Error on commissioning step 'FindOperational' while pairing matter sample over ble-thread
I'm following this tutorial https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrf/ug_matter.html - I use the nrf52840 dongle as a co-processor connected to a raspberry pi running OTBR, nrf52840 DK flashed with matter door lock sample and I downloaded chip tool (release version 2.0.0) on my laptop with Linux. I want to connect the door lock sample to OTBR as described here. Unfortunately, step 6 causes the problem. When I execute this command:
./chip-tool-release pairing ble-thread 1000 hex:0e080000000000010000000300000f35060004001fffe0020811111111222222220708fd05128ef262a22b051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0f7f8 20202021 3840
I get the following error:
CHIP:DIS: Operational discovery failed for 0x00000000000003E8: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:174: CHIP Error 0x00000032: Timeout
and I have no idea what should be wrong. (Does it mean there is something wrong with OTBR? But if I execute `service otbr-agent status` on raspberry pi I get otbr-agent is running and for command  `ot-ctl state` the response is Leader.
Can anybody help me figure it out? Thank you.
If you want to see full output from the command, you can find it here.
  • Hi Filipmrazek,
    I got some explanation from our development team about your observation:
    If the customer does not recommission the device after rebooting the PC which runs the chip-tool, it will not work. The default chip-tool caches all network data in `/tmp`which works like volatile memory and is cleaned with each reboot. There is not an out-of-the-box solution which would allow changing the storage type in chip-tool, and it's not possible to change the storage or the system path without altering the chip-tool source code. But note that chip-tool is more like a testing tool. In a real scenario, the ecosystem controller will most likely still be able to talk to the Matter device after it is rebooted.
    Charlie
  • Hi Charlie,
    thank you for your answer. If I understand your answer correctly, do I have to factory reset the nrf52840 dk and pair it again after reboot?
    I understand that chip-tool is only a testing tool, but it would be nice if I could change the cache location. It's really annoying if developers want to test their network for a few days.
    BTW: Is it possible to run chip-tool inside docker container with mounted volume (like -v /path/to/chache/:/tmp)? Then OS will not remove the cache. I can try it later and post the result if it's working.
  • Hi Filipmrazek,
    Matter is still in an active development stage. You can raise a request from here:
    Issues · project-chip/connectedhomeip (github.com)
    Charlie
  • Hey hello, I'm trying to commission nanoleaf Matter bulb using OTBR in docker and chip-tool in my linux Ubuntu 22.04. Could you please look into my error and help me getting resolve of it
    Tools :
    1)Nanoleaf Matter Bulb A60
    2)Chip-tool downloaded from https://github.com/nrfconnect/sdk-connectedhomeip/releases for ubuntu x64 machine
    3)OTBR in docker, I followed this link
    4)nRF52840 dongle programmed using this link https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.99-dev1/matter/openthread_rcp_nrf_dongle.html
    The chip-tool log:
    [1688390344.566519][22573:22575] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1688390344.566537][22573:22575] CHIP:CTL: Received ArmFailSafe response errorCode=0
    [1688390344.566549][22573:22575] CHIP:CTL: Successfully finished commissioning step 'FailsafeBeforeThreadEnable'
    [1688390344.566559][22573:22575] CHIP:CTL: Commissioning stage next step: 'FailsafeBeforeThreadEnable' -> 'ThreadNetworkEnable'
