Example for enabling BLE_ADV_EVT_SLOW mode
Adverting mode changing from BLE_ADV_EVT_FAST to BLE_ADV_EVT_IDLE. Could you provide example for changing adverting mode from BLE_ADV_EVT_FAST to BLE_ADV_EVT_SLOW mode?
The following is log messages of nRF52832 device.
00> <info> app: POWER_ON.
00> <info> app: BLE_ADV_EVT_FAST
00> <info> app: BLE_ADV_EVT_IDLE
  • #include "sdk_config.h"
    #include "advertising.h"
    #include "ble_types.h"
    #include "ble_nus.h"
    #include "bsp.h"
    #include "bsp_btn_ble.h"
    #include "error.h"
    #include "nrf_log.h"
    #include "nrf_sdh_ble.h"
    #define APP_ADV_INTERVAL               800             /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION               1800            /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_ADV_FAST_DURATION          0//1800          /**< The advertising duration of fast advertising in units of 10 milliseconds. */
    #define APP_ADV_SLOW_DURATION          0//1800          /**< The advertising duration of slow advertising in units of 10 milliseconds. */
    #define APP_ADV_FAST_INTERVAL          MSEC_TO_UNITS(500, UNIT_0_625_MS)        /**< The advertising interval (in units of 0.625 ms). The default value corresponds to 25 ms. */
    #define APP_ADV_SLOW_INTERVAL          MSEC_TO_UNITS(500, UNIT_0_625_MS)        /**< Slow advertising interval (in units of 0.625 ms). The default value corresponds to 2 seconds. */
    #define NUS_SERVICE_UUID_TYPE          BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    typedef enum {
        ADV_STATE_IDLE,               /**< Idle; no connectable advertising is ongoing. */
        ADV_STATE_DIRECTED_HIGH_DUTY, /**< Directed advertising (high duty cycle) attempts to connect to the most recently disconnected peer. */
        ADV_STATE_DIRECTED,           /**< Directed advertising (low duty cycle) attempts to connect to the most recently disconnected peer. */
        ADV_STATE_FAST,               /**< Fast advertising will connect to any peer device, or filter with a whitelist if one exists. */
        ADV_STATE_SLOW,               /**< Slow advertising is similar to fast advertising. By default, it uses a longer advertising interval and time-out than fast advertising. However, these options are defined by the user. */
    } adv_state_t;
    BLE_ADVERTISING_DEF(_gAdvertising);  /**< Advertising module instance. */
    static ble_uuid_t _gAdvUuids[]          = {                                         /**< Universally unique service identifier. */
    static adv_state_t _gAdvState = ADV_STATE_IDLE;
    #if 0
    static void _sleepModeEnter(void) {
        ret_code_t errCode;
        errCode = bsp_indication_set(BSP_INDICATE_IDLE);
        if (errCode != NRF_SUCCESS) {
            NRF_LOG_WARNING("bsp_indication_set() failed, errCode=0x%x\n", errCode);
            return;
        // Prepare wakeup buttons.
        errCode = bsp_btn_ble_sleep_mode_prepare();
            NRF_LOG_WARNING("bsp_btn_ble_sleep_mode_prepare() failed, errCode=0x%x\n", errCode);
            return;
        errCode = sd_power_system_off();
    #ifndef DEBUG_NRF
            NRF_LOG_WARNING("sd_power_system_off() failed, errCode=0x%x\n", errCode);
            return;
     * @details This function is called for advertising events that are passed to the application.
    static void _advEvtHandler(ble_adv_evt_t evt) {
        ret_code_t errCode;
        switch (evt) {
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("BLE_ADV_EVT_FAST");
                _gAdvState = ADV_STATE_FAST;
                errCode = bsp_indication_set(BSP_INDICATE_ADVERTISING);
                    return;
            case BLE_ADV_EVT_SLOW:
                NRF_LOG_INFO("BLE_ADV_EVT_SLOW");
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("BLE_ADV_EVT_IDLE");
    #if 0
    int advertisingInit(void) {
        ret_code_t errCode;
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = false;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(_gAdvUuids) / sizeof(_gAdvUuids[0]);
        init.advdata.uuids_complete.p_uuids  = _gAdvUuids;
        init.srdata.uuids_complete.uuid_cnt = sizeof(_gAdvUuids) / sizeof(_gAdvUuids[0]);
        init.srdata.uuids_complete.p_uuids  = _gAdvUuids;
        init.config.ble_adv_whitelist_enabled = false;
        init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
        init.config.ble_adv_fast_timeout  = APP_ADV_FAST_DURATION;
        init.config.ble_adv_slow_enabled  = true;
        init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
        init.config.ble_adv_slow_timeout  = APP_ADV_SLOW_DURATION;
        init.evt_handler = _advertisingEvtHandler;
        errCode = ble_advertising_init(&_gAdvertising, &init);
            NRF_LOG_WARNING("ble_advertising_init() failed errCode=0x%x", errCode);
            return ERROR_ADVERTISING_INITIALIZE_FAIL;
        ble_advertising_conn_cfg_tag_set(&_gAdvertising, APP_BLE_CONN_CFG_TAG);
        return 0;
    #else
    int advInit(void) {
        uint32_t               errCode;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.evt_handler = _advEvtHandler;
        return 0;
    ble_adv_modes_config_t advConfigGet(void) {
        ble_adv_modes_config_t config;
        memset(&config, 0, sizeof(ble_adv_modes_config_t));
        config.ble_adv_fast_enabled           = true;
        config.ble_adv_on_disconnect_disabled = true;
        return config;
    void advModesConfigSet(void) {
        const ble_adv_modes_config_t config = advConfigGet();
        ble_advertising_modes_config_set(&_gAdvertising, &config);
    /* Function for starting advertising. */
    int advStart(void) {
        if (_gAdvState == ADV_STATE_IDLE) {
            const ret_code_t errCode = ble_advertising_start(&_gAdvertising, BLE_ADV_MODE_FAST);
                NRF_LOG_WARNING("ble_advertising_start() failed errCode=0x%x", errCode);
                return ERROR_ADVERTISING_START_FAIL;
        return 0;
  • Hi.
    Closing this as a duplicate:
    How to configure for changing advertising mode slowly?
    Let's discuss your issue in the other ticket.
    Br,
    Joakim
