PCA10121 installation
Hi
I have two PCA10121 and followed the instructions here to get the demo audio application to work.
The output of:
python3 buildprog.py -c app -b debug -d both
is:
|    snr     | snr conn |  device | only reboot  | core app programmed | core net programmed |
| 1050156534 |   ←[32mTrue←[0m   | headset | Not selected |     Selected TBD    |     Not selected    |
| 1050158213 |   ←[32mTrue←[0m   | gateway | Not selected |     Selected TBD    |     Not selected    |
Invoking build step
Run: west build ../.. -b nrf5340_audio_dk_nrf5340_cpuapp -d ../../build/dev_headset/build_debug -DOVERLAY_CONFIG="overlay-headset.conf   overlay-debug.conf"
usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
west: error: argument <command>: invalid choice: 'build' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate')
  File "C:\Users\se\Desktop\projects\BT_Klaud\LE_Audio\nrf5340_audio\tools\buildprog\buildprog.py", line 319, in <module>
    __main()
  File "C:\Users\se\Desktop\projects\BT_Klaud\LE_Audio\nrf5340_audio\tools\buildprog\buildprog.py", line 302, in __main
    __build_module(build_cfg)
  File "C:\Users\se\Desktop\projects\BT_Klaud\LE_Audio\nrf5340_audio\tools\buildprog\buildprog.py", line 130, in __build_module
    raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 2
where cmake gives me the correct path to ..toolchains\v2.0.2\opt\bin\cmake.exe
Does someone know what could cause the error cmake error: 2?
Kind regards
Gerry
  • Hi Gerry,
    The west errors indicate that ZEPHYR_BASE variable has not been set in your environment. Have you tried to open the command prompt via the toolchain manager app? This should ensure the env. is correctly set up to build the sample.
    Vidar
  • Thanks Vidar, that solved the problem, but now there seems to be Kconfig issue. Any idea?
    python buildprog.py -c both -b release -d both -p
    | 1050156534 |   ←[32mTrue←[0m   | headset | Not selected |     Selected TBD    |     Selected TBD    |
    | 1050158213 |  ←[33mFalse←[0m   | gateway | Not selected |     Selected TBD    |     Selected TBD    |
    Invoking build step
    Net core uses precompiled hex
    Run: west build ../.. -b nrf5340_audio_dk_nrf5340_cpuapp -d ../../build/dev_headset/build_release -DOVERLAY_CONFIG="overlay-headset.conf   overlay-release.conf"
    -- Application: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio
    -- Using NCS Toolchain 2.0.2 for building. (C:/Users/se/Desktop/projects/BT_Klaud/toolchains/v2.0.2/cmake)
    -- Found Python3: C:/Users/se/Desktop/projects/BT_Klaud/toolchains/v2.0.2/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr/.cache
    -- Zephyr version: 3.0.99 (C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr)
    -- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
    -- Board: nrf5340_audio_dk_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.14.1 (C:/Users/se/Desktop/projects/BT_Klaud/toolchains/v2.0.2/opt/zephyr-sdk)
    -- Found dtc: C:/Users/se/Desktop/projects/BT_Klaud/toolchains/v2.0.2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: zephyr 0.14.1 (C:/Users/se/Desktop/projects/BT_Klaud/toolchains/v2.0.2/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/nrf5340_audio_dk_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/build/dev_headset/build_release/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/build/dev_headset/build_release/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/build/dev_headset/build_release/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/build/dev_headset/build_release/zephyr/dts.cmake
    warning: Experimental symbol NRF5340_AUDIO is enabled.
    warning: Experimental symbol BT_ISO_UNICAST is enabled.
    warning: Experimental symbol BT_ISO_SYNC_RECEIVER is enabled.
    warning: Experimental symbol BT_AUDIO is enabled.
    warning: Experimental symbol BT_VCS is enabled.