    [1688390344.566570][22573:22575] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
    [1688390344.566607][22573:22575] CHIP:DMG: ICR moving to [AddingComm]
    [1688390344.566619][22573:22575] CHIP:DMG: ICR moving to [AddedComma]
    [1688390344.566659][22573:22575] CHIP:EM: <<< [E:55451i S:3373 M:123627894] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1688390344.566674][22573:22575] CHIP:IN: (S) Sending msg 123627894 on secure session with LSID: 3373
    [1688390344.566862][22573:22575] CHIP:DMG: ICR moving to [CommandSen]
    [1688390344.566897][22573:22575] CHIP:DMG: ICR moving to [AwaitingDe]
    [1688390344.655738][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390345.907482][22573:22575] CHIP:BLE: BLE scan error: src/platform/Linux/bluez/ChipDeviceScanner.cpp:154: CHIP Error 0x00000032: Timeout
    [1688390345.916148][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390345.916236][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390345.916332][22573:22575] CHIP:EM: >>> [E:55451i S:3373 M:68425704] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1688390345.916348][22573:22575] CHIP:EM: Found matching exchange: 55451i, Delegate: 0x7fdab806f718
    [1688390345.916361][22573:22575] CHIP:DMG: ICR moving to [ResponseRe]
    [1688390345.916385][22573:22575] CHIP:DMG: InvokeResponseMessage =
    [1688390345.916390][22573:22575] CHIP:DMG: {
    [1688390345.916396][22573:22575] CHIP:DMG: 	suppressResponse = false,
    [1688390345.916404][22573:22575] CHIP:DMG: 	InvokeResponseIBs =
    [1688390345.916421][22573:22575] CHIP:DMG: 	[
    [1688390345.916430][22573:22575] CHIP:DMG: 		InvokeResponseIB =
    [1688390345.916447][22573:22575] CHIP:DMG: 		{
    [1688390345.916456][22573:22575] CHIP:DMG: 			CommandDataIB =
    [1688390345.916468][22573:22575] CHIP:DMG: 			{
    [1688390345.916477][22573:22575] CHIP:DMG: 				CommandPathIB =
    [1688390345.916488][22573:22575] CHIP:DMG: 				{
    [1688390345.916501][22573:22575] CHIP:DMG: 					EndpointId = 0x0,
    [1688390345.916513][22573:22575] CHIP:DMG: 					ClusterId = 0x31,
    [1688390345.916524][22573:22575] CHIP:DMG: 					CommandId = 0x7,
    [1688390345.916535][22573:22575] CHIP:DMG: 				},
    [1688390345.916549][22573:22575] CHIP:DMG:
    [1688390345.916559][22573:22575] CHIP:DMG: 				CommandFields =
    [1688390345.916571][22573:22575] CHIP:DMG: 				{
    [1688390345.916584][22573:22575] CHIP:DMG: 					0x0 = 0,
    [1688390345.916597][22573:22575] CHIP:DMG: 					0x2 = NULL
    [1688390345.916609][22573:22575] CHIP:DMG: 				},
    [1688390345.916617][22573:22575] CHIP:DMG: 			},
    [1688390345.916628][22573:22575] CHIP:DMG:
    [1688390345.916634][22573:22575] CHIP:DMG: 		},
    [1688390345.916649][22573:22575] CHIP:DMG:
    [1688390345.916656][22573:22575] CHIP:DMG: 	],
    [1688390345.916673][22573:22575] CHIP:DMG:
    [1688390345.916681][22573:22575] CHIP:DMG: 	InteractionModelRevision = 1
    [1688390345.916689][22573:22575] CHIP:DMG: },
    [1688390345.916725][22573:22575] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
    [1688390345.916743][22573:22575] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
    [1688390345.916756][22573:22575] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
    [1688390345.916767][22573:22575] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
    [1688390345.916780][22573:22575] CHIP:CTL: Performing next commissioning step 'FindOperational'
    [1688390345.916789][22573:22575] CHIP:CSM: FindOrEstablishSession: PeerId = [1:0000000000000036]
    [1688390345.916800][22573:22575] CHIP:CSM: FindOrEstablishSession: No existing OperationalSessionSetup instance found
    [1688390345.916817][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 1 --> 2
    [1688390345.916829][22573:22575] CHIP:DIS: Resolving 75A6D801D66A1E10:0000000000000036 ...
