Info : [nrf52.cpu] external reset detected
I am getting a similar error. I have nRF52832 board connected to raspberry pi for flashing and debugging using openocd. As soon as openocd command is executed I start getting this error:
Following is the snippet of the output of the openocd command:
pi@vsense:~ $ openocd -c 'bindto 0.0.0.0' -f rpi_as_debugger.cfg -c 'transport s elect swd' -c 'adapter speed 250' -f target/nrf52.cfg
Open On-Chip Debugger 0.11.0+dev-00815-gf77c919cf (2022-08-23-18:35)
Licensed under GNU GPL v2
For bug reports, read
openocd.org/.../bugs.html
srst_only separate srst_gates_jtag srst_push_pull connect_deassert_srst
swd
adapter speed: 250 kHz
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : clock speed 1001 kHz
Info : SWD DPIDR 0x2ba01477
Info : [nrf52.cpu] Cortex-M4 r0p1 processor detected
Info : [nrf52.cpu] target has 6 breakpoints, 4 watchpoints
Info : starting gdb server for nrf52.cpu on 3333
Info : Listening on port 3333 for gdb connections
Does anyone have any idea what could be the root cause of this error propping up even when there is no IDE running, no flashing of program is done, no debugging through IDE is started/ going on.
Thanks in advance...
Vicky
