sd_ble_gap_adv_set_configure() and ble_advertising_start() failed with errCode 0x8
Triggering advertising by button pressed. But when advertising state is not idle. Both sd_ble_gap_adv_set_configure() and ble_advertising_start() failed with errCode 0x8.
00> <info> app: POWER_ON.
00> <info> app: BLE_ADV_EVT_FAST
00> <info> app: NRF_GPIOTE_POLARITY_TOGGLE
00> <info> app: button released
00>
00> <info> app: button pressed
00> <warning> app: sd_ble_gap_adv_set_configure() failed, ret=0x8
00> <warning> app: ble_advertising_start() failed errCode=0x8
00>
00> <info> app: BLE_ADV_EVT_IDLE
  • #include "sdk_config.h"
    #include "advertising.h"
    #include "ble_types.h"
    #include "ble_nus.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "error.h"
    #include "nrf_log.h"
    #include "nrf_sdh_ble.h"
    #define APP_ADV_INTERVAL               800             /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION               1800            /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_ADV_FAST_DURATION          0//1800          /**< The advertising duration of fast advertising in units of 10 milliseconds. */
    #define APP_ADV_SLOW_DURATION          0//1800          /**< The advertising duration of slow advertising in units of 10 milliseconds. */
    #define APP_ADV_FAST_INTERVAL          MSEC_TO_UNITS(500, UNIT_0_625_MS)        /**< The advertising interval (in units of 0.625 ms). The default value corresponds to 25 ms. */
    #define APP_ADV_SLOW_INTERVAL          MSEC_TO_UNITS(500, UNIT_0_625_MS)        /**< Slow advertising interval (in units of 0.625 ms). The default value corresponds to 2 seconds. */
    #define NUS_SERVICE_UUID_TYPE          BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    BLE_ADVERTISING_DEF(_gAdvertising);  /**< Advertising module instance. */
    static ble_uuid_t _gAdvUuids[]          = {                                         /**< Universally unique service identifier. */
    #if 0
    static void _sleepModeEnter(void) {
        ret_code_t errCode;
        errCode = bsp_indication_set(BSP_INDICATE_IDLE);
        if (errCode != NRF_SUCCESS) {
            NRF_LOG_WARNING("bsp_indication_set() failed, errCode=0x%x\n", errCode);
            return;
        // Prepare wakeup buttons.
        errCode = bsp_btn_ble_sleep_mode_prepare();
            NRF_LOG_WARNING("bsp_btn_ble_sleep_mode_prepare() failed, errCode=0x%x\n", errCode);
            return;
        errCode = sd_power_system_off();
    #ifndef DEBUG_NRF
            NRF_LOG_WARNING("sd_power_system_off() failed, errCode=0x%x\n", errCode);
            return;
     * @details This function is called for advertising events that are passed to the application.
    static void _advertisingEvtHandler(ble_adv_evt_t evt) {
        ret_code_t errCode;
        switch (evt) {
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("BLE_ADV_EVT_FAST");
                errCode = bsp_indication_set(BSP_INDICATE_ADVERTISING);
                    return;
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("BLE_ADV_EVT_IDLE");
    #if 0
    int advertisingInit(void) {
        ret_code_t errCode;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = false;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(_gAdvUuids) / sizeof(_gAdvUuids[0]);
        init.advdata.uuids_complete.p_uuids  = _gAdvUuids;
        init.srdata.uuids_complete.uuid_cnt = sizeof(_gAdvUuids) / sizeof(_gAdvUuids[0]);
        init.srdata.uuids_complete.p_uuids  = _gAdvUuids;
        init.config.ble_adv_whitelist_enabled = false;
        init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout  = APP_ADV_FAST_DURATION;
        init.config.ble_adv_slow_enabled  = true;
        init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
        init.config.ble_adv_slow_timeout  = APP_ADV_SLOW_DURATION;
        init.evt_handler = _advertisingEvtHandler;
        errCode = ble_advertising_init(&_gAdvertising, &init);
            NRF_LOG_WARNING("ble_advertising_init() failed errCode=0x%x", errCode);
            return ERROR_ADVERTISING_INITIALIZE_FAIL;
        ble_advertising_conn_cfg_tag_set(&_gAdvertising, APP_BLE_CONN_CFG_TAG);
        return 0;
    #else
        uint32_t               errCode;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        return 0;
    ble_adv_modes_config_t advertisingConfigGet(void) {
        ble_adv_modes_config_t config;
        memset(&config, 0, sizeof(ble_adv_modes_config_t));
        config.ble_adv_fast_enabled           = true;
        config.ble_adv_on_disconnect_disabled = true;
        return config;
    void advertisingModesConfigSet(void) {
        const ble_adv_modes_config_t config = advertisingConfigGet();
        ble_advertising_modes_config_set(&_gAdvertising, &config);
    /* Function for starting advertising. */
    int advertisingStart(void) {
        const ret_code_t errCode = ble_advertising_start(&_gAdvertising, BLE_ADV_MODE_FAST);
            NRF_LOG_WARNING("ble_advertising_start() failed errCode=0x%x", errCode);
            return ERROR_ADVERTISING_START_FAIL;
        return 0;
    #include "app_button.h"
    #include "app_timer.h"
    #include "band_nctu.h"
    #include "button.h"
    #include "error.h"
    #include "nrf_drv_gpiote.h"
    #include "timer.h"
    #define APP_BUTTON_UNKNOWN      2
    #define PIN_IN F1_BUTTON_1
    #define BUTTON_NUMBER           1
    #define BUTTON_DETECTION_DELAY  APP_TIMER_TICKS(50)    /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    typedef enum {
        BUTTON_PRESS = 0,
        BUTTON_RELEASE
    } button_state_t;
    static bool _gButtonInitialized = false;
    static uint8_t _gButtonAction   = APP_BUTTON_UNKNOWN;
    void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) {
        switch (action) {
            case NRF_GPIOTE_POLARITY_LOTOHI:
                NRF_LOG_DEBUG("NRF_GPIOTE_POLARITY_LOTOHI\n");
