HID keyboard
I have integrated HID mouse and keyboard, when my custom board was connected with computer, there is "hello" on notepad. But when I pushed "CapsLk" key, RTT viewer did not print "CAPS ON" or "CAPS OF".
SDK 17.02 on nRF52810
Here is main code.
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_hids_mouse_main main.c
 * @ingroup ble_sdk_app_hids_mouse
 * @brief HID Mouse Sample Application main file.
 * This file contains is the source code for a sample application using the HID, Battery and Device
 * Information Service for implementing a simple mouse functionality. This application uses the
 * @ref app_scheduler.
 * Also it would accept pairing requests from any peer device. This implementation of the
 * application will not know whether a connected central is a known device or not.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_hids.h"
#include "ble_bas.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
//#include "bsp_btn_ble.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "ble_advertising.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "peer_manager_handler.h"
#include "usr_io_def.h"
#include "usr_twi.h"
#include "m_hid_app.h"
#include "nrf_drv_saadc.h"
#include "usr_led.h"
#include "ble_dfu.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME                     "nRF5_Mouse"                                /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(2000)                      /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL               81                                          /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL               100                                         /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT         1                                           /**< Increment between each simulated battery level measurement. */
#define PNP_ID_VENDOR_ID_SOURCE         0x02                                        /**< Vendor ID Source. */
#define PNP_ID_VENDOR_ID                0x1915                                      /**< Vendor ID. */
#define PNP_ID_PRODUCT_ID               0xEEEE                                      /**< Product ID. */
#define PNP_ID_PRODUCT_VERSION          0x0001                                      /**< Product Version. */
/*lint -emacro(524, MIN_CONN_INTERVAL) // Loss of precision */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)            /**< Minimum connection interval (7.5 ms). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum connection interval (15 ms). */
#define SLAVE_LATENCY                   20                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(3000, UNIT_10_MS)             /**< Connection supervisory timeout (3000 ms). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAM_UPDATE_COUNT     3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
#define SWIFT_PAIR_SUPPORTED            1                                           /**< Swift Pair feature is supported. */
#if SWIFT_PAIR_SUPPORTED == 1
#define MICROSOFT_VENDOR_ID             0x0006                                      /**< Microsoft Vendor ID.*/
#define MICROSOFT_BEACON_ID             0x03                                        /**< Microsoft Beacon ID, used to indicate that Swift Pair feature is supported. */
#define MICROSOFT_BEACON_SUB_SCENARIO   0x00                                        /**< Microsoft Beacon Sub Scenario, used to indicate how the peripheral will pair using Swift Pair feature. */
#define RESERVED_RSSI_BYTE              0x80                                        /**< Reserved RSSI byte, used to maintain forwards and backwards compatibility. */
//ADC define
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                               /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
#define ADC_PRE_SCALING_COMPENSATION    6                                 /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS  0                               /**< Typical forward voltage drop of the diode . */
#define ADC_RES_10BIT                   1024                              /**< Maximum digital value for 10-bit ADC conversion. */
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
//HID MAP define
#define MOVEMENT_SPEED                  5                                           /**< Number of pixels by which the cursor is moved each time a button is pushed. */
#define INPUT_REPORT_COUNT              4                                           /**< Number of input reports in this application. */
#define INPUT_REP_BUTTONS_LEN           3                                           /**< Length of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_LEN          3                                           /**< Length of Mouse Input Report containing movement data. */
#define INPUT_REP_MEDIA_PLAYER_LEN      1                                           /**< Length of Mouse Input Report containing media player data. */
#define INPUT_REP_BUTTONS_INDEX         0                                           /**< Index of Mouse Input Report containing button data. */
#define INPUT_REP_MOVEMENT_INDEX        1                                           /**< Index of Mouse Input Report containing movement data. */
#define INPUT_REP_MPLAYER_INDEX         2                                           /**< Index of Mouse Input Report containing media player data. */
#define INPUT_REP_REF_BUTTONS_ID        1                                           /**< Id of reference to Mouse Input Report containing button data. */
#define INPUT_REP_REF_MOVEMENT_ID       2                                           /**< Id of reference to Mouse Input Report containing movement data. */
#define INPUT_REP_REF_MPLAYER_ID        3                                           /**< Id of reference to Mouse Input Report containing media player data. */
#define OUTPUT_REPORT_INDEX                 0                                          /**< Index of Output Report. */
#define OUTPUT_REPORT_MAX_LEN               1                                          /**< Maximum length of Output Report. */
#define INPUT_REPORT_KEYS_INDEX             3                                          /**< Index of Input Report. */
#define OUTPUT_REPORT_BIT_MASK_CAPS_LOCK    0x02                                       /**< CAPS LOCK bit in Output Report (based on 'LED Page (0x08)' of the Universal Serial Bus HID Usage Tables). */
#define INPUT_REP_REF_ID                    4                                          /**< Id of reference to Keyboard Input Report. */
#define OUTPUT_REP_REF_ID                   0                                          /**< Id of reference to Keyboard Output Report. */
#define FEATURE_REP_REF_ID                  0                                          /**< ID of reference to Keyboard Feature Report. */
#define FEATURE_REPORT_MAX_LEN              2                                          /**< Maximum length of Feature Report. */
#define FEATURE_REPORT_INDEX                0
#define MAX_BUFFER_ENTRIES                  5
#define INPUT_REPORT_KEYS_MAX_LEN           8
#define BASE_USB_HID_SPEC_VERSION       0x0101                                      /**< Version number of base USB HID Specification implemented by this application. */
