Hello, I'm developing firmware for our custom board with a nRF9160.
The problem I'm having is that the modem crashes with error code 0x10 sometimes (read: about every 3rd or 4th time) after its turned off and on again and we try to connect to mqtt.
Because it's supposed to be battery powered we take the modem offline when the application has collected its sensordata and sent to our cloud.
The board is then woken up after a set time or after one of two external interupts are triggered.
We used asset tracker v2 as a base for developing the application and the way we do the sleep is like following:
static void do_sleep(k_tid_t sleep_thread_id)
printk("modem::do_sleep(): disconnecting lte modem\n");
//lte_lc_power_off(); // dont power off, it should use about the same amp when in flight mode
lte_lc_offline();
DEFINE_DO_SLEEP(modem, MODEM_EVT_ERROR, sleep_thread_id);
state_set(STATE_DISCONNECTED);
int err = lte_connect();
if (err) {
LOG_ERR("Failed connecting to LTE, error: %d", err);
SEND_ERROR(modem, MODEM_EVT_ERROR, err);
#define DEFINE_DO_SLEEP(_mod, _evt, _id) SEND_SLEEP_ACK(self.id); \
state_set(STATE_SLEEP); \
printk("%s::do_sleep(): sleeping %s thread\n", STRINGIFY(_mod), STRINGIFY(_mod)); \
printk("%s::do_sleep(): sleep thread id: %p\n", STRINGIFY(_mod), _id); \
if (_id == NULL) \
printk("Sleep thread was null, something went wrong in the sleep sequence.\n"); \
SEND_ERROR(_mod, _evt, -1); \
return; \
k_thread_join(_id, K_FOREVER); \
module_wakeup(&self); \
printk("%s::do_sleep(): woke up\n", STRINGIFY(_mod));
static int lte_connect(void)
int err;
err = lte_lc_connect_async(lte_evt_handler);
if (err) {
LOG_ERR("lte_lc_connect_async, error: %d", err);
return err;
SEND_EVENT(modem, MODEM_EVT_LTE_CONNECTING);
LOG_INF("LTE attempting to connect... waiting %d seconds before timeout", MODEM_LTE_TIMEOUT_SEC);
k_work_reschedule(&connect_check_work, K_SECONDS(MODEM_LTE_TIMEOUT_SEC));
return 0;
The error message we get is the following:
[00:07:03.246,337] <err> modem_module: Modem error: 0x10, PC: 0xda418
Here it is in context:
modem::do_sleep(): woke up [00:06:59.014,251] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING [00:06:59.014,434] <inf> modem_module: LTE attempting to connect... waiting 120 seconds before timeout [00:06:59.902,587] <inf> app_event_manager: MODEM_EVT_LTE_RSRP_UPDATE [00:06:59.902,740] <inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED [00:07:00.582,489] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTED [00:07:00.582,733] <wrn> cloud_module: Cloud connection establishment in progress [00:07:00.582,733] <wrn> cloud_module: New connection attempt in 32 seconds if not successful [00:07:00.582,824] <inf> app_event_manager: CLOUD_EVT_CONNECTING [00:07:00.583,435] <inf> pp_cloud: Enabling TLS [00:07:00.594,451] <inf> app_event_manager: MODEM_EVT_LTE_RSRP_UPDATE [00:07:03.246,337] <err> modem_module: Modem error: 0x10, PC: 0xda418 [00:07:03.246,459] <err> pp_cloud: mqtt_connect, error: -110 [00:07:03.246,459] <err> pp_cloud: Cloud MQTT broker connect failed -110 [00:07:03.246,520] <inf> app_event_manager: CLOUD_EVT_DISCONNECTED [00:07:03.246,795] <inf> app_event_manager: CLOUD_EVT_CONNECTION_TIMEOUT [00:07:03.247,009] <wrn> cloud_module: Cloud connection establishment in progress [00:07:03.247,039] <wrn> cloud_module: New connection attempt in 32 seconds if not successful [00:07:03.247,161] <inf> app_event_manager: CLOUD_EVT_CONNECTING [00:07:03.247,406] <err> pp_cloud: getaddrinfo, error -1 [00:07:03.247,436] <err> pp_cloud: client_broker_init, error: -10 [00:07:03.247,497] <inf> app_event_manager: CLOUD_EVT_DISCONNECTED [00:07:03.481,109] <inf> modem_module: nRF9160 modem firmware version: mfw_nrf9160_1.2.7 [00:07:03.520,080] <inf> modem_module: LTE attempting to connect... waiting 120 seconds before timeout
When we first got the error it triggered the assert in nrf_to_z_dns_error_code assert because it got -1 from the modem (which is according to modem fault handling documentation).
That leads me to believe that the error happends in the nrf_getaddrinfo function (which is offloaded to the modem).
Can anyone make sense of the error based on the error code and PC? I'm kind of lost on where the debug at the moment :)
EDIT: I forgot to say that I'm experiencing this problem on a nRF9160 revision 0 using modem firmware 1.2.7, this also happends on 1.1.0.
Thanks in advance
