Using K_timer in Zephyr NCS 1.8.0 to initiate a BLE disconnection on Central
I am using nRF Connect SDK 1.8.0 on the nRF52840.  I want to limit the amount of time that a peripheral can connect to my central 52840.  On connection start I initiate a timer following the K_timer convention set by zephyr and it times out properly.  I want to use the timeout handler function to call
int bt_conn_disconnect(struct bt_conn *conn, uint8_t reason)
I have used asynchronous functions to handle the connection and disconnection events but I had to register their callbacks using the struct
static struct bt_conn_cb connection_callbacks
Since there is no BLE event I'm timing out with, I wasn't sure how to get the bt_conn object to the timer's timeout handling function.  I assume that the on_connected or on_disconnected events are receiving the bt_conn object through the event handler, but I was not sure about this.  I tried to make the bt_conn object a static global var within the file, but in the timer handler the bt_conn_disconnect function fails with ENOTCONN (-128) so it seems it isn't accepting the bt_conn object correctly.
What would be the best way to correctly give the bt_conn object to the timer's timeout handling function here?
Thanks!
  • Your link is broken and you didn't answer any of the questions in my post.  I will look for the peripheral_uart sample elsewhere though.
    I am sorry as the first link was broken.  Now you can check the link and also if you can find this in the NCS folder (nrf\samples\bluetooth\peripheral_uart).
    If you declare the bt_conn object the way it is in the peripheral_uart sample, then it should act a global variable which can be used in your connection and disconnection function. Both connection and disconnection are defined from callback function.
    static struct bt_conn *current_conn
    static void connected(struct bt_conn *conn, uint8_t err)
    	if (err) {
    		LOG_ERR("Connection failed (err %u)", err);
    		return;
    	LOG_INF("Connected %s", addr);
    	current_conn = bt_conn_ref(conn);
    	dk_set_led_on(CON_STATUS_LED);
    	LOG_INF("Disconnected: %s (reason %u)", addr, reason);
    	if (auth_conn) {
    		bt_conn_unref(auth_conn);
    		auth_conn = NULL;
    	if (current_conn) {
    		bt_conn_unref(current_conn);
    		current_conn = NULL;
    		dk_set_led_off(CON_STATUS_LED);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected    = connected,
    	.disconnected = disconnected,
    #ifdef CONFIG_BT_NUS_SECURITY_ENABLED
    	.security_changed = security_changed,
    BR
    Kazi
  • Got it working with this, thanks for the help and no problem about the link issue.
