Hello!
I have an application that makes use of the function sd_ble_gap_conn_evt_trigger_start(), present in v7.3.0 of the S113, S132, and S140 SoftDevices. Here's the documentation for that function.
I was looking to migrate to the new nRF Connect SDK, but couldn't find a comparable function. Is this function, or an equivalent, available in the nRF Connect SDK? If not, I'll have to remain on the old nRF SDK.
Thanks!
If you're wondering why I must have the sd_ble_gap_conn_evt_trigger_start() function: sometimes I need my application to know how long it has been since the last connection event. To do this, I use that function to trigger a timer capture task on each connection event:
nrf_timer_task_address_get(NRF_TIMER1, NRF_TIMER_TASK_CAPTURE0)
Then, I can compare the value of the timer with the captured value to know how long ago a connection event occurred. If the timer value minus the captured value is 5700μs, then the last connection event started 5700μs ago.
This is important to my application. If the nRF Connect SDK does not have a similar function, I cannot use it.