    C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig:78: warning: attempt to assign the value 'y' to the undefined symbol HW_CODEC_CIRRUS_LOGIC
    Parsing C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/Kconfig
    Loaded configuration 'C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/nrf/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/prj.conf'
    Merged configuration 'C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/overlay-headset.conf'
    Merged configuration 'C:/Users/se/Desktop/projects/BT_Klaud/LE_Audio/nrf5340_audio/overlay-release.conf'
    error: Aborting due to Kconfig warnings
    CMake Error at C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr/cmake/modules/kconfig.cmake:290 (message):
      command failed with return code: 1
      C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr/cmake/modules/zephyr_default.cmake:121 (include)
      C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:51 (include)
      C:/Users/se/Desktop/projects/BT_Klaud/v2.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:76 (include_boilerplate)
      CMakeLists.txt:13 (find_package)
    FATAL ERROR: command exited with status 1: 'C:\Users\se\Desktop\projects\BT_Klaud\toolchains\v2.0.2\opt\bin\cmake.EXE' '-DWEST_PYTHON=C:\Users\se\Desktop\projects\BT_Klaud\toolchains\v2.0.2\opt\bin\python.exe' '-BC:\Users\se\Desktop\projects\BT_Klaud\LE_Audio\nrf5340_audio\build\dev_headset\build_release' '-SC:\Users\se\Desktop\projects\BT_Klaud\LE_Audio\nrf5340_audio' -GNinja -DBOARD=nrf5340_audio_dk_nrf5340_cpuapp '-DOVERLAY_CONFIG=overlay-headset.conf   overlay-release.conf'
      File "buildprog.py", line 319, in <module>
        __main()
      File "buildprog.py", line 302, in __main
      File "buildprog.py", line 130, in __build_module
    Exception: cmake error: 1
    proj.conf
    # Copyright (c) 2022 Nordic Semiconductor ASA
    # General
    CONFIG_NRF5340_AUDIO=y
    CONFIG_REBOOT=y
    CONFIG_MAIN_THREAD_PRIORITY=10
    CONFIG_MAIN_STACK_SIZE=1940
    # Disable Zephyr HCI Vendor-Specific extensions
    CONFIG_BT_HCI_VS_EXT=n
    # As long as thread names are used, config must be set to "y"
    CONFIG_THREAD_NAME=y
    # Bluetooth
    CONFIG_BT_PRIVACY=n
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    # Make sure we have enough space to receive one frame of encoded data
    # The values set below are extended for higher BLE transmission capability
    CONFIG_BT_ISO_RX_MTU=190
    CONFIG_BT_ISO_TX_MTU=190
    CONFIG_BT_L2CAP_TX_BUF_COUNT=6
    CONFIG_BT_RX_STACK_SIZE=2000
    CONFIG_BT_BUF_ACL_RX_SIZE=259
    # Not supported on Packetcraft controller
    CONFIG_BT_ATT_ENFORCE_FLOW=n
    # Only do pairing without bonding
    CONFIG_BT_BONDABLE=n
    CONFIG_BT_AUDIO=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_PER_ADV=y
    CONFIG_BT_ISO_UNICAST=y
    CONFIG_BT_ISO_BROADCASTER=y
    CONFIG_BT_ISO_SYNC_RECEIVER=y
    # Temporary, enable the following to meet BT_ISO dependencies
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_PERIPHERAL=y
    # Audio sync timer
    CONFIG_NRFX_TIMER1=y
    CONFIG_NRFX_DPPI=y
    # Need to turn on SMP when involving services in LE audio profiles
    CONFIG_BT_SMP=y
    # Temporarily disabled connetion parameter and PHY update
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
    CONFIG_BT_AUTO_PHY_UPDATE=n
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=n
    # Required for calculating test tones
    CONFIG_CMSIS_DSP=y
    CONFIG_CMSIS_DSP_FASTMATH=y
    # Channel assignment writes to UICR
    CONFIG_NRFX_NVMC=y
    # Avoid multi-build system build network core firmware
    CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE=n
    # Workaround to not use fatal_error.c in NCS. Note that the system may still
    # reset on error depending on the build configuraion
    CONFIG_RESET_ON_FATAL_ERROR=n
    # use SBC codec GS
    CONFIG_SW_CODEC_SBC=y
    Kind regards Gerry
  • Hi Gerry,
    The build fails because the HW_CODEC_CIRRUS_LOGIC symbol is not defined. This symbol should be defined by the kconfig file in ncs/modules/hal/cirrus-logic/Kconfig.
    Please check if this module is included in your SDK, and if not, repeat the steps outlined here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/nrf5340_audio/README.html#setting-up-the-nrf5340-audio-repositories
    Vidar
