Hello!
We have hit a wall trying to add support for a particular BLE peripheral to one of our products (which is acting as a BLE central). We support other peripherals, but there is something unique about this particular device that is causing problems.
We can see that the device is advertising, when we send it a scan request, we get the expected scan response. When we call sd_ble_gap_connect(), we soon receive a BLE_GAP_EVT_CONNECTED event, but a few milliseconds later we recieve a BLE_GAP_EVT_DISCONNECTED event with the reason code 0x3E (BLE_HCI_CONN_FAILED_TO_BE_ESTABLISHED).
This happens every time that we try to connect - it is not a rare event related to signal strength or something like that.
When I watch the process in a BLE sniffer, I can see the advertising packets, I can see the scan request, the scan response, and the connection request. After the connection request, I can see our device continue to try to interact with the peripheral (sending discovery request, or just empty packets to keep the connection open), but the peripheral doesn't send any responses. eventually it starts advertising again. I believe that the problem is with the connection request and not with the discovery related requests that come after it because I tried disabling discovery and I still did not see any response from the peripheral in sniffer and I still got the 0x3E disconnect code.
We are able to successfully connect to the peripheral using NRF connect. When I look at the sniffer data there are a few differences in the connection request sent by the app and the connection request sent by our central device
Connection request packet sent by our Central device | Connection request packet sent by NRF Connect App |
Frame 236: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface wireshark_extcap2028, id 0 Nordic BLE Sniffer Bluetooth Low Energy Link Layer Access Address: 0x8e89bed6 Packet Header: 0x2265 (PDU Type: CONNECT_REQ, ChSel: #2, TxAdd: Random, RxAdd: Public) .... 0101 = PDU Type: CONNECT_REQ (0x5) ...0 .... = RFU: 0 ..1. .... = Channel Selection Algorithm: #2 .1.. .... = Tx Address: Random 0... .... = Rx Address: Public Length: 34 Initator Address: d5:d6:38:ac:56:b4 (d5:d6:38:ac:56:b4) Advertising Address: TelinkSe_e5:80:15 (a4:c1:38:e5:80:15) Link Layer Data Access Address: 0x98a46d95 CRC Init: 0x3595fa Window Size: 5 (6.25 msec) Window Offset: 0 (0 msec) Interval: 48 (60 msec) Latency: 0 Timeout: 1000 (10000 msec) Channel Map: ffffffff1f ...0 1110 = Hop: 14 111. .... = Sleep Clock Accuracy: 0 ppm to 20 ppm (7) CRC: 0xfb7392 |
Frame 1473: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface wireshark_extcap1772, id 0 Nordic BLE Sniffer Bluetooth Low Energy Link Layer Access Address: 0x8e89bed6 Packet Header: 0x2245 (PDU Type: CONNECT_REQ, ChSel: #1, TxAdd: Random, RxAdd: Public) .... 0101 = PDU Type: CONNECT_REQ (0x5) ...0 .... = RFU: 0 ..0. .... = Channel Selection Algorithm: #1 .1.. .... = Tx Address: Random 0... .... = Rx Address: Public Length: 34 Initator Address: 48:5b:57:2e:eb:e7 (48:5b:57:2e:eb:e7) Advertising Address: TelinkSe_e5:80:15 (a4:c1:38:e5:80:15) Link Layer Data Access Address: 0x65f7669f CRC Init: 0x322b50 Window Size: 1 (1.25 msec) Window Offset: 32 (40 msec) Interval: 36 (45 msec) Latency: 0 Timeout: 500 (5000 msec) Channel Map: ffffffff1f ...0 0110 = Hop: 6 000. .... = Sleep Clock Accuracy: 251 ppm to 500 ppm (0) CRC: 0x936eea |
The window size, interval, and timeout are all MORE conservative for our central device than the app, so they are lower on our suspect list.
We saw these two seemingly relevant posts
RE: Channel Selection Algorithm S132 SoftDevice
which suggests that the channel selection algorithm cannot be changed and that it is probably not the problem.
apparently the hop increment is a random value, so that should not be the problem.
That leaves us without any leads into why the peripheral will not connect.
Does anyone have any idea what the problem might be?
I have attached sniffer logs for both our central device and for nrf connect.
We are using sdk version 15.2.0 for this project, soft device s132_nrf52_6.1.0.
sniffer_log_nrf52_central_device.pcapngsniffer_log_nrf52_nrf_connect.pcapng
