Modifying the SDK Keyboard USB HID Descriptor
I have a product under development that needs to send USB key codes to the PC that are outside the range that is supported by the USBD library and I am wondering the best way to go about altering the HID Keyboard descriptor.
The project implementation relies on the USBD library extensively. The USB Keyboard Descriptor is not taken from the user application; it relies on the USB HID KBD descriptor provided by the USBD library. The Logical Maximum and Usage Maximum reported by the USBD library are both 0x65. This needs to be increased to 0x73 to support keys up to F24, and I cannot determine a way to replace the built-in descriptor with my own.
From "app_usbd_hid_kbd_desc.h":
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
* @brief Example of USB HID keyboard report descriptor.
#define APP_USBD_HID_KBD_REPORT_DSC() { \
0x05, 0x01, /* USAGE_PAGE (Generic Desktop) */\
0x09, 0x06, /* USAGE (Keyboard) */\
0xa1, 0x01, /* COLLECTION (Application) */\
0x05, 0x07, /* USAGE_PAGE (Keyboard) */\
0x19, 0xe0, /* USAGE_MINIMUM (Keyboard LeftControl) */\
0x29, 0xe7, /* USAGE_MAXIMUM (Keyboard Right GUI) */\
0x15, 0x00, /* LOGICAL_MINIMUM (0) */\
0x25, 0x01, /* LOGICAL_MAXIMUM (1) */\
0x75, 0x01, /* REPORT_SIZE (1) */\
0x95, 0x08, /* REPORT_COUNT (8) */\
0x81, 0x02, /* INPUT (Data,Var,Abs) */\
0x95, 0x01, /* REPORT_COUNT (1) */\
0x75, 0x08, /* REPORT_SIZE (8) */\
0x81, 0x03, /* INPUT (Cnst,Var,Abs) */\
0x95, 0x05, /* REPORT_COUNT (5) */\
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
What is the "correct" way to change the USB HID KBD descriptor?
To be clear, I need to change the Logical Maximum and Usage Maximum to 0x73, instead of 0x65.
I am very reluctant to edit the content of the SDK. To edit the file within the SDK is likely to work, however it then relies on documenting changes to the SDK, should the SDK ever be changed at some point in the future. This would seem like a solution that will work today, however another developer in future would need to know that there have been changes made to the standard SDK.There is a code maintenance risk in the future.
I would prefer to define my own version of APP_USBD_HID_KBD_REPORT_DSC(), however I cannot see how to do it as the library version is used within app_usbd_hid_kbd:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
* @brief Global definition of app_usbd_hid_kbd_t class.
* @param instance_name Name of global instance.
* @param interface_number Unique interface index.
* @param endpoint Input endpoint (@ref nrf_drv_usbd_ep_t).
* @param user_ev_handler User event handler (optional parameter: NULL might be passed here).
* @param subclass_boot Subclass boot (@ref app_usbd_hid_subclass_t).
* Example class definition:
* @code
APP_USBD_HID_KBD_GLOBAL_DEF(my_awesome_kbd, 0, NRF_DRV_USBD_EPIN1, NULL, APP_USBD_HID_SUBCLASS_BOOT);
* @endcode
#define APP_USBD_HID_KBD_GLOBAL_DEF(instance_name, interface_number, endpoint, user_ev_handler, subclass_boot) \
APP_USBD_HID_GENERIC_SUBCLASS_REPORT_DESC(keyboard_desc, APP_USBD_HID_KBD_REPORT_DSC()); \
static const app_usbd_hid_subclass_desc_t * keyboard_descs[] = {&keyboard_desc}; \
APP_USBD_HID_KBD_GLOBAL_DEF_INTERNAL(instance_name, \
interface_number, \
endpoint, \
user_ev_handler, \
At this point, I cannot see any other way to change the USB HID KBD descriptor, other than to change the file in the SDK.
Can you please help to share the correct method for changing the USB HID KBD descriptor.
SDK 17.1.0.