    [1688390345.917565][22573:22575] CHIP:DMG: ICR moving to [AwaitingDe]
    [1688390346.117008][22573:22575] CHIP:DIS: Checking node lookup status after 200 ms
    [1688390346.801105][22573:22575] CHIP:DL: Re-trying resolve
    [1688390346.801749][22573:22575] CHIP:DL: Re-trying resolve
    [1688390348.614817][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390348.784198][22573:22575] CHIP:DL: Avahi resolve found
    [1688390348.784243][22573:22575] CHIP:DIS: Node ID resolved for 75A6D801D66A1E10:0000000000000036
    [1688390348.784250][22573:22575] CHIP:DIS: 	Hostname: A6448819020DB534
    [1688390348.784258][22573:22575] CHIP:DIS: 	IP Address #1: fd11:22::f222:7f86:5acf:da40
    [1688390348.784263][22573:22575] CHIP:DIS: 	Port: 5540
    [1688390348.784267][22573:22575] CHIP:DIS: 	Mrp Interval idle: 5000 ms
    [1688390348.784273][22573:22575] CHIP:DIS: 	Mrp Interval active: 300 ms
    [1688390348.784284][22573:22575] CHIP:DIS: 	TCP Supported: 0
    [1688390348.784597][22573:22575] CHIP:DIS: Lookup clearing interface for non LL address
    [1688390348.784634][22573:22575] CHIP:DIS: UDP:[fd11:22::f222:7f86:5acf:da40%otbr0]:5540: new best score: 4
    [1688390348.784640][22573:22575] CHIP:DIS: Checking node lookup status after 2868 ms
    [1688390348.784651][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: Updating device address to UDP:[fd11:22::f222:7f86:5acf:da40]:5540 while in state 2
    [1688390348.784657][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 2 --> 3
    [1688390348.784698][22573:22575] CHIP:IN: SecureSession[0x7fdab001bf80]: Allocated Type:2 LSID:3374
    [1688390348.784719][22573:22575] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000036
    [1688390348.791993][22573:22575] CHIP:EM: <<< [E:55452i S:0 M:98152631] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1688390348.792021][22573:22575] CHIP:IN: (U) Sending msg 98152631 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390348.794427][22573:22575] CHIP:SC: Sent Sigma1 msg
    [1688390348.794448][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 3 --> 4
    [1688390351.215770][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390351.215852][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390351.802651][22573:22575] CHIP:DL: Re-trying resolve
    [1688390351.804072][22573:22575] CHIP:DL: Re-trying resolve
    [1688390353.924665][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390354.538389][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152631 on exchange 55452i Send Cnt 1
    [1688390354.538457][22573:22575] CHIP:IN: (U) Sending msg 98152631 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390356.484032][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390356.484113][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390356.806694][22573:22575] CHIP:DL: Avahi resolve failed
    [1688390356.807345][22573:22575] CHIP:DL: Avahi resolve failed
    [1688390359.188879][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390361.391289][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152631 on exchange 55452i Send Cnt 2
    [1688390361.391341][22573:22575] CHIP:IN: (U) Sending msg 98152631 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390361.751860][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390361.751932][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390364.453044][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390367.055570][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390367.055640][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390369.762370][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390370.279025][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152631 on exchange 55452i Send Cnt 3
    [1688390370.279088][22573:22575] CHIP:IN: (U) Sending msg 98152631 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390372.320182][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390372.320265][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390375.026790][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390377.583491][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390377.583634][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390380.290891][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390382.847408][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390382.847476][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390385.556185][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390386.483214][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152631 on exchange 55452i Send Cnt 4