#define SCHED_MAX_EVENT_DATA_SIZE       APP_TIMER_SCHED_EVENT_DATA_SIZE             /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE                20                                          /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE                10                                          /**< Maximum number of events in the scheduler queue. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_ADV_FAST_INTERVAL           0x0028                                      /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL           0x00A0                                      /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 100 ms.). */
#define APP_ADV_FAST_DURATION           1000    //3000                                    /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION           12000   //18000                                    /**< The advertising duration of slow advertising in units of 10 milliseconds. */
APP_TIMER_DEF(m_battery_timer_id);                                                  /**< Battery timer. */
BLE_BAS_DEF(m_bas);        /**< Battery service instance. */
BLE_HIDS_DEF(m_hids,        /**< HID service instance. */
             NRF_SDH_BLE_TOTAL_LINK_COUNT,
             INPUT_REP_BUTTONS_LEN,
             INPUT_REP_MOVEMENT_LEN,
             INPUT_REP_MEDIA_PLAYER_LEN);
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static nrf_saadc_value_t m_adc_buf;
static bool              m_in_boot_mode = false;                                    /**< Current protocol mode. */
static uint16_t          m_conn_handle  = BLE_CONN_HANDLE_INVALID;                  /**< Handle of the current connection. */
static pm_peer_id_t      m_peer_id;                                                 /**< Device reference handle to the current bonded central. */
static ble_uuid_t        m_adv_uuids[] =                                            /**< Universally unique service identifiers. */
    {BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}
/** Abstracts buffer element */
typedef struct hid_key_buffer
    uint8_t      data_offset; /**< Max Data that can be buffered for all entries */
    uint8_t      data_len;    /**< Total length of data */
    uint8_t    * p_data;      /**< Scanned key pattern */
    ble_hids_t * p_instance;  /**< Identifies peer and service instance */
} buffer_entry_t;
STATIC_ASSERT(sizeof(buffer_entry_t) % 4 == 0);
/** Circular buffer list */
typedef struct
    buffer_entry_t buffer[MAX_BUFFER_ENTRIES]; /**< Maximum number of entries that can enqueued in the list */
    uint8_t        rp;                         /**< Index to the read location */
    uint8_t        wp;                         /**< Index to write location */
    uint8_t        count;                      /**< Number of elements in the list */
} buffer_list_t;
STATIC_ASSERT(sizeof(buffer_list_t) % 4 == 0);
static buffer_list_t     buffer_list;                               /**< List to enqueue not just data to be sent, but also related information like the handle, connection handle etc */
//Key
static bool              m_caps_on = false;                         /**< Variable to indicate if Caps Lock is turned on. */
static uint8_t m_sample_key_press_scan_str[] = /**< Key pattern to be sent when the key press button has been pushed. */
    0x0b,       /* Key h */
    0x08,       /* Key e */
    0x0f,       /* Key l */
    0x0f,       /* Key l */
    0x12,       /* Key o */
    0x28        /* Key Return */
static uint8_t m_caps_on_key_scan_str[] = /**< Key pattern to be sent when the output report has been written with the CAPS LOCK bit set. */
    0x06,       /* Key C */
    0x04,       /* Key a */
    0x13,       /* Key p */
    0x16,       /* Key s */
    0x12,       /* Key o */
    0x11,       /* Key n */
static uint8_t m_caps_off_key_scan_str[] = /**< Key pattern to be sent when the output report has been written with the CAPS LOCK bit cleared. */
    0x06,       /* Key C */
    0x04,       /* Key a */
    0x13,       /* Key p */
    0x16,       /* Key s */
    0x12,       /* Key o */
    0x09,       /* Key f */
static uint8_t m_sp_payload[] =                                                     /**< Payload of advertising data structure for Microsoft Swift Pair feature. */
    MICROSOFT_BEACON_ID,
    MICROSOFT_BEACON_SUB_SCENARIO,
    RESERVED_RSSI_BYTE
static ble_advdata_manuf_data_t m_sp_manuf_advdata =                                /**< Advertising data structure for Microsoft Swift Pair feature. */
    .company_identifier = MICROSOFT_VENDOR_ID,
    .data               =
        .size   = sizeof(m_sp_payload),
        .p_data = &m_sp_payload[0]
static ble_advdata_t m_sp_advdata;
static void on_hids_evt(ble_hids_t * p_hids, ble_hids_evt_t * p_evt);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
 * @param[in] skip  Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
    NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                   peer_id_count + 1,
                   BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
    uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
    err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
static void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
        ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        APP_ERROR_CHECK(ret);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            m_peer_id = p_evt->peer_id;
						m_hid_data.peer_manage = true;
            advertising_start(false);
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            if (     p_evt->params.peer_data_update_succeeded.flash_changed
                 && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                // Note: You should check on what kind of white list policy your application should use.
				case PM_EVT_CONN_SEC_CONFIG_REQ:
								pm_conn_sec_config_t config = {.allow_repairing = true};
								pm_conn_sec_config_reply(p_evt->conn_handle, &config);
/**@brief Function for handling Service errors.
static void service_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for handling the ADC interrupt.
 * @details  This function will fetch the conversion result from the ADC, convert the value into
 *           percentage and send it to peer.
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t batt_lvl_in_milli_volts;
        adc_result = p_event->data.done.p_buffer[0];
        batt_lvl_in_milli_volts =
            (ADC_RESULT_IN_MILLI_VOLTS(adc_result) + DIODE_FWD_VOLT_DROP_MILLIVOLTS)*2;
				if(batt_lvl_in_milli_volts>=4100) m_hid_data.battery_level=100;
				else if((batt_lvl_in_milli_volts>=3900)&((batt_lvl_in_milli_volts<4100))) m_hid_data.battery_level=75;
				else if((batt_lvl_in_milli_volts>=3700)&((batt_lvl_in_milli_volts<3900))) m_hid_data.battery_level=50;
				else if((batt_lvl_in_milli_volts>=3550)&((batt_lvl_in_milli_volts<3700))) m_hid_data.battery_level=25;
				else if(batt_lvl_in_milli_volts<3550) m_hid_data.battery_level=0;
				if(batt_lvl_in_milli_volts<=3450)
						if(m_hid_data.ble_status != DEVICE_LOW_POWER_WAIT)
								m_hid_data.ble_status = DEVICE_LOW_POWER;
				}else if(batt_lvl_in_milli_volts>=3600)
						if(m_hid_data.ble_status == DEVICE_LOW_POWER_WAIT)
								m_hid_data.ble_status = DEVICE_LOW_POWER_EXIT;
        NRF_LOG_INFO("HID DEVICE Battery Level : %d [mV]  %d%%", batt_lvl_in_milli_volts,m_hid_data.battery_level);
    else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
        NRF_LOG_INFO("HID SAADC calibration complete");
/**@brief Function for performing a battery measurement, and update the Battery Level characteristic in the Battery Service.
