I have nrf52DK (nrf52832-PCA10040) and I wanted to test the Peripheral example in the nrf Connect SDK. I have built the project for nrf52DK_nrf52832 and then flashed the code but it gives a hard faults.
I am using nRF Connect SDK v2.02 on Windows machine using nrf52DK (nrf52832-PCA10040-2.1.0)
*** Booting Zephyr OS build v3.0.99-ncs1-1 *** [Bluetooth initialized 0[00:00:00.011,016] <inf> fs_nvs: alloc wra: 0, fe8 [00:00:00.011,047] <inf> fs_nvs: data wra: 0, 0 [00:00:00.011,169] <inf> sdc_hci_driver: SoftDevice Controller build revision: 33 78 2a 18 20 f5 61 61 a6 8b 77 60 62 83 39 2a |3x*. .aa ..w`b.9* 7c f1 14 e4 ||... [00:00:00.015,441] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002) [00:00:00.015,472] <inf> bt_hci_core: HW Variant: nRF52x (0x0002) [00:00:00.015,472] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 51.10872 Build 1643454488 [00:00:00.016,082] <inf> bt_hci_core: No ID address. App must call settings_load() [00:00:00.018,096] <err> os: ***** HARD FAULT ***** [00:00:00.018,096] <err> os: Fault escalation (see below) [00:00:00.018,096] <err> os: ***** MPU FAULT ***** [00:00:00.018,127] <err> os: Stacking error (context area might be not valid) [00:00:00.018,127] <err> os: Data Access Violation [00:00:00.018,157] <err> os: MMFAR Address: 0x20005110 [00:00:00.018,157] <err> os: r0/a1: 0x95c3707c r1/a2: 0xdc7d25e8 r2/a3: 0xe97ffd9e [00:00:00.018,188] <err> os: r3/a4: 0x18a8ca4c r12/ip: 0xa77b66f4 r14/lr: 0x30e6eb39 [00:00:00.018,188] <err> os: xpsr: 0x61000000 [00:00:00.018,188] <err> os: Faulting instruction address (r15/pc): 0x00002e70 [00:00:00.018,218] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0 [00:00:00.018,249] <err> os: Current thread: 0x200023f0 (main) [00:00:01.525,573] <err> fatal_error: Resetting system
.text 0x0000000000002a74 0x8c C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002a74 sym_ZC6NJBPUISWILQK6OTOBMJVVUT63JRIDGH5WNCY
.text 0x0000000000002b00 0x68 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002b00 sym_ORUJDMUJV7RZIFXM3X5KLRROPKJ7VPLJ65JMLRQ
.text 0x0000000000002b68 0x38 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002b68 sym_PITJNQC6YSCEFAH23N5QRORZDKCSKOAUGBUS6GA
.text 0x0000000000002ba0 0x5c C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002ba0 sym_AOU55ZK756JLPLCLZ5TZSSVKOAWWFUNQZATBXUI
.text 0x0000000000002bfc 0x104 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002bfc MPSL_IRQ_RTC0_Handler
.text 0x0000000000002d00 0x100 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002d00 MPSL_IRQ_TIMER0_Handler
.text 0x0000000000002e00 0x64 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
.text 0x0000000000002e64 0xc C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002e64 sym_M4DIQOXJAE3BNHQBIUCZXAABSM24CWUEJOCU7DY
.text 0x0000000000002e70 0x144 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002e70 sym_2ZDZA75WOMRNSQ6XL7IZWAQKYFFSRJOGBGKPTIQ
.text 0x0000000000002fb4 0xc4 C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000002fb4 sym_UGOJA475OXR5HR5WFINUK27HP5BRGNWCZXQLKDI
.text 0x0000000000003078 0xc C:/nordic/v2.0.2/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a(libmpsl_debug_soft__obfuscated.elf)
0x0000000000003078 sym_RUQO26WM5KVVEW7O3OHCXPO7LLLXRBDPIPSWIWY
west build --build-dir c:\nordic\periph\peripheral\build c:\nordic\periph\peripheral --pristine --board nrf52dk_nrf52832 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/nordic/periph/peripheral;c:/nordic/v2.0.2/nrf/boards/arm/nrf52kbd_nrf52832" -DCONFIG_DEBUG_OPTIMIZATIONS:STRING="y" -DCONFIG_DEBUG_THREAD_INFO:STRING="y" -DCONF_FILE:STRING="c:/nordic/periph/peripheral/prj.conf"
And then when finally the build is working, the given example does not work! I thought the vendor-provided things should work from the first try without so much hassle.
Ahmed
