nRF Connect for VSCode unlimited number of issues
Hi, I have several issues just to start off with. One is when I generate support information, it does its thing, and then stops, and I have no idea where the support information was put. Based on instructions to another customer, that is not supposed to happen. It did not happen for them apparently, but it happened to me.
The next problem is when I start VS Code from the toolchain manager on Linux, v2.0.0, west is not found.
The next problem is when I start VS Code from the command line on Linux, cmake  --version gives an error in VS Code, although it is perfectly fine on the command line.
Basically I can do almost anything in a Linux terminal with regards to building and debugging nRF9160 projects, but on Linux I cannot build or debug, and on Windows I can build but not debug, when VS Code is involved.
I have never ever seen an IDE in many, many years that is quite so indecipherable. This is really crazy. Perhaps you can fix that or switch to another recommended IDE?
Thanks.
Burt
  • Michal,
    I cannot replicate this issue with warnings on Windows. Only Linux. Is it guaranteed that I did something wrong? Or can there be a build platform dependency?
  • Actually, Mac and Linux behave the same and show the pointer-sign warnings. (Mac shows a couple of errors, too, but that appears to be some low level compiler stuff that may possibly be mentioned in the documentation.)
  • Hello Burt,
    Sorry for the long response time, but this case is very uncommon and it's quite a bit to get into.
    I have tested the asset tracker in NCS v2.0.0 on Linux (Ubuntu 20.04) and did not get any errors. I have tried both with and without the debug options and I have added your compiler flags into my CMakeLists.txt with zephyr_library_compile_options(-Wall -Wno-pointer-sign). It didn't show any of the pointer warnings you experienced.
    Are you using the official Zephyr SDK toolchain or some other compiler? I wonder if it may be a case of NCS using a (partially) incompatible compiler in your case.
    Michal
  • Hi Michal,
    I am using the official Zephyr SDK toolchain, yes. Also, please note that -Wall -Wno-pointer-sign are used by default. I only highlighted them in my ticket because: with -Wall by itself you would expect to see the warnings, however, following it with -Wno-pointer-sign should turn off the warnings. An easy way to see the warning flags used is to issue the command line command "VERBOSE=1 west build" and let it get far enough to compile some .c files, and then look at any of the compile commands. So, I would recommend retrying without adding any flags. Most importantly, see my next paragraph, written in "real time."
    Also, sometimes I may have had to right click in the cloud-module.c file and select Run Code Analysis on Active File. I am not certain if that is necessary simply to speed things up or if there is a different reason for that being necessary. Okay, now I see why I had to right click select Run Code Analysis on Active File, and hopefully when you do that you will get my results. This warning comes from C_Cpp.codeAnalysis.clangTidy and involves the configuration setting C_Cpp.codeAnalysis.clangTidy.enabled. The default setting is "false", in which case you need to do the right click selection to make clangTidy run. So, it is clangTidy that is giving the wrong warnings on Linux and Mac. I look forward to hearing back from you with your findings.
  • I think I have a bit more insight but not all the answers. So, the warnings shown do not depend upon the warning flags used in the build. Instead, some warnings are enabled by default. To disable them, you can mouse over to the warning underline and then mouse on Quick Fix... in the pop up window then select Disable all clang-diagnostic-<warning> for example clang-diagnostic-pointer-sign. That will put json
    "C_Cpp.codeAnalysis.clangTidy.checks.disabled": ["clang-diagnostic-pointer-sign"]
    into the workspace settings.json. You can change that disabled to enabled to restore the warning or remove "clang-diagnostic-pointer-sign" to go back to the default enabled state.
    I can create a simple .c file in some Windows directory outside of my nRF work, for example
    int
    maint()
        unsigned char *b;
        char a[10];
        a[10] = 0;
        b=a;
        b[10] = 0;
        return 0;
    which will show the pointer-sign warning and also clang-diagnostic-array-bounds. Disabling it adds this to my settings.json:
    "C_Cpp.codeAnalysis.clangTidy.checks.disabled": ["clang-diagnostic-array-bounds"],
    The problem we have is that when using nrf-connect as a configuration provider, on Windows, the checks are always disabled. Linux and Mac behave--we can enable and disable the warnings.
    The question is why Windows misbehaves.