static void battery_level_update(void)
		static uint8_t * p_key = m_sample_key_press_scan_str;
    static uint8_t   size  = 0;
    err_code = nrf_drv_saadc_buffer_convert(&m_adc_buf, 1);
    err_code = nrf_drv_saadc_sample();
    err_code = ble_bas_battery_level_update(&m_bas, m_hid_data.battery_level, BLE_CONN_HANDLE_ALL);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != NRF_ERROR_FORBIDDEN) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
		NRF_LOG_INFO("xxxxx...");
		if (m_hid_data.peer_manage == true)
				NRF_LOG_INFO("Keys update...");
				keys_send(1, p_key);
				p_key++;
				size++;
				if (size == MAX_KEYS_IN_ONE_REPORT)
						size  = 0;
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    err_code = app_timer_init();
    err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
    nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN2);
    config.burst = NRF_SAADC_BURST_ENABLED;
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_calibrate_offset();
    // Create battery timer.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HID_MOUSE);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for initializing the Queued Write Module.
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
    err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
/**@brief Function for initializing Device Information Service.
static void dis_init(void)
    ble_dis_init_t   dis_init_obj;
    ble_dis_pnp_id_t pnp_id;
    pnp_id.vendor_id_source = PNP_ID_VENDOR_ID_SOURCE;
    pnp_id.vendor_id        = PNP_ID_VENDOR_ID;
    pnp_id.product_id       = PNP_ID_PRODUCT_ID;
    pnp_id.product_version  = PNP_ID_PRODUCT_VERSION;
    memset(&dis_init_obj, 0, sizeof(dis_init_obj));
    ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, MANUFACTURER_NAME);
    dis_init_obj.p_pnp_id = &pnp_id;
    dis_init_obj.dis_char_rd_sec = SEC_JUST_WORKS;
    err_code = ble_dis_init(&dis_init_obj);
/**@brief Function for initializing Battery Service.
static void bas_init(void)
    ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = NULL;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    bas_init_obj.bl_rd_sec        = SEC_JUST_WORKS;
    bas_init_obj.bl_cccd_wr_sec   = SEC_JUST_WORKS;
    bas_init_obj.bl_report_rd_sec = SEC_JUST_WORKS;
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
/**@brief Function for initializing DFU Service.
static void advertising_config_get(ble_adv_modes_config_t * p_config)
    memset(p_config, 0, sizeof(ble_adv_modes_config_t));
    p_config->ble_adv_fast_enabled  = true;
    p_config->ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
    p_config->ble_adv_fast_timeout  = APP_ADV_FAST_DURATION;
static void disconnect(uint16_t conn_handle, void * p_context)
    ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
        NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
/**@brief Function for handling dfu events from the Buttonless Secure DFU service
 * @param[in]   event   Event from the Buttonless Secure DFU service.
static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
    switch (event)
        case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
            NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
            // Prevent device from advertising on disconnect.
            ble_adv_modes_config_t config;
            advertising_config_get(&config);
            config.ble_adv_on_disconnect_disabled = true;
            ble_advertising_modes_config_set(&m_advertising, &config);
            // Disconnect all other bonded devices that currently are connected.
            // This is required to receive a service changed indication
            // on bootup after a successful (or aborted) Device Firmware Update.
            uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
            NRF_LOG_INFO("Disconnected %d links.", conn_count);
        case BLE_DFU_EVT_BOOTLOADER_ENTER:
            // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
            //           by delaying reset by reporting false in app_shutdown_handler
            NRF_LOG_INFO("Device will enter bootloader mode.");
        case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
            NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
            // YOUR_JOB: Take corrective measures to resolve the issue
            //           like calling APP_ERROR_CHECK to reset the device.
        case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
            NRF_LOG_ERROR("Request to send a response to client failed.");
            APP_ERROR_CHECK(false);
            NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
static void dfu_init(void)
		uint32_t           err_code;
		ble_dfu_buttonless_init_t dfus_init = {0};
		dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
/**@brief Function for initializing HID Service.
static void hids_init(void)
    ble_hids_init_t               hids_init_obj;
    ble_hids_inp_rep_init_t     * p_input_report;
    ble_hids_outp_rep_init_t    * p_output_report;
    ble_hids_feature_rep_init_t * p_feature_report;
    uint8_t                       hid_info_flags;
    static ble_hids_inp_rep_init_t     input_report_array[INPUT_REPORT_COUNT];
    static ble_hids_outp_rep_init_t    output_report_array[1];
    static ble_hids_feature_rep_init_t feature_report_array[1];
    static uint8_t rep_map_data[] =
        0x05, 0x01, // Usage Page (Generic Desktop)
        0x09, 0x02, // Usage (Mouse)
        0xA1, 0x01, // Collection (Application)
        // Report ID 1: Mouse buttons + scroll/pan
        0x85, 0x01,       // Report Id 1
        0x09, 0x01,       // Usage (Pointer)
        0xA1, 0x00,       // Collection (Physical)
        0x95, 0x05,       // Report Count (3)
        0x75, 0x01,       // Report Size (1)
        0x05, 0x09,       // Usage Page (Buttons)
        0x19, 0x01,       // Usage Minimum (01)
        0x29, 0x05,       // Usage Maximum (05)
        0x15, 0x00,       // Logical Minimum (0)
        0x25, 0x01,       // Logical Maximum (1)
        0x81, 0x02,       // Input (Data, Variable, Absolute)
        0x95, 0x01,       // Report Count (1)
        0x75, 0x03,       // Report Size (3)
        0x81, 0x01,       // Input (Constant) for padding
        0x75, 0x08,       // Report Size (8)
        0x09, 0x38,       // Usage (Wheel)
        0x15, 0x81,       // Logical Minimum (-127)
        0x25, 0x7F,       // Logical Maximum (127)
        0x81, 0x06,       // Input (Data, Variable, Relative)
        0x05, 0x0C,       // Usage Page (Consumer)
        0x0A, 0x38, 0x02, // Usage (AC Pan)
        0x81, 0x06,       // Input (Data,Value,Relative,Bit Field)
        0xC0,             // End Collection (Physical)
        // Report ID 2: Mouse motion
