Commissioning to a single device using Zigbee CLI Agent
I use nrf52840 dongle programmed with zigbee cli agent example.
Using the bdb start command, the coordinator enable the permit join and connects to all free devices in the network.
Knowing the customer's mac address, is there a method or better a command to connect to the single specified device?
    You can use install codes. The install code and IEEE address of the joining device must be added to the coordinator, and the install code must be set on the joining device. When testing with the CLI agent it is enough to add it and enable install codes with bdb ic commands on the coordinator. For production devices, you must make sure that the install code is installed by the production configuration present in the flash.
    Marte
