Provisioning the nRF Cloud Certificate to nrf9160-chip
Is it possible to download the Certificate from a file or memory to chip with the internal SDK function?
I intend to automate the installation of the certificate on the device.
I am using nRF SDK v2.0.2.
I can't find exact information anywhere about the internal interface where the certificate can be loaded onto the chip..
    Yes, you can see how it is done in asset_tracker_v2/src/cloud-certs.
  • I can't find any solution here!
    Can you give the name of the function?
  • I found this code:
    /* Provisions root CA certificate using modem_key_mgmt API */
    static int nct_provision(void)
    	static sec_tag_t sec_tag_list[] = { CONFIG_NRF_CLOUD_SEC_TAG };
    	nct.tls_config.peer_verify = 2;
    	nct.tls_config.cipher_count = 0;
    	nct.tls_config.cipher_list = NULL;
    	nct.tls_config.sec_tag_count = ARRAY_SIZE(sec_tag_list);
    	nct.tls_config.sec_tag_list = sec_tag_list;
    	nct.tls_config.hostname = NRF_CLOUD_HOSTNAME;
    #if defined(CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES)
    #if defined(CONFIG_NRF_MODEM_LIB)
    		int err;
    		/* Delete certificates */
    		nrf_sec_tag_t sec_tag = CONFIG_NRF_CLOUD_SEC_TAG;
    		for (enum modem_key_mgmt_cred_type type = 0; type < 5;
    		     type++) {
    			err = modem_key_mgmt_delete(sec_tag, type);
    			LOG_DBG("modem_key_mgmt_delete(%u, %d) => result = %d",
    				sec_tag, type, err);
    		/* Provision CA Certificate. */
    		err = modem_key_mgmt_write(CONFIG_NRF_CLOUD_SEC_TAG,
    					   MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
    					   ca_certificate,
    					   strlen(ca_certificate));
    		if (err) {
    			LOG_ERR("ca_certificate err: %d", err);
    			return err;
    		/* Provision Private Certificate. */
    			MODEM_KEY_MGMT_CRED_TYPE_PRIVATE_CERT,
    			private_key,
    			strlen(private_key));
    		if (err) {
    			LOG_ERR("private_key err: %d", err);
    			return err;
    		/* Provision Public Certificate. */
    			MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT,
    			device_certificate,
    			strlen(device_certificate));
    		if (err) {
    			LOG_ERR("device_certificate err: %d",
    				err);
    			return err;
    #else
    		int err;
    		err = tls_credential_add(CONFIG_NRF_CLOUD_SEC_TAG,
    					 TLS_CREDENTIAL_CA_CERTIFICATE,
    					 ca_certificate,
    					 sizeof(ca_certificate));
    		if (err < 0) {
    			LOG_ERR("Failed to register ca certificate: %d", err);
    			return err;
    					 TLS_CREDENTIAL_PRIVATE_KEY,
    					 private_key,
    					 sizeof(private_key));
    		if (err < 0) {
    			LOG_ERR("Failed to register private key: %d", err);
    			return err;
    			TLS_CREDENTIAL_SERVER_CERTIFICATE,
    			device_certificate,
    			sizeof(device_certificate));
    		if (err < 0) {
    			LOG_ERR("Failed to register public certificate: %d",
    				err);
    			return err;
    #endif /* defined(CONFIG_NRF_MODEM_LIB) */
    #endif /* defined(CONFIG_NRF_CLOUD_PROVISION_CERTIFICATES) */
    	return 0;
    Could I have an example of how to use this?
  • Yes, the asset_tracker_v2 that I referred to is a good example for how certificates can be provisioned from a file.
    modem_key_mgmt_write(), or you can use the AT%CMNG command to store certificates.
