NCS: Setting MAC address to static for Mesh; UUID last bytes are zeroes
1. Is it possible to set MAC address from random to static for Mesh in nRF Connect SDK?
CONFIG_BT_PRIVACY=n and CONFIG_BT_SETTINGS=y seems does not change the behavior.
2. We have an issue with UUID, last bytes are zeroes in default configuration. Is it a bug or how to configure SDK to avoid this?
    I believe it should be possible but I will have to ask the Mesh team to verify this statement and if we have any configurations that allows for this. As for the config you're, the CONFIG_BT_PRIVACY should enable/disable the use of Resolvable Private Addresses, which is only one type of random address.
    How did you define and write the UUID? My guess is that the fault might be caused by how it is written in the code. Could you supply some code that illustrates how this is done in your application? If you're using a library for c-strings when defining the UUID, the string will be terminated when it reaches the first 0-byte in the string.
    Andreas
    To force mesh use a static address they can set BT_MESH_DEBUG_USE_ID_ADDR option. For changing address, call bt_id_create before bt_enable with the required address.
    Also, note that it is useful only for debugging purpose and not recommended to use it in actual products that are supposed to interop with other systems. If the app or such systems are made with assumption of mesh devices having static address, then such assumption won't hold good while dealing with third party devices.
    Andreas
  • Thank you for response Andreas.
    We want to use static MAC for troubleshooting our devices on the network. With static MAC we can identify our device (e.g. its location) and check for example corresponding RSSI values.
    Regarding UUID at the moment I am not completely sure, however this problem seems to appear in mesh sample projects, probably on /mesh/light sample.
    In case your previous reply is a question for me to answer, could you please reformulate it into a question? Otherwise I am wondering if my previous reply has answered your question?
    Andreas
  • Your suggested way of achieving static MAC also requires Logging to be enabled. Previously I justified our need to have static MAC, is there any other way to do so, or maybe it will be added in the future (that we could use for produced devices)?
    And regarding UUID I did not find time yet to double check if issue appears on the sample project I mentioned above, however we derived our project from the sample and as far as I remember UUID was always with trailing zeroes.
