NCS 2.0.2: TFM+PSA+MBEDTLS bootloop
I want to use a setup as desctibed in the title, but I constantly get a bootloop.
I have a nrf9160dk >=0.14 (it has the ext flash at least) and I took the tfm_ipc sample and slowly modified it, to get to my target application that I need to have. This includes the crypto stuff, but also things like enabling mcuboot and using the ext flash as a secondary partition (for this use, I have already modified my SDK according to : https://github.com/nrfconnect/sdk-nrf/pull/8363 )
I want to use MBEDTLS from the ns image with the PSA api and C3xx drivers for hardware accelerated cryptography.
To save space, I want everything that is not needed in my application disabled, PSA wise. I now encounter a bootloop though and cannot enter in my application main(). I cannot testwise enable every PSA option, because then it doesn't fit into the FLASH. My hunch is, that one driver might need to be enabled, but I have no clue which.
Right now my prj.conf looks as follows, and I have attached my example program:
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
CONFIG_TFM_IPC=y
CONFIG_REBOOT=y
# The Zephyr CMSIS emulation assumes that ticks are ms, currently
### CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
# Log
CONFIG_USE_SEGGER_RTT=n
CONFIG_RTT_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_LOG=n
CONFIG_CONSOLE=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_CONSOLE_HANDLER=n
CONFIG_BOOT_BANNER=n
CONFIG_STDOUT_CONSOLE=n
# Kernel config
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
CONFIG_POLL=n
CONFIG_COMPILER_OPT="-Og"
CONFIG_TFM_LOG_LEVEL_SILENCE=y
CONFIG_TFM_PARTITION_AUDIT_LOG=n
CONFIG_TFM_BL2=n
## CONFIG_PM_PARTITION_SIZE_BL2=0x0
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_TFM_PROFILE_TYPE_MINIMAL=n
CONFIG_TFM_PROFILE_TYPE_SMALL=n
CONFIG_TFM_PROFILE_TYPE_MEDIUM=n
CONFIG_TFM_PROFILE_TYPE_LARGE=n
CONFIG_NRF_SECURITY=y
CONFIG_NRF_SECURITY_ADVANCED=y
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=n
CONFIG_PSA_WANT_ALG_CBC_PKCS7=n
CONFIG_PSA_WANT_ALG_CFB=n
CONFIG_PSA_WANT_ALG_OFB=n
CONFIG_PSA_WANT_ALG_CTR=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_CTR_CC3XX=y
CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_ECB_NO_PADDING_CC3XX=y
CONFIG_PSA_WANT_ALG_CMAC=n
CONFIG_PSA_WANT_ALG_HMAC=n
CONFIG_PSA_WANT_ALG_CCM=n
CONFIG_PSA_WANT_ALG_GCM=n
CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=n
CONFIG_PSA_WANT_ALG_ECDH=n
CONFIG_PSA_WANT_ALG_ECDSA=n
CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=n
CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256=n
CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384=n
CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512=n
CONFIG_PSA_WANT_ECC_MONTGOMERY_255=n
CONFIG_PSA_WANT_ECC_MONTGOMERY_448=n
CONFIG_PSA_WANT_ECC_SECP_K1_192=n
CONFIG_PSA_WANT_ECC_SECP_K1_256=n
CONFIG_PSA_WANT_ECC_SECP_R1_192=n
CONFIG_PSA_WANT_ECC_SECP_R1_224=n
CONFIG_PSA_CRYPTO_DRIVER_ECC_SECP_R1_224_CC3XX=y
CONFIG_PSA_WANT_ECC_SECP_R1_256=n
CONFIG_PSA_WANT_ECC_SECP_R1_384=n
CONFIG_PSA_WANT_ECC_SECP_R1_521=n
CONFIG_PSA_WANT_ALG_RSA_OAEP=n
CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=n
CONFIG_PSA_WANT_ALG_RSA_PSS=n
CONFIG_PSA_WANT_ALG_SHA_224=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_224_CC3XX=y
CONFIG_PSA_WANT_ALG_SHA_256=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_256_CC3XX=y
CONFIG_PSA_WANT_ALG_SHA_512=y
CONFIG_PSA_CRYPTO_DRIVER_ALG_SHA_512_OBERON=y
CONFIG_PSA_WANT_ALG_SHA_1=n
CONFIG_PSA_WANT_ALG_SHA_384=n
tfm_ipc_modified.zip
