Using the S340 protocol stack to DFU 52840, the SD_VERSION_FAILURE error is reported
The version of bootload I use is as follows:
,Finally, the file was synthesized by NRFUtil and downloaded to 52840. The system started well when it was powered on, which means that the bootload was running well. When I tried to upgrade it with DFU, I received the following error:
I made it clear in the DFU package -- SD-req is 0xb9, which is obtained from the command line query:
Wonder why the SD_VERSION_FAILURE error is reported? How do I fix this?
