PWM Waveform
Hello there.
I am wondering if PWM peripheral in waveform is able to generate a following sequence:
The idea, as you may see, is to generate a sequence with the same Duty Cycle (50%) and different Periods.
Best Regards, Genadi.
    you can have a look at our example,
    note to do different periods you need to restart PWM...
    But you can have a look at the wave counter, this might help you.
    Kaja
  • This might help:
    #define CYCLE_A  (2*1000)   // Some arbitrary number of clock cycles to match required resolution
    #define CYCLE_B  (2*2000)	// More clock cycles gets wider
    #define CYCLE_C  (2*3000)
    #define CYCLE_D  (2*4000)
    nrf_pwm_values_wave_form_t pecularSequence[] = {
      //   Index     Normal pin          Inverted     (Spare)  Top Value
      { /*   0  */   0x8000|(CYCLE_A/2), (CYCLE_A/2), 0,       CYCLE_A  },
      { /*   1  */   0x8000|(CYCLE_B/2), (CYCLE_B/2), 0,       CYCLE_B  },
      { /*   2  */   0x8000|(CYCLE_C/2), (CYCLE_C/2), 0,       CYCLE_C  },
      { /*   3  */   0x8000|(CYCLE_D/2), (CYCLE_D/2), 0,       CYCLE_D  },
    #define NUM_PWM_ITERATIONS  ( sizeof(pecularSequence)/sizeof(pecularSequence[0].channel_0) )
    #define NUM_PWM_TABLE_LINES ( sizeof(pecularSequence)/sizeof(pecularSequence[0]) )
    STATIC_ASSERT(sizeof(nrf_pwm_values_wave_form_t) == sizeof(pecularSequence[0]), "pecularSequence line size");
    //  NUM_PWM_ITERATIONS WaveLength (.CNT) is 15-bit Amount of values (duty cycles) in this sequence
