03] [trace] [ Worker] - Command close executed for 60 milliseconds with result 0
[2022-Aug-23 12:05:03] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Aug-23 12:05:03] [trace] [ Worker] - Executed 5 commands for 266 milliseconds
[2022-Aug-23 12:05:03] [debug] [ Client] - Worker process exited with code: 0
[2022-Aug-23 12:05:03] [debug] [ Client] - Child process terminated with result 0
[2022-Aug-23 12:05:04] [trace] [ Client] - Executed 5 commands for 332 milliseconds
[2022-Aug-23 12:05:04] [debug] [ Client] - terminate
    This is too low for successful programming using the DK's as a programmer.
    Try powering your external board from the nRF DK itself, this way you're ensuring that the voltages are equal.
    Håkon