        0x85, 0x02,       // Report Id 2
        0x75, 0x0C,       // Report Size (12)
        0x95, 0x02,       // Report Count (2)
        0x09, 0x30,       // Usage (X)
        0x09, 0x31,       // Usage (Y)
        0x16, 0x01, 0xF8, // Logical maximum (2047)
        0x26, 0xFF, 0x07, // Logical minimum (-2047)
        0xC0,             // End Collection (Application)
        // Report ID 3: Advanced buttons
        0x09, 0x01,       // Usage (Consumer Control)
        0x85, 0x03,       // Report Id (3)
        0x15, 0x00,       // Logical minimum (0)
        0x25, 0x01,       // Logical maximum (1)
        0x09, 0xCD,       // Usage (Play/Pause)
        0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
        0x09, 0xB5,       // Usage (Scan Next Track)
        0x09, 0xB6,       // Usage (Scan Previous Track)
        0x09, 0xEA,       // Usage (Volume Down)
        0x09, 0xE9,       // Usage (Volume Up)
        0x0A, 0x25, 0x02, // Usage (AC Forward)
        0x0A, 0x24, 0x02, // Usage (AC Back)
				// Report ID 4: Key board
        0x09, 0x06,       // Usage (Keyboard)
				0x85, 0x04,       // Report Id (4)
        0x05, 0x07,       // Usage Page (Key Codes)
        0x19, 0xe0,       // Usage Minimum (224)
        0x29, 0xe7,       // Usage Maximum (231)
        0x95, 0x08,       // Report Count (8)
        0x81, 0x01,       // Input (Constant) reserved byte(1)
        0x95, 0x05,       // Report Count (5)
        0x05, 0x08,       // Usage Page (Page# for LEDs)
        0x19, 0x01,       // Usage Minimum (1)
        0x29, 0x05,       // Usage Maximum (5)
        0x91, 0x02,       // Output (Data, Variable, Absolute), Led report
        0x91, 0x01,       // Output (Data, Variable, Absolute), Led report padding
        0x95, 0x06,       // Report Count (6)
        0x25, 0x65,       // Logical Maximum (101)
        0x05, 0x07,       // Usage Page (Key codes)
        0x19, 0x00,       // Usage Minimum (0)
        0x29, 0x65,       // Usage Maximum (101)
        0x81, 0x00,       // Input (Data, Array) Key array(6 bytes)
        0x09, 0x05,       // Usage (Vendor Defined)
        0x26, 0xFF, 0x00, // Logical Maximum (255)
        0x75, 0x08,       // Report Size (8 bit)
        0xB1, 0x02,       // Feature (Data, Variable, Absolute)
        0xC0              // End Collection (Application)
		//Key
    memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
    memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
    memset((void *)feature_report_array, 0, sizeof(ble_hids_feature_rep_init_t));
    // Initialize HID Service.
    p_input_report                      = &input_report_array[INPUT_REP_BUTTONS_INDEX];
    p_input_report->max_len             = INPUT_REP_BUTTONS_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_BUTTONS_ID;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
    p_input_report->sec.wr      = SEC_JUST_WORKS;
    p_input_report->sec.rd      = SEC_JUST_WORKS;
    p_input_report                      = &input_report_array[INPUT_REP_MOVEMENT_INDEX];
    p_input_report->max_len             = INPUT_REP_MOVEMENT_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MOVEMENT_ID;
    p_input_report                      = &input_report_array[INPUT_REP_MPLAYER_INDEX];
    p_input_report->max_len             = INPUT_REP_MEDIA_PLAYER_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MPLAYER_ID;
		//Key
    p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];
    p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
    p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
    p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
    p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
    p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
    p_output_report->sec.wr = SEC_JUST_WORKS;
    p_output_report->sec.rd = SEC_JUST_WORKS;
    p_feature_report                      = &feature_report_array[FEATURE_REPORT_INDEX];
    p_feature_report->max_len             = FEATURE_REPORT_MAX_LEN;
    p_feature_report->rep_ref.report_id   = FEATURE_REP_REF_ID;
    p_feature_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_FEATURE;
    p_feature_report->sec.rd              = SEC_JUST_WORKS;
    p_feature_report->sec.wr              = SEC_JUST_WORKS;
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = true;
    hids_init_obj.is_mouse                       = true;
    hids_init_obj.inp_rep_count                  = INPUT_REPORT_COUNT;
    hids_init_obj.p_inp_rep_array                = input_report_array;
    hids_init_obj.outp_rep_count                 = 1;
    hids_init_obj.p_outp_rep_array               = output_report_array;
    hids_init_obj.feature_rep_count              = 1;
    hids_init_obj.p_feature_rep_array            = feature_report_array;
    hids_init_obj.rep_map.data_len               = sizeof(rep_map_data);
    hids_init_obj.rep_map.p_data                 = rep_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
    hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
		//Key
    hids_init_obj.boot_kb_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_outp_rep_sec.rd = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_outp_rep_sec.wr = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.wr      = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
    hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
    qwr_init();
    dis_init();
    bas_init();
    hids_init();
		dfu_init();
/**@brief Function for initializing the battery sensor simulator.
//static void sensor_simulator_init(void)
//    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
//    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
//    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
//    m_battery_sim_cfg.start_at_max = true;
//    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
/**@brief Function for handling a Connection Parameters error.
    cp_init.max_conn_params_update_count   = MAX_CONN_PARAM_UPDATE_COUNT;
    cp_init.evt_handler                    = NULL;
/**@brief Function for starting timers.
static void timers_start(void)
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
/**@brief   Function for transmitting a key scan Press & Release Notification.
 * @warning This handler is an example only. You need to analyze how you wish to send the key
 *          release.
 * @param[in]  p_instance     Identifies the service for which Key Notifications are requested.
 * @param[in]  p_key_pattern  Pointer to key pattern.
 * @param[in]  pattern_len    Length of key pattern. 0 < pattern_len < 7.
 * @param[in]  pattern_offset Offset applied to Key Pattern for transmission.
 * @param[out] actual_len     Provides actual length of Key Pattern transmitted, making buffering of
 *                            rest possible if needed.
