An error is reported when using uart to output debugging information
Hi,nordic.
I've been wanting to make some modifications to the existing bluetooth mesh model and output data to the serial port. I have tried to use app_uart_put() to output characters while turning on rtt , but there is always no output, and I understand that this output is inefficient, so I plan to replace rtt directly, use uart to output debugging information and put it in Change based on that. I found a case in the forum, but it will report the following error, how should I solve it? I use light_switch as a test case here, the working environment is ses, the version is mesh5.0.0 and sdk1710.
  • #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    #include <stdio.h>
    /* Core */
    #include "nrf_mesh_config_core.h"
    #include "nrf_mesh_gatt.h"
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh_events.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    #include "proxy.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "generic_onoff_server.h"
    #include "scene_setup_server.h"
    #include "model_config_file.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "example_common.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "app_onoff.h"
    #include "ble_softdevice_support.h"
    #include "app_dtt.h"
    #include "app_scene.h"
     * Definitions
    #define ONOFF_SERVER_0_LED          (BSP_LED_0)
    #define APP_ONOFF_ELEMENT_INDEX     (0)
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #include "app_uart.h"
    #include "nrf_uart.h"
    /* Controls if the model instance should force all mesh messages to be segmented messages. */
    #define APP_FORCE_SEGMENTATION      (false)
    /* Controls the MIC size used by the model instance for sending the mesh messages. */
    #define APP_MIC_SIZE                (NRF_MESH_TRANSMIC_SIZE_SMALL)
     * Forward declaration of static functions
    static void mesh_events_handle(const nrf_mesh_evt_t * p_evt);
    static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff);
    static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff);
    static void app_onoff_server_transition_cb(const app_onoff_server_t * p_server,
                                                    uint32_t transition_time_ms, bool target_onoff);
    #if SCENE_SETUP_SERVER_INSTANCES_MAX > 0
    static void app_onoff_scene_transition_cb(const app_scene_setup_server_t * p_app,
                                              uint16_t target_scene);
     * Static variables
    static bool m_device_provisioned;
    static nrf_mesh_evt_handler_t m_event_handler =
        .evt_cb = mesh_events_handle,
    /* Defaut Transition Time server structure definition and initialization */
    APP_DTT_SERVER_DEF(m_dtt_server_0,
                       APP_FORCE_SEGMENTATION,
                       APP_MIC_SIZE,
                       NULL)
    /* Scene Setup server structure definition and initialization */
    APP_SCENE_SETUP_SERVER_DEF(m_scene_server_0,
                               APP_MIC_SIZE,
                               app_onoff_scene_transition_cb,
                               &m_dtt_server_0.server)
    /* Generic OnOff server structure definition and initialization */
    APP_ONOFF_SERVER_DEF(m_onoff_server_0,
                         APP_MIC_SIZE,
                         app_onoff_server_set_cb,
                         app_onoff_server_get_cb,
                         app_onoff_server_transition_cb)
    /* Callback for updating the hardware state */
        /* Resolve the server instance here if required, this example uses only 1 instance. */
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
        hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
    /* Callback for reading the hardware state */
        *p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target OnOff: %d\n",
                                           transition_time_ms, target_onoff);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target Scene: %d\n",
                                           transition_time_ms, target_scene);
    static void app_model_init(void)
        /* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
        ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
        /* Instantiate Generic Default Transition Time server as needed by Scene models */
        ERROR_CHECK(app_dtt_init(&m_dtt_server_0, APP_ONOFF_ELEMENT_INDEX));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App DTT Model Handle: %d\n", m_dtt_server_0.server.model_handle);
        /* Instantiate scene server and register onoff server to have scene support */
        ERROR_CHECK(app_scene_model_init(&m_scene_server_0, APP_ONOFF_ELEMENT_INDEX));
        ERROR_CHECK(app_scene_model_add(&m_scene_server_0, &m_onoff_server_0.scene_if));
        ERROR_CHECK(app_onoff_scene_context_set(&m_onoff_server_0, &m_scene_server_0));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App Scene Model Handle: %d\n", m_scene_server_0.scene_setup_server.model_handle);
        if (p_evt->type == NRF_MESH_EVT_ENABLED)
            APP_ERROR_CHECK(app_onoff_value_restore(&m_onoff_server_0));
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        model_config_file_clear();
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    #if NRF_MESH_LOG_ENABLE
    static const char m_usage_string[] =
        "\n"
