matter otbr problem
Hi:
I used the following command to install matter OTBR, but the following error occurred when executing this command;(sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \
--sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \
--volume /dev/ttyACM0:/dev/radio nrfconnect/otbr:4b04548 --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000)
See the OTBR video tutorials provided by Nordic;
https://www.eeyxs.com/livebroadcast/index/playback/tid/627.html
sudo systemctl start docker
sudo docker network create --ipv6 --subnet fd11:db8:1::/64 -o com.docker.network.bridge.name=otbr0 otbr
sudo docker pull nrfconnect/otbr:4b04548
sudo ip -6 route add fd11:22::/64 dev otbr0 via fd11:db8:1::2
sudo modprobe ip6table_filter
