Wakeup immediately from sd_app_evt_wait() with external LFCLK
Hi all
We use the nRF51822 with the S130 V1.0.0. Our application initializes the TIMER2 (f = 16MHz) with a EVENTS_COMPARE interrupt on the CC channel 1 to monitor some timings.
Afterwards the SoftDevice is enabled with the LFCLK source "NRF_CLOCK_LFCLKSRC_XTAL_20_PPM". The TIMER2 stays running.
Later on, we want to reduce the power consumption. Therefore we disable the TIMER2 with the following code:
   NRF_TIMER2->TASKS_STOP = 1;
   NRF_TIMER2->TASKS_SHUTDOWN = 1;
   NVIC_DisableIRQ(TIMER2_IRQn);
   NVIC_ClearPendingIRQ(TIMER2_IRQn);
Afterwards we call the function sd_app_evt_wait() but the nRF51822 wakes up immediately. The strange thing is, that when I change the LFCLK source at the SoftDevice initialization to "NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_4000MS_CALIBRATION", the nRF51822 stays in the low power mode. Therefore there should be no event/interrupt in our application that awakes the chip.
Further observations are:
  • When we disable the TIMER2 before initializing the SoftDevice (LFCLK source is the XTAL) everything works fine
  • When we initialize the TIMER2 after initializing the SoftDevice (LFCLK source is the XTAL) everything works fine too
Is there a problem when the TIMER2 is running during the SD init in combination with the LF crystal? Does anyone know this behavior?
EDIT: I've added a stripped-down version of our application to reproduce this behavior:
Function to enable the query-timer:
static void query_timer_init(void)
   // :NOTE:
   //    Currently the following capture/compare channels are used:
   //       - Channel 0: Used to capture the timer value
   //       - Channel 1: Used to handle the overflow of the 16bit timer
   // Stop the timer before the configuration
   // Init module variables
   gTIMER2_high_word = 0;
   // Configure TIMER2 in timer mode with 16 bits
   NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
   NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
   // Use 16 MHz (disable the prescaler)
   // -> f = HFCLK / (2 ^ prescaler_value)
   NRF_TIMER2->PRESCALER = 0;
   // Clear the timer before using it
   NRF_TIMER2->TASKS_CLEAR = 1;
   // Setup capture/compare channel 1 for timer overflow
   NRF_TIMER2->CC[1] = 0xFFFF;
   NRF_TIMER2->EVENTS_COMPARE[1] = 0;
   NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
   // Enable interrupt for timer 2
   NVIC_SetPriority(TIMER2_IRQn, APP_IRQ_PRIORITY_HIGH);
   NVIC_EnableIRQ(TIMER2_IRQn);
   // Start the timer
   NRF_TIMER2->TASKS_START = 1;
Function to disable the query-timer:
static void query_timer_disable(void)
   // Stop the timer
   // Shutdown the timer module
   // Disable and clear the timer interrupt
The main function:
int32_t main(void)
   uint32_t sd_stat = NRF_SUCCESS;
   ble_enable_params_t ble_enable_params;
   // Initialize the query timer
   query_timer_init();
   // Init the SoftDevice
   sd_stat = sd_softdevice_enable(
      //NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_4000MS_CALIBRATION, NULL); // -> OK
      NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);                          // -> NOK
   if (sd_stat != NRF_SUCCESS) {goto exception;}
   // Init the BLE stack
   ble_enable_params.gatts_enable_params.service_changed = 0;
   ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
   sd_stat = sd_ble_enable(&ble_enable_params);
   // Disable the query timer
   query_timer_disable();
   // Activate the system ON low power mode
   sd_stat = sd_app_evt_wait();
   // -> This point should not be reached since there is no enabled wakeup source!
   // Re-enable the query timer
   query_timer_init();
   // the main loop
   while (1) {}
   // -> Should never reach this point!
exception:
   while (sd_stat != NRF_SUCCESS) {}
   return 0;
Kind regards
  • Thanks for the clarification of application events! I know that I could keep it the way it works with disabling and enabling the timer :-) But I would like to know if there is something that I am doing wrong in my code or if there is hiccup in the softdevice initialization when an interrupt occurs at the wrong moment? Many thanks for your effort!
