trouble with nrf9160 modem firmware in a virgin chip 9160
hello,
I made a custom board that mounts a virgin nrf9160; its programming takes place via a tag connected to the segger programmer. I tried copying a whole chip with JFlash from a motato 9160 to a thingy91 and then flashing to the new one. It seems to take the application well but not the modem firmware. I did not understand if the entire erased and reprogrammed chip is dedicated only to applications and the modem is programmed separately. If so; how can I with the segger to inject only the modem firmware? Thank you
Silvio
  • Hello Silvio,
    I will have to get back to you on this.
    Elfving
  • Hello Elfving,
    I will wait for some news thanks.
    I don't understand if the chip already comes with the modem firmware and in any case, if I have the MODEM firmware file (eg. Xxx_1.3.2.zip) how can I inject it through the jlink SEGGER programmer? I tried to open it but there are more files ... I have no idea of the sequence and how to use it. My custom card is similar to thingy91 in serial port configuration so I should go from 52840 ... (???)
    a thousand thanks
  • *** Booting Zephyr OS build v3.0.99-ncs1  ***
    Flash regions           Domain          Permissions
    00 02 0x00000 0x18000   Secure          rwxl
    03 31 0x18000 0x100000  Non-Secure      rwxl
    Non-secure callable region 0 placed in flash region 2 with size 32.
    SRAM region             Domain          Permissions
    00 03 0x00000 0x08000   Secure          rwxl
    04 31 0x08000 0x40000   Non-Secure      rwxl
    Peripheral              Domain          Status
    00 NRF_P0               Non-Secure      OK
    01 NRF_CLOCK            Non-Secure      OK
    02 NRF_RTC0             Non-Secure      OK
    03 NRF_RTC1             Non-Secure      OK
    04 NRF_NVMC             Non-Secure      OK
    05 NRF_UARTE1           Non-Secure      OK
    06 NRF_UARTE2           Secure          SKIP
    07 NRF_TWIM2            Non-Secure      OK
    08 NRF_SPIM3            Non-Secure      OK
    09 NRF_TIMER0           Non-Secure      OK
    10 NRF_TIMER1           Non-Secure      OK
    11 NRF_TIMER2           Non-Secure      OK
    12 NRF_SAADC            Non-Secure      OK
    13 NRF_PWM0             Non-Secure      OK
    14 NRF_PWM1             Non-Secure      OK
    15 NRF_PWM2             Non-Secure      OK
    16 NRF_PWM3             Non-Secure      OK
    17 NRF_WDT              Non-Secure      OK
    18 NRF_IPC              Non-Secure      OK
    19 NRF_VMC              Non-Secure      OK
    20 NRF_FPU              Non-Secure      OK
    21 NRF_EGU0             Non-Secure      OK
    22 NRF_EGU1             Non-Secure      OK
    23 NRF_EGU2             Non-Secure      OK
    24 NRF_EGU3             Non-Secure      OK
    25 NRF_EGU4             Non-Secure      OK
    26 NRF_EGU5             Non-Secure      OK
    27 NRF_DPPIC            Non-Secure      OK
    28 NRF_REGULATORS       Non-Secure      OK
    29 NRF_PDM              Non-Secure      OK
    30 NRF_I2S              Non-Secure      OK
    31 NRF_GPIOTE1          Non-Secure      OK
    SPM: NS image at 0x18200
    SPM: NS MSP at 0x20022cb0
    SPM: NS reset vector at 0x2dc95
    SPM: prepare to jump to Non-Secure image.
    BT300:~$ *** Booting Zephyr OS build v3.0.99-ncs1  ***
    Version 1.2.7 UNIFIED TH 290822 1821 - BT300
    BT300 version:       1.2.7 UNIFIED TH 290822 1821
    BT300 build id:      custom
    BT300 build variant: beta
    Modem fw:            mfw-pti_nrf9160_1.1.2
    thread_service: initialized successfully
    leds: initialized successfully
    PWM-based LED fade
    main thread : intialized successfully
    Fall thread : intialized successfully
    AT+CNEC=16 failed, err 65536
    Release 14 features disable AT-command error, type 1 err 0
    BT300:~$
    GNSS: Failed to start GNSS
    start: starting GNSS failed, err -1
    Main thread has started !
    [00:00:01.568,481] <err> lte_lc: Failed to subscribe to CEREG notifications, error: 65536
    [00:00:01.568,511] <err> lte_lc: Failed to enable notifications
    [00:00:01.628,021] <err> lte_lc: Failed to subscribe to CEREG notifications, error: 65536
    [00:00:01.628,021] <err> lte_lc: Failed to enable notifications, error: -14
    [00:00:01.662,780] <err> nrf_modem: Modem error: 0xfff, PC: 0x0
    Failed to send AT command, err -1
    [STA]: A500000000000004
    [STA]: A500000000000007
    [STA]: A50000000000000B
    [STA]: A50000000000000F
    [STA]: A500000000000013
    [STA]: A500000000000017
    [STA]: A50000000000001A
    [STA]: A50000000000001E
    [STA]: A500000000000022
    [STA]: A500000000000026
    [STA]: A50000000000002A
    [STA]: A50000000000002D
    [STA]: A500000000000031
    [STA]: A500000000000035
    [STA]: A500000000000039
    [STA]: A50000000000003D
    [STA]: A500000000000040
    [STA]: A500000000000044
    [STA]: A500000000000048
    [STA]: A50000000000004C
    [STA]: A500000000000050
    [STA]: A500000000000053
    for completeness I have read some material around and I have learned that the firmware is inserted in the nrf9160 from the factory. So I just have to update it (now at revision 1.3.2.).
    I am sending you a piece of log to try to understand the errors I get from the modem I think. The application is the modem_shell for thingy91 modified for my uses, and obviously the connectivity_bridge on the 52840 side with BLE activated permanently.
    Everything works but I am not communicating with the modem. Could it be the firmware version that is old?
    I hope not to waste a lot of time
    Thank you
    BABOS
  • Hello, sorry about the wait.
    It doesn't really. It just comes with a basic test FW from the factory, and you would have to update it yourself. You can do this using the nRF Connect Programmer on nRF Connect for Desktop for instance. This video explains how its done, and the different files in the MFW zip file
    Did you allready manage to update the modem FW?
    What is the version of the nRF9160 you're using?
    Elfving
  • hello,
    i managed to insert modem firmware 1.3.2, via nrf connect with jlink programmer, following your suggestion.
    Now I can make it communicate via AT commands. Now it doesn't seem to see the SIM Card; i need to check the hardware and i will let you know.
    Meanwhile, I thank you for your advice
    Babos
  • No problem at all,
    Let me know how it works out.
    Elfving