    [1688390386.483269][22573:22575] CHIP:IN: (U) Sending msg 98152631 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390388.110776][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390388.110817][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390390.820638][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390393.383445][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390393.383531][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390396.085136][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390398.643837][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390398.643961][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390401.349332][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390403.911652][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390403.911792][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390406.658059][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390409.215954][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390409.216083][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390411.920730][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390413.641632][22573:22575] CHIP:EM: Failed to Send CHIP MessageCounter:98152631 on exchange 55452i sendCount: 4 max retries: 4
    [1688390414.523523][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390414.523598][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390417.228258][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390419.783832][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390419.783979][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390421.271661][22573:22575] CHIP:SC: CASESession timed out while waiting for a response from the peer. Current state was 1
    [1688390421.271698][22573:22575] CHIP:IN: SecureSession[0x7fdab001bf80]: Released - Type:2 LSID:3374
    [1688390421.271717][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 4 --> 2
    [1688390421.271730][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 2 --> 1
    [1688390421.271746][22573:22575] CHIP:DIS: OperationalSessionSetup:attempts done: 1, attempts left: 2, retry delay 1s, status src/system/SystemLayerImplSelect.cpp:167: Success
    [1688390421.271753][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 1 --> 6
    [1688390421.271771][22573:22575] CHIP:CTL: Session establishment failed for <0000000000000036, 1>, error: src/protocols/secure_channel/CASESession.cpp:485: CHIP Error 0x00000032: Timeout.  Next retry expected to get a response to Sigma1 or fail within 8 seconds
    [1688390421.271784][22573:22575] CHIP:CTL: Arming failsafe (68 seconds)
    [1688390421.271825][22573:22575] CHIP:DMG: ICR moving to [AddingComm]
    [1688390421.271838][22573:22575] CHIP:DMG: ICR moving to [AddedComma]
    [1688390421.271890][22573:22575] CHIP:EM: <<< [E:55453i S:3373 M:123627895] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    [1688390421.271910][22573:22575] CHIP:IN: (S) Sending msg 123627895 on secure session with LSID: 3373
    [1688390421.272269][22573:22575] CHIP:DMG: ICR moving to [CommandSen]
    [1688390421.366506][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390421.412787][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390421.412874][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390421.412964][22573:22575] CHIP:EM: >>> [E:55453i S:3373 M:68425705] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
    [1688390421.412980][22573:22575] CHIP:EM: Found matching exchange: 55453i, Delegate: 0x7fdab806f5b8
    [1688390421.412992][22573:22575] CHIP:DMG: ICR moving to [ResponseRe]
    [1688390421.413015][22573:22575] CHIP:DMG: InvokeResponseMessage =
    [1688390421.413021][22573:22575] CHIP:DMG: {
    [1688390421.413029][22573:22575] CHIP:DMG: 	suppressResponse = false,
    [1688390421.413035][22573:22575] CHIP:DMG: 	InvokeResponseIBs =
    [1688390421.413047][22573:22575] CHIP:DMG: 	[
    [1688390421.413053][22573:22575] CHIP:DMG: 		InvokeResponseIB =
    [1688390421.413065][22573:22575] CHIP:DMG: 		{
    [1688390421.413072][22573:22575] CHIP:DMG: 			CommandDataIB =
    [1688390421.413080][22573:22575] CHIP:DMG: 			{
    [1688390421.413086][22573:22575] CHIP:DMG: 				CommandPathIB =
    [1688390421.413094][22573:22575] CHIP:DMG: 				{
    [1688390421.413101][22573:22575] CHIP:DMG: 					EndpointId = 0x0,
    [1688390421.413109][22573:22575] CHIP:DMG: 					ClusterId = 0x30,
    [1688390421.413116][22573:22575] CHIP:DMG: 					CommandId = 0x1,
    [1688390421.413122][22573:22575] CHIP:DMG: 				},
    [1688390421.413133][22573:22575] CHIP:DMG:
    [1688390421.413139][22573:22575] CHIP:DMG: 				CommandFields =
    [1688390421.413148][22573:22575] CHIP:DMG: 				{
    [1688390421.413156][22573:22575] CHIP:DMG: 					0x0 = 0,
    [1688390421.413165][22573:22575] CHIP:DMG: 					0x1 = "" (0 chars),
    [1688390421.413173][22573:22575] CHIP:DMG: 				},
    [1688390421.413178][22573:22575] CHIP:DMG: 			},
    [1688390421.413187][22573:22575] CHIP:DMG:
    [1688390421.413193][22573:22575] CHIP:DMG: 		},
    [1688390421.413202][22573:22575] CHIP:DMG:
    [1688390421.413208][22573:22575] CHIP:DMG: 	],
    [1688390421.413219][22573:22575] CHIP:DMG:
    [1688390421.413225][22573:22575] CHIP:DMG: 	InteractionModelRevision = 1
    [1688390421.413230][22573:22575] CHIP:DMG: },
    [1688390421.413257][22573:22575] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
    [1688390421.413271][22573:22575] CHIP:CTL: Status of extending fail-safe for CASE retry: 0
    [1688390421.413286][22573:22575] CHIP:DMG: ICR moving to [AwaitingDe]
    [1688390422.273282][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 6 --> 2
    [1688390422.273321][22573:22575] CHIP:DIS: Resolving 75A6D801D66A1E10:0000000000000036 ...
