For reference I am using NCS v2.0 and VSCode with the NCS extension and coding in C++.
Hi, can you help clarify the expected behavior and usage of the MPSL_TIMESLOT_SIGNAL_RADIO signal?
I can see a few details from the MPSL API page (link)
void MPSL_IRQ_RADIO_Handler(void)
RADIO interrupt handler.Note: This handler should be placed in the interrupt vector table. The interrupt priority level should be priority 0.
This signal indicates the RADIO interrupt. The signal will be executed in the same context as MPSL_IRQ_RADIO_Handler.
It isn't clear to me the meaning of how to use this information.
I have found the Nordic blog post Updating to the MPSL Timeslot interface regarding MPSL and ESB.
Looking at the source code, the MPSL_TIMESLOT_SIGNAL_RADIO event triggers calling RADIO_IRQHandler().
I can see in the nrf esb.c file there is such a function
ISR_DIRECT_DECLARE(RADIO_IRQHandler)
radio_irq_handler();
ISR_DIRECT_PM();
return 1;
Question 1
So it seems that the Nordic example is what, receiving radio interrupts and routing them to the MPSL_TIMESLOT_SIGNAL_RADIO event?
Should I understand that if I'm driving another radio protocol, like ESB, that I have to forward radio event notifications to that protocol's radio ISR?
I have confirmed by implementing this that calling RADIO_IRQHandler() is necessary for the ESB example to work.
Question 2
Regarding the API page, for the MPSL_IRQ_RADIO_Handler(), when it says "This handler should be placed in the interrupt vector table", what does that mean? Am I able to put the RADIO_IRQHandler() into an interrupt vector so I don't have to call it from the MPSL_TIMESLOT_SIGNAL_RADIO event myself?
Question 3
I can't seem to get access to the RADIO_IRQHandler() from my code without modifying the esb.h file to put an extern statement at the top.
extern void RADIO_IRQHandler();
I'm kind of baffled by that, I tried putting the exact same extern statement into the C++ file of my application and I get undefined reference to `RADIO_IRQHandler()' when compiling. Unclear why or how I can work around that. I don't want to edit the esb.h file. Can you suggest what I do differently?
Thanks.
