SPI spi_transceive not receiving data
my master is outputting all the right signals on the SPI lines. The slave though, although it appears ot recognize the CSN pin and runs the spi_tranceieve function. It does not actually read the MOSI line. I am using 2x nRF52850DK boards. and using the nrf52840dk_nrf52840.dts file and wrapping it with an overlay. i got 2 print command that show it waits at the spi_transceive line until it sees a csn trigger. but it never actually fills the rx buffer.
master overlay
&pinctrl {
	spi1_default: spi1_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 31)>,
				<NRF_PSEL(SPIM_MOSI, 0, 30)>,
				<NRF_PSEL(SPIM_MISO, 0, 10)>;
	spi1_sleep: spi1_sleep {
		group1 {
			low-power-enable;
&spi1 {
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	cs-gpios = <&gpio0 4 GPIO_ACTIVE_LOW>;
master SPI output command
int spi_write_cmd(uint8_t cmd){
	int err;
	int incr = 0;
	tx_buffer[0] = cmd;
	tx_buffer[1] = 0x33;
	tx_buffer[2] = 0xff;
	err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx);
	if(err > 0){
		while(incr < MAX_BUFFER_SIZE){
			printk("0x%X", rx_buffer[incr]);
			incr++;
		printk("\n");
	return err;
slave overlay
&pinctrl {
	spi2_default: spi2_default {
		group1 {
			psels = <NRF_PSEL(SPIS_SCK, 0, 10)>,
					<NRF_PSEL(SPIS_MOSI, 0, 21)>,
					<NRF_PSEL(SPIS_MISO, 0, 23)>,
					<NRF_PSEL(SPIS_CSN, 0, 16)>;
	spi2_sleep: spi2_sleep {
		group1 {
			low-power-enable;
&spi2 {
	compatible = "nordic,nrf-spis";
	status = "okay";
	pinctrl-0 = <&spi2_default>;
	/delete-property/ pinctrl-1;
	pinctrl-names = "default";
	def-char = <0x33>;
slave read function
int spis_transceive(void){
	int cnt = 0;
	uint8_t incr = 0;
	printk("pre trans_spi\n");
	cnt = spi_transceive(spis_dev, &spis_cfg, &spis_tx, &spis_rx);
	printk("post spi_trans cnt: %d\n", cnt);
	if(cnt > 0){
		while(incr < SPI_BUFFER_SIZE){
			printk("0x%X", spis_rx_buffer[incr]);
			incr++;
		printk("\n");
	return cnt;
slave output: every time i send a command over SPI it registers the the CSN pin activity, but the spi_transceieve function does not do anything or fill the buffer.
post spi_trans cnt: 0
pre trans_spi
pre trans_spi
pre trans_spi
complete slave code
#include "spis.h"
#include <zephyr.h>
#include <sys/printk.h>
#include <drivers/spi.h>
#include <device.h>
#define SPIS_NODE DT_NODELABEL(spi2)
extern void spis_thread(void *, void *, void *);
K_THREAD_DEFINE(spis_tid, SPIS_STACK_SIZE, spis_thread, NULL, NULL, NULL, SPIS_PRIORITY, 0, 0);
struct spis_cb_t spi_cb;
static uint8_t spis_tx_buffer[SPI_BUFFER_SIZE] = "<*>slave out default message buf";
static uint8_t spis_rx_buffer[SPI_BUFFER_SIZE];
static struct spi_config spis_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB |
		     SPI_OP_MODE_SLAVE
			 | SPI_MODE_CPOL | SPI_MODE_CPHA,
	.frequency = 125000,
	.slave = 1,
	//.cs = &spi_cs,
const struct spi_buf spis_tx_buf = {
	.buf = spis_tx_buffer,
	.len = sizeof(spis_tx_buffer)
const struct spi_buf_set spis_tx = {
	.buffers = &spis_tx_buf,
	.count = 1
const struct spi_buf spis_rx_buf = 	{
	.buf = spis_rx_buffer,
	.len = sizeof(spis_rx_buffer),
const struct spi_buf_set spis_rx =	{
	.buffers = &spis_rx_buf,
	.count = 1
const struct device *spis_dev;
uint8_t spis_init(void)
	int err;
	spis_tx_buffer[0] = 0xff;
	spis_tx_buffer[1] = 0x35;
	spis_dev = device_get_binding(DT_LABEL(SPIS_NODE));
	if (spis_dev == NULL) {
		printk("Could not get %s device\n", DT_LABEL(SPIS_NODE));
		return 1;
	printk("SPI Device: %s\n", DT_LABEL(SPIS_NODE));
	return 0;
	int cnt = 0;
	uint8_t incr = 0;
	if(cnt > 0){
			incr++;
		printk("\n");
	return cnt;
extern void spis_thread(void *unused1, void *unused2, void *unused3){
	int err;
	err = spis_init();
	if(err) return;
	if(!device_is_ready(spis_dev)) return;
	printk("SPIS thread begin\n");
	while (1) {
		err = spis_transceive();
		if(err < 0) break;
	printk("SPIS thread end\n");
