Error on commissioning step 'FindOperational' while pairing matter sample over ble-thread
I'm following this tutorial https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrf/ug_matter.html - I use the nrf52840 dongle as a co-processor connected to a raspberry pi running OTBR, nrf52840 DK flashed with matter door lock sample and I downloaded chip tool (release version 2.0.0) on my laptop with Linux. I want to connect the door lock sample to OTBR as described here. Unfortunately, step 6 causes the problem. When I execute this command:
./chip-tool-release pairing ble-thread 1000 hex:0e080000000000010000000300000f35060004001fffe0020811111111222222220708fd05128ef262a22b051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0f7f8 20202021 3840
I get the following error:
CHIP:DIS: Operational discovery failed for 0x00000000000003E8: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:174: CHIP Error 0x00000032: Timeout
and I have no idea what should be wrong. (Does it mean there is something wrong with OTBR? But if I execute `service otbr-agent status` on raspberry pi I get otbr-agent is running and for command  `ot-ctl state` the response is Leader.
Can anybody help me figure it out? Thank you.
If you want to see full output from the command, you can find it here.
  • Hi Charlie,
    thank you for your reply. This shouldn't be my case, because I have never successfully commissioned a device. Anyway, I tried to update my OTBR to the newest version (nrfconnect/otbr:1813352) and used the Node ID I never used. Unfortunately, I'm getting the same error.
    Maybe I forget to mention that I'm using OTBR within docker-compose with the following config:
    version: '3.0'
    networks:
      otbr:
        external: true
    services:
      otbr:
        container_name: otbr
        image: nrfconnect/otbr:1813352
        privileged: true
        networks:
          - otbr
        volumes:
          - /dev/ttyACM0:/dev/radio
        ports:
          - 8080:80
        sysctls:
          - net.ipv6.conf.all.disable_ipv6=0
          - net.ipv4.conf.all.forwarding=1
          - net.ipv6.conf.all.forwarding=1
        command: --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
    EDIT: One more thing I noticed: In OTBR frontend, I cannot load topology, it's still loading. I would expect there will be only the connected co-processor as a leader.
  • Hi Filipmrazek,
    Here are some suggestions for your debugging:
    1) Ensure that the chip-tool cache is cleaned after each unsuccessful command:
    rm -rf /tmp/chip_*
    2) Ensure that the RPi OS is 64 bit (we use Ubuntu 20.04 LTS 64 bit on daily basis, this distro is also used for Matter certification)
    3) It might be that the docker setup blocks the router advertisements on the RPi. Following lines may help is such a case (run on RPi host, replace the wlan0 with proper WiFi iface name if needed):
    sudo sysctl net.ipv6.conf.wlan0.accept_ra=2
    sudo sysctl net.ipv6.conf.wlan0.accept_ra_rt_info_max_plen=128
    4) Also I advice to run the otbr container in the following fashion on the RPi:
    sudo docker run --rm -it --privileged -d --network host --name otbr --volume /dev/ttyACM0:/dev/ttyACM0 nrfconnect/otbr:1813352 --radio-url spinel+hdlc+uart:///dev/ttyACM0 -B wlan0
    Charlie
  • Hi Charlie,
    I followed your suggestions and it works!
    I tried several things which didn't help:
    • tried to clean the chip-tool cache
    • already had 64-bit Ubuntu 20.04 on my RPi, so I tried to install OTBR also on Intel NUC with Ubuntu 20.04, but it gave me the same error.
    • tried to add suggested sysctls to docker-compose config
    • tried docker run command  in the tutorial here
    Then I tried your command for running the docker container and it worked! To find out which part is causing the problem I tried many variations of your command and it seems to me it's a combination of host network (custom network is used in the tutorial) and using -B nps1s0 in the command.
    Thank you for your help!
