I am developing the nRF52833 DK with NCS v2.00. I am using a function in my source code that reads the current RSSI of the connection. The function, read_conn_rssi (attached below), is taken from the Bluetooth sample, Bluetooth: HCI Power Control. I am getting the following error with the bt_hci_cmd_send_sync function in my code:
<wrn> bt_hci_core: opcode ox1405 status 0x01
Read RSSI err: -5 reason 0x00
I have been trying to find the error & status codes but have not been able to - where can I find them so that I can see what they mean?
Adam
static void read_conn_rssi(uint16_t handle, int8_t *rssi)
struct net_buf *buf, *rsp = NULL;
struct bt_hci_cp_read_rssi *cp;
struct bt_hci_rp_read_rssi *rp;
int err;
buf = bt_hci_cmd_create(BT_HCI_OP_READ_RSSI, sizeof(*cp));
if (!buf) {
printk("Unable to allocate command buffer\n");
return;
cp = net_buf_add(buf, sizeof(*cp));
cp->handle = sys_cpu_to_le16(handle);
err = bt_hci_cmd_send_sync(BT_HCI_OP_READ_RSSI, buf, &rsp);
if (err) {
uint8_t reason = rsp ?
((struct bt_hci_rp_read_rssi *)rsp->data)->status : 0;
printk("Read RSSI err: %d reason 0x%02x\n", err, reason);
return;
rp = (void *)rsp->data;
*rssi = rp->rssi;
net_buf_unref(rsp);