    [1688390422.274554][22573:22575] CHIP:DL: Avahi resolve found
    [1688390422.274600][22573:22575] CHIP:DIS: Node ID resolved for 75A6D801D66A1E10:0000000000000036
    [1688390422.274607][22573:22575] CHIP:DIS: 	Hostname: A6448819020DB534
    [1688390422.274615][22573:22575] CHIP:DIS: 	IP Address #1: fd11:22::f222:7f86:5acf:da40
    [1688390422.274619][22573:22575] CHIP:DIS: 	Port: 5540
    [1688390422.274624][22573:22575] CHIP:DIS: 	Mrp Interval idle: 5000 ms
    [1688390422.274628][22573:22575] CHIP:DIS: 	Mrp Interval active: 300 ms
    [1688390422.274635][22573:22575] CHIP:DIS: 	TCP Supported: 0
    [1688390422.274920][22573:22575] CHIP:DIS: Lookup clearing interface for non LL address
    [1688390422.274949][22573:22575] CHIP:DIS: UDP:[fd11:22::f222:7f86:5acf:da40%otbr0]:5540: new best score: 4
    [1688390422.274955][22573:22575] CHIP:DIS: Checking node lookup status after 2 ms
    [1688390422.274960][22573:22575] CHIP:DIS: Keeping DNSSD lookup active
    [1688390422.472919][22573:22575] CHIP:DIS: Checking node lookup status after 200 ms
    [1688390422.472958][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: Updating device address to UDP:[fd11:22::f222:7f86:5acf:da40]:5540 while in state 2
    [1688390422.472966][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 2 --> 3
    [1688390422.473004][22573:22575] CHIP:IN: SecureSession[0x7fdab001bf80]: Allocated Type:2 LSID:3375
    [1688390422.473020][22573:22575] CHIP:SC: Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000036
    [1688390422.479178][22573:22575] CHIP:EM: <<< [E:55454i S:0 M:98152632] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    [1688390422.479187][22573:22575] CHIP:IN: (U) Sending msg 98152632 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390422.481513][22573:22575] CHIP:SC: Sent Sigma1 msg
    [1688390422.481518][22573:22575] CHIP:DIS: OperationalSessionSetup[1:0000000000000036]: State change 3 --> 4
    [1688390424.110209][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390426.667809][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390426.667941][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390429.348639][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152632 on exchange 55454i Send Cnt 1
    [1688390429.348692][22573:22575] CHIP:IN: (U) Sending msg 98152632 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390429.372749][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390431.935584][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390431.935706][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390434.680949][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390435.781223][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152632 on exchange 55454i Send Cnt 2
    [1688390435.781274][22573:22575] CHIP:IN: (U) Sending msg 98152632 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390437.239768][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390437.239898][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390439.943621][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390442.499704][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390442.499787][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390444.945933][22573:22575] CHIP:EM: Retransmitting MessageCounter:98152632 on exchange 55454i Send Cnt 3
    [1688390444.945987][22573:22575] CHIP:IN: (U) Sending msg 98152632 to IP address 'UDP:[fd11:22::f222:7f86:5acf:da40]:5540'
    [1688390445.161771][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390447.719040][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390447.719091][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390450.424870][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390452.983724][22573:22574] CHIP:DL: Indication received, conn = 0x7fdab806d8c0
    [1688390452.983847][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
    [1688390455.688867][22573:22575] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
    [1688390455.757115][22573:22573] CHIP:CTL: Shutting down the commissioner
    [1688390455.757139][22573:22573] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1688390455.757146][22573:22573] CHIP:DIS: Closing all BLE connections
    [1688390455.757157][22573:22573] CHIP:IN: Clearing BLE pending packets.