    Anyway, I've got one more question.  After successful pairing, I can control my device using for example
    sudo ./chip-tool-release doorlock unlock-door 7 1 --timedInteractionTimeoutMs 100
    but after I reset my laptop with chip-tool, I get the following error when trying to interact with the paired device:
    [1663513504.010477][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_kvs-QnevCm)
    [1663513504.010548][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_kvs)
    [1663513504.010703][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-9iGebm)
    [1663513504.010753][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1663513504.010806][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_config.ini-6eYnyn)
    [1663513504.010853][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1663513504.010901][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-d97uin)
    [1663513504.010948][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1663513504.011017][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-rmsSSn)
    [1663513504.011142][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1663513504.011158][5676:5676] CHIP:DL: NVS set: chip-factory/unique-id = "F7A36C44BF44AC4B"
    [1663513504.011199][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-MI7Dmm)
    [1663513504.011314][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1663513504.011329][5676:5676] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
    [1663513504.011365][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-QqrM3m)
    [1663513504.011471][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
    [1663513504.011487][5676:5676] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
    [1663513504.011523][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-dcFbVn)
    [1663513504.011610][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1663513504.011625][5676:5676] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
    [1663513504.011661][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-7bKXPo)
    [1663513504.011757][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1663513504.011772][5676:5676] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1663513504.011813][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-Z68VPo)
    [1663513504.011910][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1663513504.011928][5676:5676] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
    [1663513504.011961][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_config.ini-Gxh2Ep)
    [1663513504.012048][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1663513504.012065][5676:5676] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
    [1663513504.012102][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_config.ini-4nBt2o)
    [1663513504.012253][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
    [1663513504.012279][5676:5676] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
    [1663513504.012829][5676:5676] CHIP:DL: Got Ethernet interface: enp9s0
    [1663513504.013315][5676:5676] CHIP:DL: Found the primary Ethernet interface:enp9s0
    [1663513504.013795][5676:5676] CHIP:DL: Got WiFi interface: wlp8s0
    [1663513504.014840][5676:5676] CHIP:DL: Found the primary WiFi interface:wlp8s0
    [1663513504.015313][5676:5676] CHIP:ZCL: Using ZAP configuration...
    [1663513504.017375][5676:5676] CHIP:DL: Avahi client registered
    [1663513504.018830][5676:5676] CHIP:CTL: Setting attestation nonce to random value
    [1663513504.018858][5676:5676] CHIP:CTL: Setting CSR nonce to random value
    [1663513504.018920][5676:5676] CHIP:CTL: Setting attestation nonce to random value
    [1663513504.018931][5676:5676] CHIP:CTL: Setting CSR nonce to random value
    [1663513504.019111][5676:5676] CHIP:CTL: Couldn't get ExampleOpCredsCAKey from storage: ../../examples/chip-tool/config/PersistentStorage.cpp:108: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1663513504.022092][5676:5676] CHIP:CTL: Couldn't get ExampleOpCredsICAKey from storage: ../../examples/chip-tool/config/PersistentStorage.cpp:108: CHIP Error 0x000000A0: Value not found in the persisted storage
    [1663513504.022505][5676:5676] CHIP:CTL: Generating RCAC
    [1663513504.022788][5676:5676] CHIP:CTL: Generating ICAC
    [1663513504.023049][5676:5676] CHIP:CTL: Generating NOC
    [1663513504.023727][5676:5676] CHIP:DIS: Verifying the received credentials
