Wakeup immediately from sd_app_evt_wait() with external LFCLK
Hi all
We use the nRF51822 with the S130 V1.0.0. Our application initializes the TIMER2 (f = 16MHz) with a EVENTS_COMPARE interrupt on the CC channel 1 to monitor some timings.
Afterwards the SoftDevice is enabled with the LFCLK source "NRF_CLOCK_LFCLKSRC_XTAL_20_PPM". The TIMER2 stays running.
Later on, we want to reduce the power consumption. Therefore we disable the TIMER2 with the following code:
   NRF_TIMER2->TASKS_STOP = 1;
   NRF_TIMER2->TASKS_SHUTDOWN = 1;
   NVIC_DisableIRQ(TIMER2_IRQn);
   NVIC_ClearPendingIRQ(TIMER2_IRQn);
Afterwards we call the function sd_app_evt_wait() but the nRF51822 wakes up immediately. The strange thing is, that when I change the LFCLK source at the SoftDevice initialization to "NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_4000MS_CALIBRATION", the nRF51822 stays in the low power mode. Therefore there should be no event/interrupt in our application that awakes the chip.
Further observations are:
  • When we disable the TIMER2 before initializing the SoftDevice (LFCLK source is the XTAL) everything works fine
  • When we initialize the TIMER2 after initializing the SoftDevice (LFCLK source is the XTAL) everything works fine too
Is there a problem when the TIMER2 is running during the SD init in combination with the LF crystal? Does anyone know this behavior?
EDIT: I've added a stripped-down version of our application to reproduce this behavior:
Function to enable the query-timer:
static void query_timer_init(void)
   // :NOTE:
   //    Currently the following capture/compare channels are used:
   //       - Channel 0: Used to capture the timer value
   //       - Channel 1: Used to handle the overflow of the 16bit timer
   // Stop the timer before the configuration
   // Init module variables
   gTIMER2_high_word = 0;
   // Configure TIMER2 in timer mode with 16 bits
   NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
   NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
   // Use 16 MHz (disable the prescaler)
   // -> f = HFCLK / (2 ^ prescaler_value)
   NRF_TIMER2->PRESCALER = 0;
   // Clear the timer before using it
   NRF_TIMER2->TASKS_CLEAR = 1;
   // Setup capture/compare channel 1 for timer overflow
   NRF_TIMER2->CC[1] = 0xFFFF;
   NRF_TIMER2->EVENTS_COMPARE[1] = 0;
   NRF_TIMER2->INTENSET = (TIMER_INTENSET_COMPARE1_Enabled << TIMER_INTENSET_COMPARE1_Pos);
   // Enable interrupt for timer 2
   NVIC_SetPriority(TIMER2_IRQn, APP_IRQ_PRIORITY_HIGH);
   NVIC_EnableIRQ(TIMER2_IRQn);
   // Start the timer
   NRF_TIMER2->TASKS_START = 1;
Function to disable the query-timer:
static void query_timer_disable(void)
   // Stop the timer
   // Shutdown the timer module
   // Disable and clear the timer interrupt
The main function:
int32_t main(void)
   uint32_t sd_stat = NRF_SUCCESS;
   ble_enable_params_t ble_enable_params;
   // Initialize the query timer
   query_timer_init();
   // Init the SoftDevice
   sd_stat = sd_softdevice_enable(
      //NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_4000MS_CALIBRATION, NULL); // -> OK
      NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);                          // -> NOK
   if (sd_stat != NRF_SUCCESS) {goto exception;}
   // Init the BLE stack
   ble_enable_params.gatts_enable_params.service_changed = 0;
   ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
   sd_stat = sd_ble_enable(&ble_enable_params);
   // Disable the query timer
   query_timer_disable();
   // Activate the system ON low power mode
   sd_stat = sd_app_evt_wait();
   // -> This point should not be reached since there is no enabled wakeup source!
   // Re-enable the query timer
   query_timer_init();
   // the main loop
   while (1) {}
   // -> Should never reach this point!
exception:
   while (sd_stat != NRF_SUCCESS) {}
   return 0;
Kind regards
  • I don't see either what the choice of the LFCLK source has to do with this issue, but that's exactly the problem I am seeing. When I choose the RC oscillator at the SD init, the chip does NOT awake after the function call sd_app_event_wait(). But when I choose the LF crystal, the chip awakes immediately.
    And another interesting thing is that when I initialize my query timer after the initialization of the SoftDevice, the chip stays sleeping even when I choose the LF crystal.
  • It is possible that when you choose different 'lfclk with calibration option, it takes little more time (few cycles) to setup calibration timer and this changes the timing and the state of Program counter when the application event occurs.
    Important thing to note as RK already mentioned is that this wait for event in this scenario does not suit well if they are not called in a loop.
  • I also tried different waiting times (e.g. 500ms) before and after the initialization of the softdevice, but it didn't help. Is an interrupt of the Timer2 also an application event? Maybe I understand the term application event wrong. Can you please explain by what application events are generated? Or do you see in my code the source of this event?
    Is it safer when the Timer2 is not running during the softdevice initialization? Because when I disabled the query timer before the SD init and re-enabled it afterwards, the problem didn't occur anymore.
  • Any event or interrupts that are caused by modules not used by softdevice are application events. For example RTC0, RNG, RADIO etc are used directly and only by softdevice, so any interrupts caused by these modules are not application events. Timer2 is application module and not used by SD, so its interrupt is application event.
    I have no clue why disabling of timer and enabling it after softdevice initialization works. But if it works, then keep it that way :)
  • Thanks for the clarification of application events! I know that I could keep it the way it works with disabling and enabling the timer :-) But I would like to know if there is something that I am doing wrong in my code or if there is hiccup in the softdevice initialization when an interrupt occurs at the wrong moment? Many thanks for your effort!
