Accessing the nrf52820 pins
Hello all
I am porting the code from the nRF52DK to the nrf52820, and so far so good, however, I am having a question, when configuring the TWI, will this get me the right PINS, for instance, according to the module manufacturer I should be accessing the P0.02 for SDA, while P0.08 for the SCL , this is my code:
void twi_init (void)
    ret_code_t err_code;
    const nrf_drv_twi_config_t twi_config = {
       .scl                = NRF_GPIO_PIN_MAP(0, 8), // ARDUINO_SCL_PIN,   //Add you SCL Pin Here
       .sda                = NRF_GPIO_PIN_MAP(0, 2), // ARDUINO_SDA_PIN,   //Add you SDA Pin Here
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
This part works on the nrf52dk, for example where I am directly using the P0.27 and P0.26, however, the numbers 26 and 27 are simply used, as 26 and 27...
hence my question, if I am accessing the pins correctly?
best.
  • Hi MuRa,
    sorry to place the reply here, this site sometimes does not show the reply button under recent tickets. ????
    F5 => P0.02
    F7 => P0.08
    Lets say I would like to assign the TWI, namely F5 = SDA and the F7 = SCL ... not really sure how to consider the in/out properties of the TWI.. with regard to the GPIO configuration...
    then just change some code in my given example (see earlier posts)
    const uint32_t scl_pin = NRF_GPIO_PIN_MAP(0, 2); /*port-0 pin2 (= F5) */
    const uint32_t sda_pin = NRF_GPIO_PIN_MAP(0, 8); /*port-0 pin8  (=F7) */
    By doing this the nrf52820 will route (internally) the pin F5/F7 not to the GPIO but to the TWImaster.
    so no worry about gpio input/output (they do not exist then.
    2nd question: about testing.
    I think about attaching a oscilloscope (or my favorite Saleae a logic analyzer) to the F5 and F7 and check the signals.
       nRF5xFanBoy
  • Hi MuRa,
    F5 => P0.02
    F7 => P0.08
       nRF5xFanBoy
