How to transmit more than 20 bytes with Python pc_ble_driver?
I have a BLE OTA application and I try to send data with the nRF52840 dongle and a Python application using the pc_ble_driver for Python. I have tested my MCU application with the nRF Connect for Desktop app and I´m able to transmit up to 216 bytes, but my Python application is reporting "NRF_ERROR_DATA_SIZE" when I try to send more than 20 bytes.
import sys
import time
import math
import logging
import argparse
import progressbar
from queue import Queue, Empty
from pc_ble_driver_py.observers import *
global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEUUIDBase, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
from pc_ble_driver_py import config
config.__conn_ic_id__ = "NRF52"
from pc_ble_driver_py.ble_driver import (
    BLEDriver,
    BLEAdvData,
    BLEEvtID,
    BLEEnableParams,
    BLEGapTimeoutSrc,
    BLEUUID,
    BLEUUIDBase,
    BLEGapScanParams,
    BLEConfigCommon,
    BLEConfig,
    BLEConfigConnGatt,
from pc_ble_driver_py.ble_adapter import BLEAdapter
global nrf_sd_ble_api_ver
nrf_sd_ble_api_ver = config.sd_api_ver_get()
class OTAConnector(BLEDriverObserver, BLEAdapterObserver):
    from enum import Enum
    class States(Enum):
        DEVICE_INFORMATION  = 0x01
        OTA_INIT            = 0x02
        OTA_DONE            = 0x03
    def __init__(self, adapter):
        super(OTAConnector, self).__init__()
        self.first = 1
        self.adapter = adapter
        self.conn_q = Queue()
        self.adapter.observer_register(self)
        self.adapter.driver.observer_register(self)
        self.adapter.default_mtu = 300
        self.ota_base = BLEUUIDBase([0x6e, 0x40, 0x00, 0x00, 0xb5, 0xa3, 0xf3, 0x93, 0xe0, 0xa9, 0xe5, 0x0e, 0x24, 0xdc, 0xca, 0x9e])
        self.ota_ctrl = BLEUUID(0x0002, self.ota_base)
        self.ota_data = BLEUUID(0x0003, self.ota_base)
        self.ota_info = BLEUUID(0x0004, self.ota_base)
        self.conn = None
    def open(self):
        self.adapter.driver.open()
        gatt_cfg = BLEConfigConnGatt()
        gatt_cfg.att_mtu = self.adapter.default_mtu
        gatt_cfg.tag = args.config
        self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
        self.adapter.driver.ble_enable()
        self.adapter.driver.ble_vs_uuid_add(self.ota_base)
    def close(self):
        self.adapter.driver.close()
    def connect_and_discover(self, ScanDuration = 5):
        self.adapter.driver.ble_gap_scan_start(scan_params = BLEGapScanParams(interval_ms = 200, window_ms = 150, timeout_s = ScanDuration))
        try:
            self.conn = self.conn_q.get(timeout = ScanDuration)
            self.adapter.service_discovery(self.conn)
            self.adapter.enable_notification(self.conn, self.ota_ctrl)
            self.adapter.enable_notification(self.conn, self.ota_info)
            return True
        except Empty:
            print("No device advertising with name {} found.".format(args.device))
            return False
    def run_ota(self, file):
        if(self.conn == None):
            return False
        try:
            print("Opening {}...".format(file))
            with open(file, "rb") as File:
                # Get the device information
                self.adapter.write_cmd(self.conn, self.ota_ctrl, [OTAConnector.States.DEVICE_INFORMATION.value])
                # Get the total length of the firmware file
                CurrentPos = File.tell()
                FileSize = File.seek(0, 2)
                File.seek(CurrentPos, 0)
                print("File size: {} bytes".format(FileSize))
                print("Packages: {}".format(math.ceil(FileSize / args.size)))
                # Set the packet size
                self.adapter.write_cmd(self.conn, self.ota_data, args.size.to_bytes(2, "little"))
                self.adapter.write_cmd(self.conn, self.ota_ctrl, [OTAConnector.States.OTA_INIT.value])
                time.sleep(2)
                # Process the OTA update
                Bar = progressbar.ProgressBar(max_value = FileSize)
                Transmit = 0
                while(FileSize > 0):
                    Bytes = File.read(args.size)
                    self.adapter.write_cmd(self.conn, self.ota_data, Bytes)
                    FileSize -= args.size
                    Transmit += args.size
                    Bar.update(Transmit)
                # Finish the OTA update
                self.adapter.write_cmd(self.conn, self.ota_ctrl, [OTAConnector.States.OTA_DONE.value])
                return True
        except Exception as e:
            print("{}".format(e))
            return False
    def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, status, att_mtu):
        print("ATT MTU updated to {}".format(att_mtu))
    def on_gap_evt_data_length_update(self, ble_driver, conn_handle, data_length_params):
        print("Max rx octets: {}".format(data_length_params.max_rx_octets))
        print("Max tx octets: {}".format(data_length_params.max_tx_octets))
        print("Max rx time: {}".format(data_length_params.max_rx_time_us))
        print("Max tx time: {}".format(data_length_params.max_tx_time_us))
    def on_gatts_evt_exchange_mtu_request(self, ble_driver, conn_handle, client_mtu):
        print("Client requesting to update ATT MTU to {} bytes".format(client_mtu))
    def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
        print("New connection: {}".format(conn_handle))
        self.conn_q.put(conn_handle)
    def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
        print("Disconnected: {} {}".format(conn_handle, reason))
    def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
        if(BLEAdvData.Types.complete_local_name in adv_data.records):
            dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
        elif(BLEAdvData.Types.short_local_name in adv_data.records):
            dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
        else:
            return
        dev_name = "".join(chr(e) for e in dev_name_list)
        address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
        print("Received advertisment report, address: 0x{}, device_name: {}".format(address_string, dev_name))
        if(dev_name == args.device):
            self.adapter.connect(peer_addr, tag = args.config)
    def on_notification(self, ble_adapter, conn_handle, uuid, data):
        data = "({}...)".format(data[0:10])
        print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
if(__name__ == "__main__"):
    driver = BLEDriver(serial_port = args.port, auto_flash = False, baud_rate = args.baud, log_severity_level = "info")
    adapter = BLEAdapter(driver)
    collector = OTAConnector(adapter)
    collector.open()
    if(collector.connect_and_discover() == True):
        print("Device found. Start OTA...")
        Result = collector.run_ota(args.input)
        print("Update successful: {}".format(Result))
    collector.close()
    quit()
How can I increase the transmission length?