    [1688390455.757348][22573:22573] CHIP:BLE: Auto-closing end point's BLE connection.
    [1688390455.757359][22573:22573] CHIP:DL: Closing BLE GATT connection (con 0x7fdab806d8c0)
    [1688390455.757395][22573:22574] CHIP:DL: BluezDisconnect peer=F0:82:C0:02:B4:7C
    [1688390458.574152][22573:22573] CHIP:IN: SecureSession[0x7fdab000e600]: MarkForEviction Type:1 LSID:3373
    [1688390458.574189][22573:22573] CHIP:SC: SecureSession[0x7fdab000e600]: Moving from state 'kActive' --> 'kPendingEviction'
    [1688390458.574223][22573:22573] CHIP:IN: SecureSession[0x7fdab000e600]: Released - Type:1 LSID:3373
    [1688390458.574239][22573:22573] CHIP:CTL: Shutting down the controller
    [1688390458.574266][22573:22573] CHIP:IN: SecureSession[0x7fdab001bf80]: Released - Type:2 LSID:3375
    [1688390458.574294][22573:22573] CHIP:CTL: Device connection failed. Error src/app/OperationalSessionSetup.cpp:438: CHIP Error 0x00000074: The operation has been cancelled
    [1688390458.574305][22573:22573] CHIP:IN: Expiring all sessions for fabric 0x1!!
    [1688390458.574312][22573:22573] CHIP:FP: Forgetting fabric 0x1
    [1688390458.574325][22573:22573] CHIP:TS: Pending Last Known Good Time: 2023-06-01T07:38:45
    [1688390458.574437][22573:22574] CHIP:DL: Bluez disconnected
    [1688390458.574453][22573:22574] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    [1688390458.574440][22573:22573] CHIP:TS: Previous Last Known Good Time: 2023-06-01T07:38:45
    [1688390458.574484][22573:22573] CHIP:TS: Reverted Last Known Good Time to previous value
    [1688390458.574501][22573:22573] CHIP:CTL: Shutting down the commissioner
    [1688390458.574507][22573:22573] CHIP:CTL: Stopping commissioning discovery over DNS-SD
    [1688390458.574516][22573:22573] CHIP:CTL: Shutting down the controller
    [1688390458.574522][22573:22573] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
    [1688390458.575125][22573:22573] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
    [1688390458.575175][22573:22573] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
    [1688390458.575198][22573:22573] CHIP:FP: Shutting down FabricTable
    [1688390458.575214][22573:22573] CHIP:TS: Pending Last Known Good Time: 2023-06-01T07:38:45
    [1688390458.575293][22573:22573] CHIP:TS: Previous Last Known Good Time: 2023-06-01T07:38:45
    [1688390458.575301][22573:22573] CHIP:TS: Reverted Last Known Good Time to previous value
    [1688390458.575463][22573:22573] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-0icr8m)
    [1688390458.575750][22573:22573] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
    [1688390458.575776][22573:22573] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
    [1688390458.575787][22573:22573] CHIP:DL: Inet Layer shutdown
    [1688390458.575795][22573:22573] CHIP:DL: BLE shutdown
    [1688390458.576658][22573:22573] CHIP:DL: System Layer shutdown
    [1688390458.576874][22573:22573] CHIP:TOO: Run command failure: examples/chip-tool/commands/common/CHIPCommand.cpp:537: CHIP Error 0x00000032: Timeout
  • Hey how you got operational dataset by running the following command
    sudo docker run --rm -it --privileged -d --network host --name otbr --volume /dev/ttyACM0:/dev/ttyACM0 nrfconnect/otbr:1813352 --radio-url spinel+hdlc+uart:///dev/ttyACM0 -B wlan0
