USB CDC ACM and Central UART
Hello
I need to combine USB CDC ACM and BLE Central role on the nrf5340dk, using nrf Connect SDK v1.9.1. I started from Peripheral UART Sample with the USB CDC ACM extension and then I changed the configuration in prj.conf to the Central role, acording to BLE Central Sample like this:
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
# Enable the NUS service
CONFIG_BT_NUS=y
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_DM=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
I also made changes in the main, to act as Central:
#include "uart_async_adapter.h"
#include <zephyr/types.h>
#include <zephyr.h>
#include <drivers/uart.h>
#include <usb/usb_device.h>
#include <device.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <settings/settings.h>
#include <stdio.h>
#include <logging/log.h>
#include <errno.h>
//#include <zephyr.h>
#include <sys/byteorder.h>
#include <sys/printk.h>
#include <bluetooth/conn.h>
#include <bluetooth/services/nus_client.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 20
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_RX_TIMEOUT 50
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static const struct device *uart;
static struct k_work_delayable uart_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static struct bt_conn *default_conn;
static struct bt_nus_client nus_client;
#if CONFIG_BT_NUS_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
static const struct device *const async_adapter;
static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
					const uint8_t *const data, uint16_t len)
	ARG_UNUSED(nus);
	struct uart_data_t *buf;
	/* Retrieve buffer context. */
	buf = CONTAINER_OF(data, struct uart_data_t, data);
	k_free(buf);
	k_sem_give(&nus_write_sem);
	if (err) {
		LOG_WRN("ATT error code: 0x%02X", err);
static uint8_t ble_data_received(struct bt_nus_client *nus,
						const uint8_t *data, uint16_t len)
	ARG_UNUSED(nus);
	int err;
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return BT_GATT_ITER_CONTINUE;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static uint8_t *current_buf;
	static size_t aborted_len;
	static bool buf_release;
	static uint8_t *aborted_buf;
	switch (evt->type) {
	case UART_TX_DONE:
		LOG_DBG("tx_done");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("rx_rdy");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		buf_release = false;
		if (buf->len == UART_BUF_SIZE) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
			  (evt->data.rx.buf[buf->len - 1] == '\r')) {
			current_buf = evt->data.rx.buf;
			buf_release = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("rx_disabled");
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("rx_buf_request");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG("rx_buf_released");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf_release && (current_buf != evt->data.rx_buf.buf)) {
			k_free(buf);
			current_buf = NULL;
	case UART_TX_ABORTED:
			LOG_DBG("tx_aborted");
			if (!aborted_buf) {
				aborted_buf = (uint8_t *)evt->data.tx.buf;
			aborted_len += evt->data.tx.len;
					   data);
			uart_tx(uart, &buf->data[aborted_len],
				buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	uart = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
	if (!uart) {
		LOG_ERR("UART binding failed");
		return -ENXIO;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err) {
			LOG_ERR("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_BT_NUS_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		LOG_ERR("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		LOG_INF("Wait for DTR");
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr) {
			//Give CPU resources to low priority threads.
			k_sleep(K_MSEC(100));
		LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			LOG_WRN("Failed to set DSR, ret code %d", err);
	if (tx) {
		pos = snprintf(tx->data, sizeof(tx->data),
			       "Starting Nordic UART service example\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data))) {
			k_free(tx);
			LOG_ERR("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
	} else {
		return -ENOMEM;
	if (err) {
		LOG_ERR("Cannot display welcome message (err: %d)", err);
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data), UART_RX_TIMEOUT);
static void discovery_complete(struct bt_gatt_dm *dm,
			       void *context)
	struct bt_nus_client *nus = context;
	LOG_INF("Service discovery completed");
	bt_gatt_dm_data_print(dm);
	bt_nus_handles_assign(dm, nus);
	bt_nus_subscribe_receive(nus);
	bt_gatt_dm_data_release(dm);
static void discovery_service_not_found(struct bt_conn *conn,
					void *context)
	LOG_INF("Service not found");
static void discovery_error(struct bt_conn *conn,
			    int err,
			    void *context)
	LOG_WRN("Error while discovering GATT database: (%d)", err);
struct bt_gatt_dm_cb discovery_cb = {
	.completed         = discovery_complete,
