Help with computing correct SAADC output value
I am using an Nrf52840 and sdk V14.2.0.
My question is how to compute the battery voltage based on my hardware.
The hardware uses AIN0 to measure.
The hardware has a resistor divider: GPIO output pin >---806K---X---->2M------>GND.
AIN0 is connected at point X above. The GPIO pin is configured as an output and set to a logic 1.
How would I scale the reading taken this way to represent a supply voltage of 3V?
With 3V as VDD AIN0 would see 2V I believe.
I use default config so gain is 1/6.
Battery has no protection diode in series.
Thanks.