 * @return     NRF_SUCCESS on success, NRF_ERROR_RESOURCES in case transmission could not be
 *             completed due to lack of transmission buffer or other error codes indicating reason
 *             for failure.
 * @note       In case of NRF_ERROR_RESOURCES, remaining pattern that could not be transmitted
 *             can be enqueued \ref buffer_enqueue function.
 *             In case a pattern of 'cofFEe' is the p_key_pattern, with pattern_len as 6 and
 *             pattern_offset as 0, the notifications as observed on the peer side would be
 *             1>    'c', 'o', 'f', 'F', 'E', 'e'
 *             2>    -  , 'o', 'f', 'F', 'E', 'e'
 *             3>    -  ,   -, 'f', 'F', 'E', 'e'
 *             4>    -  ,   -,   -, 'F', 'E', 'e'
 *             5>    -  ,   -,   -,   -, 'E', 'e'
 *             6>    -  ,   -,   -,   -,   -, 'e'
 *             7>    -  ,   -,   -,   -,   -,  -
 *             Here, '-' refers to release, 'c' refers to the key character being transmitted.
 *             Therefore 7 notifications will be sent.
 *             In case an offset of 4 was provided, the pattern notifications sent will be from 5-7
 *             will be transmitted.
static uint32_t send_key_scan_press_release(ble_hids_t * p_hids,
                                            uint8_t    * p_key_pattern,
                                            uint16_t     pattern_len,
                                            uint16_t     pattern_offset,
                                            uint16_t   * p_actual_len)
    uint16_t offset;
    uint16_t data_len;
    uint8_t  data[INPUT_REPORT_KEYS_MAX_LEN];
    // HID Report Descriptor enumerates an array of size 6, the pattern hence shall not be any
    // longer than this.
    STATIC_ASSERT((INPUT_REPORT_KEYS_MAX_LEN - 2) == 6);
    ASSERT(pattern_len <= (INPUT_REPORT_KEYS_MAX_LEN - 2));
    offset   = pattern_offset;
    data_len = pattern_len;
    do
        // Reset the data buffer.
        memset(data, 0, sizeof(data));
        // Copy the scan code.
        memcpy(data + SCAN_CODE_POS + offset, p_key_pattern + offset, data_len - offset);
//        if (bsp_button_is_pressed(SHIFT_BUTTON_ID))
//            data[MODIFIER_KEY_POS] |= SHIFT_KEY_CODE;
        if (!m_in_boot_mode)
            err_code = ble_hids_inp_rep_send(p_hids,
                                             INPUT_REPORT_KEYS_INDEX,
                                             INPUT_REPORT_KEYS_MAX_LEN,
                                             data,
                                             m_conn_handle);
            err_code = ble_hids_boot_kb_inp_rep_send(p_hids,
                                                     data,
                                                     m_conn_handle);
        offset++;
    while (offset <= data_len);
    *p_actual_len = offset;
    return err_code;
/**@brief   Function for initializing the buffer queue used to key events that could not be
 *          transmitted
 * @warning This handler is an example only. You need to analyze how you wish to buffer or buffer at
 *          all.
 * @note    In case of HID keyboard, a temporary buffering could be employed to handle scenarios
 *          where encryption is not yet enabled or there was a momentary link loss or there were no
 *          Transmit buffers.
static void buffer_init(void)
    uint32_t buffer_count;
    BUFFER_LIST_INIT();
    for (buffer_count = 0; buffer_count < MAX_BUFFER_ENTRIES; buffer_count++)
        BUFFER_ELEMENT_INIT(buffer_count);
/**@brief Function for enqueuing key scan patterns that could not be transmitted either completely
 *        or partially.
 *          release.
 * @param[in]  p_hids         Identifies the service for which Key Notifications are buffered.
 * @param[in]  offset         Offset applied to Key Pattern when requesting a transmission on
 *                            dequeue, @ref buffer_dequeue.
 * @return     NRF_SUCCESS on success, else an error code indicating reason for failure.
static uint32_t buffer_enqueue(ble_hids_t * p_hids,
                               uint16_t     offset)
    buffer_entry_t * element;
    uint32_t         err_code = NRF_SUCCESS;
    if (BUFFER_LIST_FULL())
        // Element cannot be buffered.
        err_code = NRF_ERROR_NO_MEM;
        // Make entry of buffer element and copy data.
        element              = &buffer_list.buffer[(buffer_list.wp)];
        element->p_instance  = p_hids;
        element->p_data      = p_key_pattern;
        element->data_offset = offset;
        element->data_len    = pattern_len;
        buffer_list.count++;
        buffer_list.wp++;
        if (buffer_list.wp == MAX_BUFFER_ENTRIES)
            buffer_list.wp = 0;
    return err_code;
/**@brief   Function to dequeue key scan patterns that could not be transmitted either completely of
 *          partially.
 *          release.
 * @param[in]  tx_flag   Indicative of whether the dequeue should result in transmission or not.
 * @note       A typical example when all keys are dequeued with transmission is when link is
 *             disconnected.
static uint32_t buffer_dequeue(bool tx_flag)
    buffer_entry_t * p_element;
    uint16_t         actual_len;
    if (BUFFER_LIST_EMPTY())
        err_code = NRF_ERROR_NOT_FOUND;
        bool remove_element = true;
        p_element = &buffer_list.buffer[(buffer_list.rp)];
        if (tx_flag)
            err_code = send_key_scan_press_release(p_element->p_instance,
                                                   p_element->p_data,
                                                   p_element->data_len,
                                                   p_element->data_offset,
                                                   &actual_len);
            // An additional notification is needed for release of all keys, therefore check
            // is for actual_len <= element->data_len and not actual_len < element->data_len
            if ((err_code == NRF_ERROR_RESOURCES) && (actual_len <= p_element->data_len))
                // Transmission could not be completed, do not remove the entry, adjust next data to
                // be transmitted
                p_element->data_offset = actual_len;
                remove_element         = false;
        if (remove_element)
            BUFFER_ELEMENT_INIT(buffer_list.rp);
            buffer_list.rp++;
            buffer_list.count--;
            if (buffer_list.rp == MAX_BUFFER_ENTRIES)
                buffer_list.rp = 0;
    return err_code;
/**@brief Function for sending sample key presses to the peer.