    [1663513504.024229][5676:5676] CHIP:DIS: Added new fabric at index: 0x1, Initialized: 1
    [1663513504.024238][5676:5676] CHIP:DIS: Assigned compressed fabric ID: 0xD0430A4B4679D9C7, node ID: 0x000000000001B669
    [1663513504.025366][5676:5676] CHIP:DIS: Fabric (1) persisted to storage. Calling OnFabricPersistedToStorage
    [1663513504.025542][5676:5676] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0xD0430A4B4679D9C7
    [1663513504.025578][5676:5676] CHIP:CTL: Setting attestation nonce to random value
    [1663513504.025605][5676:5676] CHIP:CTL: Setting CSR nonce to random value
    [1663513504.026002][5676:5676] CHIP:CTL: Generating NOC
    [1663513504.026289][5676:5676] CHIP:DIS: Verifying the received credentials
    [1663513504.026818][5676:5676] CHIP:DIS: Added new fabric at index: 0x2, Initialized: 1
    [1663513504.026831][5676:5676] CHIP:DIS: Assigned compressed fabric ID: 0x7F29D9201A48EA8B, node ID: 0x000000000001B669
    [1663513504.028127][5676:5676] CHIP:DIS: Fabric (2) persisted to storage. Calling OnFabricPersistedToStorage
    [1663513504.028341][5676:5676] CHIP:CTL: Joined the fabric at index 2. Compressed fabric ID is: 0x7F29D9201A48EA8B
    [1663513504.028379][5676:5676] CHIP:CTL: Setting attestation nonce to random value
    [1663513504.028396][5676:5676] CHIP:CTL: Setting CSR nonce to random value
    [1663513504.028754][5676:5676] CHIP:CTL: Generating NOC
    [1663513504.029019][5676:5676] CHIP:DIS: Verifying the received credentials
    [1663513504.029609][5676:5676] CHIP:DIS: Added new fabric at index: 0x3, Initialized: 1
    [1663513504.029620][5676:5676] CHIP:DIS: Assigned compressed fabric ID: 0x692D05399609C116, node ID: 0x000000000001B669
    [1663513504.030652][5676:5676] CHIP:DIS: Fabric (3) persisted to storage. Calling OnFabricPersistedToStorage
    [1663513504.030866][5676:5676] CHIP:CTL: Joined the fabric at index 3. Compressed fabric ID is: 0x692D05399609C116
    [1663513504.053079][5676:5686] CHIP:TOO: Sending command to node 0x9
    [1663513504.053107][5676:5686] CHIP:DIS: Resolving D0430A4B4679D9C7:0000000000000009 ...
    [1663513504.253958][5676:5686] CHIP:DIS: Checking node lookup status after 201 ms
    [1663513509.056111][5676:5686] CHIP:DL: Re-trying resolve
    [1663513514.053429][5676:5676] CHIP:DIS: Cancelling incomplete address resolution as device is being deleted.
    [1663513514.053496][5676:5676] CHIP:DIS: Discovery does not require any more timeouts
    [1663513514.054750][5676:5676] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1663513514.055019][5676:5676] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-ZzlNVn)
    [1663513514.055547][5676:5676] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1663513514.055855][5676:5676] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1663513514.056093][5676:5676] CHIP:DL: Inet Layer shutdown
    [1663513514.056117][5676:5676] CHIP:DL: BLE shutdown
    [1663513514.056136][5676:5676] CHIP:DL: System Layer shutdown
    [1663513514.056395][5676:5676] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/common/CHIPCommand.cpp:397: CHIP Error 0x00000032: Timeout
    What should I do to control the device after resetting the laptop with chip-tool?
    Thank you.
  • Hi Filipmrazek,
    I try to understand your issue. Do you mean that you run the following after your laptop is reset, and then you get the log you shared?
    If not, could you descript the detail steps you did that can repeat the issue?
    `sudo ./chip-tool-release doorlock unlock-door 7 1 --timedInteractionTimeoutMs 100`
    Charlie
  • Hi Charlie,
    my setup:
    • nrf52840 dk flashed with doorlock example
    • intel nuc with ubuntu 20.04 running OTBR (with nrf52840 dongle coprocessor)
    • laptop with ubuntu 20.04 on which I execute chip-tool
    What I do:
    1. pair nrf52840 dk with doorlock example with the following command:
      sudo ./chip-tool-release pairing ble-thread 1 hex:<operational> 20202021 3840
    2. after successful pairing, I try to send a command to unlock the door to test if everything works with the following command:
      sudo ./chip-tool-release doorlock unlock-door 1 1 --timedInteractionTimeoutMs 100
    3. the nrf52840 indicates that the door is unlocked - everything works
    4. reset my laptop
    5. try to control nrf52840 dk (lock / unlock door) with the same command as in step 2, but it does not work - log from chip-tool is in my previous post
    Filip
