Error while setting up device 000683855816: Error: No firmware defined for selected device
I am using a power profiler from my Win10 laptop, to test my nrf52 PDK.
The NRF Connect version is 3.11.1 and the Power profiler app version is 3.2.0
I am working with the PPK and nrf52 PDK board.
Initially, all worked ok means I am able to see the current consumption of the board as per the firmware uploaded in the nrf52 PDK board in the power profiler app.
But, by mistake, I uploaded the " ble_app_beacon " firmware into the nrf52 PDK while the PPK board is attached to it.
So might be it corrupted the PPK board firmware bcoz, after that, the LED1 on the PPK board was not glowing.
I searched and found the firmware of PPK from the Nordic site https://www.nordicsemi.com/Products/Development-hardware/Power-Profiler-Kit/Download#infotabs and uploaded the " ppk_110.hex " file into the PPK board via J link Programmer.
After that, the LED1 on PPK is turned on. Then I checked whether everything is working or not by following the procedure mentioned in the below video link from nordic https://www.youtube.com/watch?v=JBKeHlOcO_g
But I have got the below error while selecting a device from the " SELECT DEVICE " tab of the power profiler app,
14:12:35.842 Validating firmware for device with s/n 000683855816
14:12:35.866 Error while setting up device 000683855816: Error: No firmware defined for selected device
14:12:35.867 Deselecting device
I am also getting the same error while the PPK board is not attached to the nrf52 PDK board (P22 is connected via a short link), I have tried different data cables and also used the nrf52 DK board.
I have searched for the error is there any solution but have not succeeded
Please help me to resolve this error.
  • Actually, after this error arrived I downgraded the power profiler app as some solutions are mentioned on the nordic devzone site. for trying to resolve the issue.
    Yes, I have tried the update but still, the issue remains.
    My issue is resolved after I tried with another PC and it worked.
    Thank you, Kenneth.
    But I don't understand that I have uninstalled and installed the nordic desktop app many times and also used different versions of it but the issue is not resolved. can you please tell me what exactly happens? because it does not work with my pc.
    Is there any solution to this?