 * @param[in]   key_pattern_len   Pattern length.
 * @param[in]   p_key_pattern     Pattern to be sent.
void keys_send(uint8_t key_pattern_len, uint8_t * p_key_pattern)
    err_code = send_key_scan_press_release(&m_hids,
                                           p_key_pattern,
                                           key_pattern_len,
                                           0,
                                           &actual_len);
    // is for actual_len <= key_pattern_len and not actual_len < key_pattern_len.
    if ((err_code == NRF_ERROR_RESOURCES) && (actual_len <= key_pattern_len))
        // Buffer enqueue routine return value is not intentionally checked.
        // Rationale: Its better to have a a few keys missing than have a system
        // reset. Recommendation is to work out most optimal value for
        // MAX_BUFFER_ENTRIES to minimize chances of buffer queue full condition
        UNUSED_VARIABLE(buffer_enqueue(&m_hids, p_key_pattern, key_pattern_len, actual_len));
/**@brief Function for handling the HID Report Characteristic Write event.
 * @param[in]   p_evt   HID service event.
static void on_hid_rep_char_write(ble_hids_evt_t * p_evt)
    if (p_evt->params.char_write.char_id.rep_type == BLE_HIDS_REP_TYPE_OUTPUT)
        uint8_t  report_val;
        uint8_t  report_index = p_evt->params.char_write.char_id.rep_index;
        if (report_index == OUTPUT_REPORT_INDEX)
            // This code assumes that the output report is one byte long. Hence the following
            // static assert is made.
            STATIC_ASSERT(OUTPUT_REPORT_MAX_LEN == 1);
            err_code = ble_hids_outp_rep_get(&m_hids,
                                             report_index,
                                             OUTPUT_REPORT_MAX_LEN,
                                             0,
                                             m_conn_handle,
                                             &report_val);
            if (!m_caps_on && ((report_val & OUTPUT_REPORT_BIT_MASK_CAPS_LOCK) != 0))
                // Caps Lock is turned On.
                NRF_LOG_INFO("Caps Lock is turned On!");
//                err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
//                APP_ERROR_CHECK(err_code);
                keys_send(sizeof(m_caps_on_key_scan_str), m_caps_on_key_scan_str);
                m_caps_on = true;
            else if (m_caps_on && ((report_val & OUTPUT_REPORT_BIT_MASK_CAPS_LOCK) == 0))
                // Caps Lock is turned Off .
                NRF_LOG_INFO("Caps Lock is turned Off!");
//                err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
                keys_send(sizeof(m_caps_off_key_scan_str), m_caps_off_key_scan_str);
                m_caps_on = false;
                // The report received is not supported by this application. Do nothing.
//static void sleep_mode_enter(void)
//    ret_code_t err_code;
//    err_code = bsp_indication_set(BSP_INDICATE_IDLE);
//    // Prepare wakeup buttons.
//    err_code = bsp_btn_ble_sleep_mode_prepare();
//    // Go to system-off mode (this function will not return; wakeup will cause a reset).
//    err_code = sd_power_system_off();
/**@brief Function for handling HID events.
 * @details This function will be called for all HID events which are passed to the application.
 * @param[in]   p_hids  HID service structure.
 * @param[in]   p_evt   Event received from the HID service.
    switch (p_evt->evt_type)
        case BLE_HIDS_EVT_BOOT_MODE_ENTERED:
            m_in_boot_mode = true;
        case BLE_HIDS_EVT_REPORT_MODE_ENTERED:
				case BLE_HIDS_EVT_REP_CHAR_WRITE:
            on_hid_rep_char_write(p_evt);
        case BLE_HIDS_EVT_NOTIF_ENABLED:
            // No implementation needed.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
            NRF_LOG_INFO("Directed advertising.");
//            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
//            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
        case BLE_ADV_EVT_SLOW:
            NRF_LOG_INFO("Slow advertising.");
            m_sp_advdata.p_manuf_specific_data = NULL;
            err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata, NULL);
//            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_FAST_WHITELIST:
            NRF_LOG_INFO("Fast advertising with whitelist.");
//            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
        case BLE_ADV_EVT_SLOW_WHITELIST:
            NRF_LOG_INFO("Slow advertising with whitelist.");
        case BLE_ADV_EVT_IDLE:
//            sleep_mode_enter();
						NRF_LOG_INFO("Device stop advertising.");
						m_hid_data.ble_status = DEVICE_ADV_STOP;
        case BLE_ADV_EVT_WHITELIST_REQUEST:
            ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
            uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
            err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                        whitelist_irks,  &irk_cnt);
            NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                           addr_cnt,
                           irk_cnt);
            // Set the correct identities list (no excluding peers with no Central Address Resolution).
            identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
            // Apply the whitelist.
            err_code = ble_advertising_whitelist_reply(&m_advertising,
                                                       whitelist_addrs,
                                                       addr_cnt,
                                                       whitelist_irks,
                                                       irk_cnt);
        case BLE_ADV_EVT_PEER_ADDR_REQUEST:
            pm_peer_data_bonding_t peer_bonding_data;
            // Only Give peer address if we have a handle to the bonded peer.
            if (m_peer_id != PM_PEER_ID_INVALID)
                err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                if (err_code != NRF_ERROR_NOT_FOUND)
                    // Manipulate identities to exclude peers with no Central Address Resolution.
                    identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                    ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                    err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
//            err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
						if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
								m_hid_data.ble_status = DEVICE_CONNECTED;
								sd_ble_gap_adv_stop(m_advertising.adv_handle);
								NRF_LOG_INFO("Disconnected low power stop adv.");
						}else
								m_hid_data.ble_status = DEVICE_DISCONNECTED;
								NRF_LOG_INFO("Disconnected timeout.");
						(void) buffer_dequeue(false);
						// Reset m_caps_on variable. Upon reconnect, the HID host will re-send the Output
            // report containing the Caps lock state.