        "\t\t-------------------------------------------------------------------------------\n"
        "\t\t Button/RTT 1) LED state will toggle and inform clients about the state change.\n"
        "\t\t Button/RTT 4) Clear all the states to reset the node.\n"
        "\t\t-------------------------------------------------------------------------------\n";
    static void button_event_handler(uint32_t button_number)
        /* Increase button number because the buttons on the board is marked with 1 to 4 */
        button_number++;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        switch (button_number)
            /* Pressing SW1 on the Development Kit will result in LED state to toggle and trigger
            the STATUS message to inform client about the state change. This is a demonstration of
            state change publication due to local event. */
            case 1:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "User action \n");
                hal_led_pin_set(ONOFF_SERVER_0_LED, !hal_led_pin_get(ONOFF_SERVER_0_LED));
                app_onoff_status_publish(&m_onoff_server_0);
            /* Initiate node reset */
            case 4:
                /* Clear all the states to reset the node. */
                if (mesh_stack_is_device_provisioned())
    #if MESH_FEATURE_GATT_PROXY_ENABLED
                    (void) proxy_stop();
                    mesh_stack_config_clear();
                    node_reset();
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
    static void app_rtt_input_handler(int key)
        if (key >= '1' && key <= '4')
            uint32_t button_number = key - '1';
            button_event_handler(button_number);
    static void device_identification_start_cb(uint8_t attention_duration_s)
        hal_led_mask_set(HAL_LED_MASK, false);
        hal_led_blink_ms(HAL_LED_MASK_HALF,
                         LED_BLINK_ATTENTION_INTERVAL_MS,
                         LED_BLINK_ATTENTION_COUNT(attention_duration_s));
    static void provisioning_aborted_cb(void)
        hal_led_blink_stop();
    static void unicast_address_print(void)
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
    #if MESH_FEATURE_GATT_ENABLED
        /* Restores the application parameters after switching from the Provisioning
         * service to the Proxy  */
        gap_params_init();
        conn_params_init();
        unicast_address_print();
        hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        app_model_init();
    static void mesh_init(void)
        /* Initialize the application storage for models */
        model_config_file_init();
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = NULL,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
        if (status == NRF_SUCCESS)
            /* Check if application stored data is valid, if not clear all data and use default values. */
            status = model_config_file_config_apply();
        switch (status)
            case NRF_ERROR_INVALID_DATA:
                /* Clear model config file as loading failed */
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
            case NRF_SUCCESS:
                ERROR_CHECK(status);
    //START
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    //END
    static void initialize(void)
        uart_init();
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_sd_ble_opt_set_cb = NULL,
                .prov_complete_cb = provisioning_complete_cb,
                .prov_device_identification_start_cb = device_identification_start_cb,
                .prov_device_identification_stop_cb = NULL,
                .prov_abort_cb = provisioning_aborted_cb,
                .p_device_uri = EX_URI_LS_SERVER
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
        /* NRF_MESH_EVT_ENABLED is triggered in the mesh IRQ context after the stack is fully enabled.
         * This event is used to call Model APIs for establishing bindings and publish a model state information. */
        nrf_mesh_evt_handler_add(&m_event_handler);
        ERROR_CHECK(mesh_stack_start());
        hal_led_mask_set(HAL_LED_MASK_UPPER_HALF, LED_MASK_STATE_OFF);
        hal_led_blink_ms(HAL_LED_MASK_UPPER_HALF, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        start();
        for (;;)
            (void)sd_app_evt_wait();
    Here is the code.I'm a newbie and I don't know how to upload the complete code file, how do I upload the code file if it is needed?
    best regards
    Peter Beckham
  • Hi.
    You can find an example on how to implement printing logs via UART in Mesh here:
     Adding UART code to the 'light switch server' project
    You can upload a file by choosing "Insert -> Image/Video/File".
  • Hi,Joakim Jakobsen
    I still can't upload, when I put the file zip it shows up as an unreasonable url.
    In fact, I changed the code based on the link you gave. At present, after debugging, I can use printf to print normally, but it can only print on rtt, and the serial port still has no information. Is it not possible to print information using uart in mesh?
    best regards
    Peter Beckham
  • That is strange.
    You can also drag-and-drop the file directly to the text box to upload your file.
    So you have based your project on the example made my by colleague Hung in the link I sent you?
    Did you take into account that the example was written for nRF5 SDK for Mesh v.4.0.0? Did you make any changes to the example?
    Br,
    Joakim
