Read Uart based sensor data on nrf5340 using VsCode?
I'am using the  Ultrasonic Oxygen Senor with the nrf5340, the output is like this "photo" I want to calculate the concentration and the purity and with this values I had wrong results, so can you help to solve this problem?
 I am using this code
4857.gasboard.zip
 and here is my result.
this technical specification for my sensor.
 https://en.gassensor.com.cn/Product_files/Specifications/Gasboard%207500H%20series%20technical%20specification.pdf?fbclid=IwAR0R1P0FlwkPzhew7jBYVzL-rvtESB1ob2HGF0OE4bngaI5jP8ktZfFMoMo
Could you please help me to solve this problem
  • I haven't seen the Arduino code so I can't say anything about that unless you share the code. Is the Arduino code also interrupt based?
    Looking at your code, it looks like you're disabling uart irq tx in your callback without enabling it again, any reason for this? Also you are using code in your main function that is supposed to be used in callbacks. I would recommend trying to use a UART API that is not interrupt based to test that you are able to communicate with the sensor.
    -Einar
  • Here is the Arduino code.
    #include <Wire.h>
    void setup() {
      Serial.begin(9600);
    void loop() {
      typedef unsigned char u8;
      typedef unsigned int u16;
      int inByte;
      u8 temp;
      u8 i, j, o2[12];
      u16 o2c, o2f, o2t; //Define oxygen concentration, flow rate and temperature
      //When character arrive over the serial port ..
      if (Serial.available()) {
      // wait a bit for the entire message to arrive
      delay(100);
        // read all the available characters
        while (Serial.available() > 0) {
          inByte = Serial.read();
          //---Receiving part---
          if ((o2[0] == 0x16) && (o2[1] == 0x09) && (o2[2] == 0x01)) //Determine if the first two bytes are received correctly, I is the global variable
            o2[i] = inByte;
            i++;
          else           //If one of the first three bytes received is incorrect, the first two bytes will be judged
            if ((o2[0] == 0x16) && (o2[1] == 0x09))
              if ( inByte == 0x01)
                o2[2] =  inByte;
                i++;
                i = 0;
                for (j = 0; j < 12; j++)
                  o2[j] = 0;
              if (o2[0] == 0x16)
                if ( inByte == 0x09)
                  o2[1] =  inByte;
                  i++;
                  i = 0;
                    o2[j] = 0;
                if ( inByte == 0x16)
                  o2[0] =  inByte;
                  i++;
                  i = 0;
                    o2[j] = 0;
          if (i == 12)   //Data received complete, start calibration
            temp = 0;
              temp += o2[j];
            if (temp == 0)     //Check passed, calculate oxygen concentration, flow, temperature value
              o2c = o2[3] * 256 + o2[4];     //Oxygen concentration
              o2f = o2[5] * 256 + o2[6];     //Oxygen flow value
              o2t = o2[7] * 256 + o2[8];     //Oxygen temperature
            i = 0;
            for (j = 0; j < 12; j++)           //Initialize array
              o2[j] = 0;
    //--O2
    Serial.print("O2 : ");
    Serial.print(o2c/100);
    Serial.print(o2c/10%10);
    Serial.print(".");
    Serial.print(o2c%10);
    Serial.println("%");
    //--Flow
    Serial.print("Flow : ");
    Serial.print(o2f/10%10);
    Serial.print(".");
    Serial.print(o2f%10);
    Serial.println("L/min");
    //--Temperature
    Serial.print("Temp : ");
    Serial.print(o2t/100);
    Serial.print(o2t/10%10);
    Serial.print(".");
    Serial.print(o2t%10);
    Serial.println("Celcius");
    delay(2000);
  • Hi
    I noticed now that the data sheet says "The sensor will send data actively by default and the sending interval is 0.5 seconds", so you should be able to read data the same way the Arduino code does, without sending commands to it.
    So try to look at the Arduino code you have here and do the same in your program.
    Have you done anything more to look at the values you're reading other than the prints in your original post? Any reason you print those bytes as %x %i %i and not %x %x %x ?
    -Einar
  • Yes, I did the same but the program display this value"0", I think that i have a bug or problem in the code that i sent to you in the first discussion that i can't find it. So I need a help from you because i'm a beginner in the programing of nrf with zephyr. Thank you
    #include <zephyr.h>
    #include <device.h>
    #include <devicetree.h>
    #include <drivers/uart.h>
    #include <sys/printk.h>
    uint8_t uart_buf[1024];
    int count;
    void uart_cb(const struct device *x, void *user_data)
    	uart_update(x);
    	int data_length = 0;
    	if (uart_rx_ready(x)) {
    		data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
    		uart_buf[data_length] = 0;
        uart_fifo_fill(x, uart_buf, data_length);
    void main(void)
        printk("sensor program start!\n"); //output on UART0, which is default for logging
    const struct device *uart = device_get_binding("UART_1");
    	uart_callback_set(uart, uart_cb,NULL);
    	uart_rx_enable(uart,uart_buf,sizeof(uart_buf),500000);
        struct uart_config cfg ;
        cfg.baudrate = 9600 ;
        cfg.parity = UART_CFG_PARITY_NONE ;
        cfg.stop_bits = UART_CFG_STOP_BITS_1 ;
        cfg.data_bits = UART_CFG_DATA_BITS_8 ;
        cfg.flow_ctrl = UART_CFG_FLOW_CTRL_NONE ;
     uart_configure(uart, &cfg);
    	printk("main function!\n"); //output on UART0, which is default for logging
    	while (1) {
            // uart_fifo_fill(uart, "UART loopback start!\r\n", 22);
            count=uart_fifo_read(uart,uart_buf,sizeof(uart_buf));
            printf("read  %i\n",count);
            printk("receiveing data! %x %i %i\n",uart_buf[0],uart_buf[1],uart_buf[2]); //output on UART0, which is default for logging
            k_cpu_idle();
            k_sleep(K_MSEC(1000));
  • As I asked in my last post, have you tried using %x instead of %i in your print? It could be that your program works but just doesn't display the data correctly.