            m_caps_on = false;
						m_hid_data.peer_manage = false;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTS_EVT_HVN_TX_COMPLETE:
            // Send next key event
            (void) buffer_dequeue(true);
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    uint8_t                adv_flags;
    ble_advertising_init_t init;
    adv_flags                            = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = adv_flags;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.advdata.p_manuf_specific_data = &m_sp_manuf_advdata;
    memcpy(&m_sp_advdata, &init.advdata, sizeof(m_sp_advdata));
    init.config.ble_adv_whitelist_enabled          = true;
    init.config.ble_adv_directed_high_duty_enabled = true;
    init.config.ble_adv_directed_enabled           = false;
    init.config.ble_adv_directed_interval          = 0;
    init.config.ble_adv_directed_timeout           = 0;
    init.config.ble_adv_fast_enabled               = true;
    init.config.ble_adv_fast_interval              = APP_ADV_FAST_INTERVAL;
    init.config.ble_adv_fast_timeout               = APP_ADV_FAST_DURATION;
    init.config.ble_adv_slow_enabled               = true;
    init.config.ble_adv_slow_interval              = APP_ADV_SLOW_INTERVAL;
    init.config.ble_adv_slow_timeout               = APP_ADV_SLOW_DURATION;
    init.evt_handler   = on_adv_evt;
    init.error_handler = ble_advertising_error_handler;
/**@brief Function for the Event Scheduler initialization.
static void scheduler_init(void)
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for sending a Mouse Movement.
 * @param[in]   x_delta   Horizontal movement.
 * @param[in]   y_delta   Vertical movement.
void mouse_movement_send(int16_t x_delta, int16_t y_delta)
				if (m_in_boot_mode)
						x_delta = MIN(x_delta, 0x00ff);
						y_delta = MIN(y_delta, 0x00ff);
						err_code = ble_hids_boot_mouse_inp_rep_send(&m_hids,
																												0x00,
																												(int8_t)x_delta,
																												(int8_t)y_delta,
																												0,
																												NULL,
																												m_conn_handle);
						uint8_t buffer[INPUT_REP_MOVEMENT_LEN];
						APP_ERROR_CHECK_BOOL(INPUT_REP_MOVEMENT_LEN == 3);
						x_delta = MIN(x_delta, 0x0fff);
						y_delta = MIN(y_delta, 0x0fff);
						buffer[0] = x_delta & 0x00ff;
						buffer[1] = ((y_delta & 0x000f) << 4) | ((x_delta & 0x0f00) >> 8);
						buffer[2] = (y_delta & 0x0ff0) >> 4;
						err_code = ble_hids_inp_rep_send(&m_hids,
																						 INPUT_REP_MOVEMENT_INDEX,
																						 buffer,
																						 m_conn_handle);
/**@brief Function for media data.
 * @param[in]   control --- hid media data
void m_button_media_player_control(uint8_t control)
		uint32_t err_code;
		uint8_t buffer[1];
		buffer[0] = control;
				err_code = ble_hids_inp_rep_send( &m_hids,
																					INPUT_REP_MPLAYER_INDEX,
																					1,
																					buffer,
																					m_conn_handle);
				if(( err_code != NRF_SUCCESS ) &&
					 ( err_code != NRF_ERROR_INVALID_STATE ) &&
					 ( err_code != NRF_ERROR_RESOURCES ) &&
					 ( err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING ))
						APP_ERROR_HANDLER( err_code );
				buffer[0] = 0;
																					1,
																					buffer,
																					m_conn_handle);
/**@brief Function for buttons
 * @param[in]   buttons --- hid media data
 * @details click 1 2 4 左 右 中
            wheel  -127 to +127 上下滑动
						pan    -127 to +127 左右滑动
void mouse_buttons_send(int8_t click, int8_t wheel, int8_t pan)
		 uint32_t err_code;
		uint8_t buffer[INPUT_REP_BUTTONS_LEN];
				APP_ERROR_CHECK_BOOL(INPUT_REP_BUTTONS_LEN == 3);
//				NRF_LOG_INFO("mouse_buttons_send\r\n");
				buffer[0] = click;
				buffer[1] = wheel;
				buffer[2] = pan;
																					INPUT_REP_BUTTONS_INDEX,
																					buffer,
																					m_conn_handle);
 * @param[in]   event   Event generated by button press.
//static void bsp_event_handler(bsp_event_t event)
//    switch (event)
//        case BSP_EVENT_SLEEP:
//            break;
//        case BSP_EVENT_DISCONNECT:
//            err_code = sd_ble_gap_disconnect(m_conn_handle,
//                                             BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
//            if (err_code != NRF_ERROR_INVALID_STATE)
//            break;
//        case BSP_EVENT_WHITELIST_OFF:
//            if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
//                err_code = ble_advertising_restart_without_whitelist(&m_advertising);
//            break;
//        case BSP_EVENT_KEY_0:
//            if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
//                mouse_movement_send(-MOVEMENT_SPEED, 0);
//            break;
//        case BSP_EVENT_KEY_1:
//                mouse_movement_send(0, -MOVEMENT_SPEED);
//            break;
//        case BSP_EVENT_KEY_2:
//                mouse_movement_send(MOVEMENT_SPEED, 0);
//            break;
//        case BSP_EVENT_KEY_3:
//                mouse_movement_send(0, MOVEMENT_SPEED);
//            break;
//        default:
//            break;
//static void buttons_leds_init(bool * p_erase_bonds)
//    bsp_event_t startup_event;
//    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
//    err_code = bsp_btn_ble_init(NULL, &startup_event);
//    *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
static void log_init(void)
    app_sched_execute();
        nrf_pwr_mgmt_run();
/**@brief Function for start advertising.
void m_adv_start(void)
/**@brief Function for disconnect.
void m_adv_disconnect(void)
		if (m_conn_handle != BLE_CONN_HANDLE_INVALID)//连接状态
																				 BLE_HCI_REMOTE_DEV_TERMINATION_DUE_TO_POWER_OFF);
		}else//非连接状态
				m_pwm_stop();
				err_code = sd_ble_gap_adv_stop(m_advertising.adv_handle);
				NRF_LOG_INFO("Normal low power stop adv.");
/**@brief Function for application main entry.
    bool erase_bonds = false;
    // Initialize.
    log_init();
	  // Initialize the async SVCI interface to bootloader before any interrupts are enabled.
