UARTE
In UART async mode (CONFIG_UART_ASYNC_API=y) the UART transmit data and receive callback works fine. I've been able to set up the callback and enable the rx.
After switching to UARTE (CONFIG_NRFX_UARTE0=y), the UART transmit once, but the event handler is never called.
UARTE is set up like example from: "C:\ncs\v2.0.0\zephyr\samples\boards\nrf\nrfx_prs\src\main.c", the baudrate is set to 9600. nrfx_uarte_init() and nrfx_uarte_tx() show NRFX_SUCCESS. When nrfx_uarte_tx_in_progress() call is added, just after nrfx_uarte_tx(),  nrfx_uarte_tx_in_progress() hangs without any further (log) message.
Is it possible to implement UARTE like this on nRF9160 development board?
Do you need to enable rx on UARTE?
Is there any working sample for nRF9160?
    can you show the part of the code where you call these functions? If you want to, you can include the entire project.
  • // UARTE set up
    PINCTRL_DT_DEFINE(CONSOLE_NODE);
    nrfx_err_t nrfxError;
    nrfx_uarte_config_t uarte_config = NRFX_UARTE_DEFAULT_CONFIG(NRF_UARTE_PSEL_DISCONNECTED, NRF_UARTE_PSEL_DISCONNECTED);
    uarte_config.baudrate = NRF_UARTE_BAUDRATE_9600;
    uarte_config.skip_gpio_cfg = true;
    uarte_config.skip_psel_cfg = true;
    iReturn = pinctrl_apply_state(PINCTRL_DT_DEV_CONFIG_GET(CONSOLE_NODE), PINCTRL_STATE_DEFAULT);
    if(iReturn != 0) {
    LOG_ERR("pinctrl_apply_state() failed: 0x%08x", iReturn);
    nrfxError = nrfx_uarte_init(&uarte, &uarte_config, uarte_handler);
    if(nrfxError != NRFX_SUCCESS) {
    LOG_ERR("nrfx_uarte_init() failed: 0x%08x", nrfxError);
    // UARTE transmit
    nrfxError = nrfx_uarte_tx(&uarte, p, u8Cnt);
    if(nrfxError == NRFX_SUCCESS) {
    if(nrfx_uarte_tx_in_progress(&uarte)) {
    bTransmitted = true;
    } else {
    LOG_ERR("nrfx_uarte_tx_in_progress(): UARTE is not transmitting");
    } else {
    LOG_ERR("nrfx_uarte_tx() failed: 0x%08x", nrfxError);
    // UARTE callback
    static void uarte_handler(const nrfx_uarte_event_t *p_event, void *p_context)
    if (p_event->type == NRFX_UARTE_EVT_RX_DONE) {
    iReceived = p_event->data.rxtx.bytes;
    } else if (p_event->type == NRFX_UARTE_EVT_ERROR) {
    iReceived = 0;
  • What if the UART configuration is CONFIG_UART_ASYNC_API=y and CONFIG_NRFX_UARTE0=y
    and the standard uart functions uart_callback_set(..., uart_console_cb, ...), uart_rx_enable(), uart_tx() are used.
    In that case the receive callback works, but is in this case UARTE mode active?
    If yes, how can I check this?
    How is "uarte" defined?
  • static nrfx_uarte_t     uarte   = NRFX_UARTE_INSTANCE(0);