            case NRF_GPIOTE_POLARITY_HITOLO:
                NRF_LOG_DEBUG("NRF_GPIOTE_POLARITY_HITOLO\n");
            case NRF_GPIOTE_POLARITY_TOGGLE:
                NRF_LOG_INFO("NRF_GPIOTE_POLARITY_TOGGLE\n");
                const uint32_t buttonState = nrf_gpio_pin_read(F1_BUTTON_1);
                if (buttonState == BUTTON_PRESS) {
                    NRF_LOG_INFO("button pressed\n");
                    advertisingStart();
                    timerButtonLongPressStart();
                    _gButtonAction = BUTTON_PRESS;
                } else {
                    NRF_LOG_INFO("button released\n");
                    _gButtonAction = BUTTON_RELEASE;
    int buttonInit(void) {
        ret_code_t errCode;
        nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        in_config.pull = NRF_GPIO_PIN_PULLUP;
        errCode = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
            NRF_LOG_WARNING("nrf_drv_gpiote_in_init() failed, errCode=0x%x\n", errCode);
            return ERROR_BUTTON_INITIALIZE_FAIL;
        nrf_drv_gpiote_in_event_enable(PIN_IN, true);
            _gButtonAction = APP_BUTTON_PUSH;
        _gButtonInitialized = true;
        return 0;
    #if 0
    void button_events_init(void) {
        nrf_gpio_cfg_input(BUTTON_1,NRF_GPIO_PIN_PULLUP);
        timerButtonScanStart();
  • Looking at the documentation for sd_ble_gap_adv_set_configure() and nrf_error.h I can find that 8 means NRF_ERROR_INVALID_STATE.
    /**@brief Configure an advertising set. Set, clear or update advertising and scan response data.
     * @note  The format of the advertising data will be checked by this call to ensure interoperability.
     *        Limitations imposed by this API call to the data provided include having a flags data type in the scan response data and
     *        duplicating the local name in the advertising data and scan response data.
     * @note In order to update advertising data while advertising, new advertising buffers must be provided.
     * @mscs
     * @mmsc{@ref BLE_GAP_ADV_MSC}
     * @endmscs
     * @param[in,out] p_adv_handle                         Provide a pointer to a handle containing @ref BLE_GAP_ADV_SET_HANDLE_NOT_SET to configure
     *                                                     a new advertising set. On success, a new handle is then returned through the pointer.
     *                                                     Provide a pointer to an existing advertising handle to configure an existing advertising set.
     * @param[in]     p_adv_data                           Advertising data. If set to NULL, no advertising data will be used. See @ref ble_gap_adv_data_t.
     * @param[in]     p_adv_params                         Advertising parameters. When this function is used to update advertising data while advertising,
     *                                                     this parameter must be NULL. See @ref ble_gap_adv_params_t.
     * @retval ::NRF_SUCCESS                               Advertising set successfully configured.
     * @retval ::NRF_ERROR_INVALID_PARAM                   Invalid parameter(s) supplied:
     *                                                      - Invalid advertising data configuration specified. See @ref ble_gap_adv_data_t.
     *                                                      - Invalid configuration of p_adv_params. See @ref ble_gap_adv_params_t.
     *                                                      - Use of whitelist requested but whitelist has not been set,
     *                                                        see @ref sd_ble_gap_whitelist_set.
     * @retval ::BLE_ERROR_GAP_INVALID_BLE_ADDR            ble_gap_adv_params_t::p_peer_addr is invalid.
     * @retval ::NRF_ERROR_INVALID_STATE                   Invalid state to perform operation. Either:
     *                                                     - It is invalid to provide non-NULL advertising set parameters while advertising.
     *                                                     - It is invalid to provide the same data buffers while advertising. To update
     *                                                       advertising data, provide new advertising buffers.
     * @retval ::BLE_ERROR_GAP_DISCOVERABLE_WITH_WHITELIST Discoverable mode and whitelist incompatible.
     * @retval ::BLE_ERROR_INVALID_ADV_HANDLE              The provided advertising handle was not found. Use @ref BLE_GAP_ADV_SET_HANDLE_NOT_SET to
     *                                                     configure a new advertising handle.
     * @retval ::NRF_ERROR_INVALID_ADDR                    Invalid pointer supplied.
     * @retval ::NRF_ERROR_INVALID_FLAGS                   Invalid combination of advertising flags supplied.
     * @retval ::NRF_ERROR_INVALID_DATA                    Invalid data type(s) supplied. Check the advertising data format specification
     *                                                     given in Bluetooth Specification Version 5.0, Volume 3, Part C, Chapter 11.
     * @retval ::NRF_ERROR_INVALID_LENGTH                  Invalid data length(s) supplied.
     * @retval ::NRF_ERROR_NOT_SUPPORTED                   Unsupported data length or advertising parameter configuration.
     * @retval ::NRF_ERROR_NO_MEM                          Not enough memory to configure a new advertising handle. Update an
     *                                                     existing advertising handle instead.
     * @retval ::BLE_ERROR_GAP_UUID_LIST_MISMATCH Invalid UUID list supplied.
    SVCALL(SD_BLE_GAP_ADV_SET_CONFIGURE, uint32_t, sd_ble_gap_adv_set_configure(uint8_t *p_adv_handle, ble_gap_adv_data_t const *p_adv_data, ble_gap_adv_params_t const *p_adv_params));
    I suggest to read the description for NRF_ERROR_INVALID_STATE and see if any of those explain your issue.
    Kenneth