//    err_code = ble_dfu_buttonless_async_svci_init();
    timers_init();
		sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
//    buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
//    sensor_simulator_init();
    conn_params_init();
		buffer_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("HID Mouse example started.");
    timers_start();
		advertising_start(erase_bonds);
		m_platform_init();
		m_twi_init();       //TWI init
		m_pwm_common_init();//PWM init
		m_paw3003_check();
		m_button_init();
		m_paw3003_init();
		m_system_timer_init();
		m_led_timer_init();
    // Enter main loop.
    for (;;)
				m_application_handle();
				m_led_handle();
        idle_state_handle();
  • Hi, Hieu
    I have changed OUTPUT_REP_REF_ID to 4, but still have no print "CAPS ON" or "CAPS OFF" when I pushed CapsLk button.
    Did I delete some important code?
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "fds.h"
    //ADC define
    //HID MAP define
    #define OUTPUT_REP_REF_ID                   4                                          /**< Id of reference to Keyboard Output Report. */
    #else
    } buffer_entry_t;
    typedef struct
    } buffer_list_t;
    //Key
        0x5d,       /* Key h */
        0x08,       /* Key e */
        0x0f,       /* Key l */
        0x0f,       /* Key l */
        0x12,       /* Key o */
        0x51        /* Key Return */
        0x06,       /* Key C */
        0x04,       /* Key a */
        0x13,       /* Key p */
        0x16,       /* Key s */
        0x12,       /* Key o */
        0x11,       /* Key n */
        0x06,       /* Key C */
        0x04,       /* Key a */
        0x13,       /* Key p */
        0x16,       /* Key s */
        0x12,       /* Key o */
        0x09,       /* Key f */
        RESERVED_RSSI_BYTE
        .data               =
                       peer_id_count + 1,
            delete_bonds();
        switch (event)
    		uint32_t           err_code;
    		//Key
    		//Key
    		//Key
        qwr_init();
        dis_init();
        bas_init();
        hids_init();
    		dfu_init();
     *          release.
     *             for failure.
        uint16_t offset;
        uint16_t data_len;
        do
    				//Shift button
                                                 data,
                                                 m_conn_handle);
                                                         data,
                                                         m_conn_handle);
            offset++;
        return err_code;
     *          transmitted
     *          all.
     *          Transmit buffers.
        BUFFER_LIST_INIT();
     *        or partially.
     *          release.
                                   uint16_t     offset)
            buffer_list.wp++;
                buffer_list.wp = 0;
        return err_code;
     *          partially.
     *          release.
     *             disconnected.
            if (tx_flag)
                                                       p_element->p_data,
                                                       &actual_len);
                    // be transmitted
            if (remove_element)
                buffer_list.rp++;
                    buffer_list.rp = 0;
        return err_code;
    																							 p_key_pattern,
    																							 key_pattern_len,
    																							 0,
    																							 &actual_len);
            uint8_t  report_val;
                                                 report_index,
                                                 0,
                                                 m_conn_handle,
                                                 &report_val);
                    m_caps_on = true;
                    m_caps_on = false;
                               addr_cnt,
                               irk_cnt);
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
    						}else
    						m_caps_on = false;
            } break;
        uint8_t                adv_flags;
    				if (m_in_boot_mode)
    																												0x00,
    																												(int8_t)x_delta,
    																												(int8_t)y_delta,
    																												0,
    																												NULL,
    																												m_conn_handle);
    																						 buffer,
    																						 m_conn_handle);
    		uint32_t err_code;
    		uint8_t buffer[1];
    																					1,
    																					buffer,
    																					m_conn_handle);
    				buffer[0] = 0;
    																					1,
    																					buffer,
    																					m_conn_handle);
    		 uint32_t err_code;
    				buffer[0] = click;
    				buffer[1] = wheel;
    				buffer[2] = pan;
    																					buffer,
    																					m_conn_handle);
    //    switch (event)
    //            break;
    //            break;
    //            break;
    //            break;
    //            break;
    //            break;
    //            break;
    //        default:
    //            break;
            nrf_pwr_mgmt_run();
    		}else//非连接状态
    				m_pwm_stop();
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        scheduler_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
    		buffer_init();
        // Start execution.
        timers_start();
    		m_platform_init();
    		m_paw3003_check();
    		m_button_init();
    		m_paw3003_init();
    		m_led_timer_init();
        // Enter main loop.
        for (;;)
    				m_led_handle();
  • Hi Taylor,
    No you didn't remove anything too important. It is just the references to the removed code was (very) slightly distracting.
    In any cases, I just reviewed all of your newest codes which is relevant to hids_init() through a line by line comparison with my current implementation.
    Once again, no obvious problems...
    There is one bad BLE_HIDS_DEF setup. However, I have a very similar mistake there until this review, and printing CAPSON/capsof worked for me last week, so I don't think that is the problem...
    The difference between your mistake and mine is due to you basing on mouse example, and me basing on keyboard example.
    Would you mind trying the following steps? The steps might seem a little too brainless, but I feel like the problem is a minor thing somewhere hiding from our mind. After all, I did reproduce your bug, and simply changing OUTPUT_REP_REF_ID fixed it.
    1. Erase the board completely before flashing, retry
    2. Update BLE_HIDS_DEF following my code below, retry
    3. .. just use my entire code below, retry
    #define INPUT_REPORT_KEYS_MAX_LEN       8   /**< Maximum length of the Input Report characteristic. */
    BLE_HIDS_DEF(m_hids,                        /**< Structure used to identify the HID service. */
                 INPUT_REP_MEDIA_PLAYER_LEN,
                 FEATURE_REPORT_MAX_LEN);
                                      // Begin of 1.Button
                                      // End of 1.Button
                                      // Begin of 1 Wheel
                                      // End of 1.Wheel
                                      // Begin of 1.AC_Pan
                                      // End of 1.AC_Pan
                                  // End of 1.
                                      // Begin of 2.XY
                                      // End of 2.XY
                                  // End of 2.
                              // Begin of 2.
                              // End of 2.
        //Key
        //Key
        //Key
