Hi guys,
I am using SPIS to receive data from a camera and use UART to put this data back into the terminal. However, I noticed that my UART wouldn't print anything as long as I enabled the SPIS. I do use retargeting to make sure app_uart_put is working as expected. BTW, uart works fine when I disable the SPIS.
void uart_spis_init() {
uint32_t err_code;
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.csn_pin = APP_SPIS_CS_PIN;
spis_config.miso_pin = APP_SPIS_MISO_PIN;
spis_config.mosi_pin = APP_SPIS_MOSI_PIN;
spis_config.sck_pin = APP_SPIS_SCK_PIN;
spis_config.irq_priority = APP_SPIS_IRQ_PRIORITY;
APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
NRF_UART_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_HIGHEST,
err_code);
void spis_event_handler(nrf_drv_spis_event_t event)
if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
spis_xfer_done = true;
app_uart_put("K");
ret_code_t err_code;
err_code = nrf_drv_gpiote_init(); // Initialize the GPIOTE
uart_spis_init();
while (true)
spis_xfer_done = false;
app_uart_put('A'); #uart output testing
memset(m_rx_buf, 0, m_rx_length);
APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_tx_length, m_rx_buf, m_rx_length));
while (!spis_xfer_done);