	.service_not_found = discovery_service_not_found,
	.error_found       = discovery_error,
static void gatt_discover(struct bt_conn *conn)
	int err;
	if (conn != default_conn) {
		return;
	err = bt_gatt_dm_start(conn,
			       BT_UUID_NUS_SERVICE,
			       &discovery_cb,
			       &nus_client);
	if (err) {
		LOG_ERR("could not start the discovery procedure, error "
			"code: %d", err);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
	if (!err) {
		LOG_INF("MTU exchange done");
	} else {
		LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err)
	int err;
	if (conn_err) {
		LOG_INF("Failed to connect to %s (%d)", log_strdup(addr),
			conn_err);
		if (default_conn == conn) {
			bt_conn_unref(default_conn);
			default_conn = NULL;
			err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
			if (err) {
				LOG_ERR("Scanning failed to start (err %d)",
					err);
		return;
	LOG_INF("Connected: %s", log_strdup(addr));
	static struct bt_gatt_exchange_params exchange_params;
	exchange_params.func = exchange_func;
	err = bt_gatt_exchange_mtu(conn, &exchange_params);
	if (err) {
		LOG_WRN("MTU exchange failed (err %d)", err);
	err = bt_conn_set_security(conn, BT_SECURITY_L2);
	if (err) {
		LOG_WRN("Failed to set security: %d", err);
		gatt_discover(conn);
	err = bt_scan_stop();
	if ((!err) && (err != -EALREADY)) {
		LOG_ERR("Stop LE scan failed (err %d)", err);
	int err;
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr),
		reason);
	if (default_conn != conn) {
		return;
	if (err) {
			err);
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
	.security_changed = security_changed
static void scan_filter_match(struct bt_scan_device_info *device_info,
			      struct bt_scan_filter_match *filter_match,
			      bool connectable)
	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
	LOG_INF("Filters matched. Address: %s connectable: %d",
		log_strdup(addr), connectable);
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
	default_conn = bt_conn_ref(conn);
static int nus_client_init(void)
	int err;
	struct bt_nus_client_init_param init = {
		.cb = {
			.received = ble_data_received,
			.sent = ble_data_sent,
	err = bt_nus_client_init(&nus_client, &init);
	if (err) {
		LOG_ERR("NUS Client initialization failed (err %d)", err);
		return err;
	LOG_INF("NUS Client module initialized");
	return err;
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
		scan_connecting_error, scan_connecting);
static int scan_init(void)
	int err;
	struct bt_scan_init_param scan_init = {
		.connect_if_match = 1,
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
	if (err) {
		LOG_ERR("Scanning filters cannot be set (err %d)", err);
		return err;
	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
	if (err) {
		LOG_ERR("Filters cannot be turned on (err %d)", err);
		return err;
	LOG_INF("Scan module initialized");
	return err;
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_WRN("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.cancel = auth_cancel,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
static void configure_gpio(void)
	int err;
	err = dk_leds_init();
	if (err) {
		LOG_ERR("Cannot init LEDs (err: %d)", err);
void main(void)
	int err = 0;
	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
	if (err) {
		LOG_ERR("Failed to register authorization callbacks.");
		return;
	err = bt_enable(NULL);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)", err);
		return;
	LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	int (*module_init[])(void) = {uart_init, scan_init, nus_client_init};
	for (size_t i = 0; i < ARRAY_SIZE(module_init); i++) {
		err = (*module_init[i])();
		if (err) {
			return;
	printk("Starting Bluetooth Central UART example\n");
	if (err) {
		LOG_ERR("Scanning failed to start (err %d)", err);
		return;
	LOG_INF("Scanning successfully started");
	for (;;) {
void ble_write_thread(void)
	int err;
	// Don't go any further until BLE is initialized
	k_sem_take(&ble_init_ok, K_FOREVER);
	for (;;) {
		// Wait indefinitely for data to be sent over bluetooth
		struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		err = bt_nus_client_send(&nus_client, buf->data, buf->len);
		if (err) {
			LOG_WRN("Failed to send data over BLE connection"
				"(err %d)", err);
		err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
		if (err) {
			LOG_WRN("NUS send timeout");
		k_free(buf);
K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
		NULL, PRIORITY, 0, 0);
but when I set in CMakeLists
set(OVERLAY_CONFIG "prj_cdc.conf")
set(DTC_OVERLAY_FILE "usb.overlay")
the virtual COM does not appear.
I did not make any changes to uart_async_adapter.c, uart_async_adapter.h, Kcongig or prj_cdc.conf.
Is it possible, that Central role and virtual COM Port are in some type of collision or do I need to define something extra compared to Peripheral Role?
Thanks a lot for every advice!
